I’m experiencing this issue only when playing AC Odyssey through Steam Proton. Could also be on any other game running proton, but I have no more examples.
It starts with whole system freezing, leaving me only an option to move the cursor. Nothing is clickable and keyboard shortcuts are not working. After a second or two, both screens turn black for a second, then come back but nothing changes. The audio is working as if nothing happened when screens are not black.
I am able to switch to TTY after screens are not black again, but can’t do anything to fix the issue. The only option is hard reboot.
Here is journald output:
21.10.2022 17:17:54:251 kernel amdgpu 0000:09:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:7 pasid:32803, for process ACOdyssey.exe pid 26251 thread dxvk-submit pid 26294)
21.10.2022 17:17:54:254 kernel amdgpu 0000:09:00.0: amdgpu: in page starting at address 0x0000000193f24000 from client 0x1b (UTCL2)
21.10.2022 17:17:54:254 kernel amdgpu 0000:09:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00701431
21.10.2022 17:17:54:255 kernel amdgpu 0000:09:00.0: amdgpu: Faulty UTCL2 client ID: SQC (data) (0xa)
21.10.2022 17:17:54:255 kernel amdgpu 0000:09:00.0: amdgpu: MORE_FAULTS: 0x1
21.10.2022 17:17:54:255 kernel amdgpu 0000:09:00.0: amdgpu: WALKER_ERROR: 0x0
21.10.2022 17:17:54:255 kernel amdgpu 0000:09:00.0: amdgpu: PERMISSION_FAULTS: 0x3
21.10.2022 17:17:54:255 kernel amdgpu 0000:09:00.0: amdgpu: MAPPING_ERROR: 0x0
21.10.2022 17:17:54:256 kernel amdgpu 0000:09:00.0: amdgpu: RW: 0x0
21.10.2022 17:17:54:256 kernel amdgpu 0000:09:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:7 pasid:32803, for process ACOdyssey.exe pid 26251 thread dxvk-submit pid 26294)
21.10.2022 17:17:54:256 kernel amdgpu 0000:09:00.0: amdgpu: in page starting at address 0x0000000193f24000 from client 0x1b (UTCL2)
21.10.2022 17:17:54:256 kernel amdgpu 0000:09:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
21.10.2022 17:17:54:256 kernel amdgpu 0000:09:00.0: amdgpu: Faulty UTCL2 client ID: CB/DB (0x0)
21.10.2022 17:17:54:256 kernel amdgpu 0000:09:00.0: amdgpu: MORE_FAULTS: 0x0
21.10.2022 17:17:54:256 kernel amdgpu 0000:09:00.0: amdgpu: WALKER_ERROR: 0x0
21.10.2022 17:17:54:257 kernel amdgpu 0000:09:00.0: amdgpu: PERMISSION_FAULTS: 0x0
21.10.2022 17:17:54:257 kernel amdgpu 0000:09:00.0: amdgpu: MAPPING_ERROR: 0x0
21.10.2022 17:17:54:258 kernel amdgpu 0000:09:00.0: amdgpu: RW: 0x0
21.10.2022 17:17:54:258 kernel amdgpu 0000:09:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:7 pasid:32803, for process ACOdyssey.exe pid 26251 thread dxvk-submit pid 26294)
21.10.2022 17:17:54:258 kernel amdgpu 0000:09:00.0: amdgpu: in page starting at address 0x0000000002d4d000 from client 0x1b (UTCL2)
21.10.2022 17:17:54:259 kernel amdgpu 0000:09:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
21.10.2022 17:17:54:259 kernel amdgpu 0000:09:00.0: amdgpu: Faulty UTCL2 client ID: CB/DB (0x0)
21.10.2022 17:17:54:259 kernel amdgpu 0000:09:00.0: amdgpu: MORE_FAULTS: 0x0
21.10.2022 17:17:54:259 kernel amdgpu 0000:09:00.0: amdgpu: WALKER_ERROR: 0x0
21.10.2022 17:17:54:260 kernel amdgpu 0000:09:00.0: amdgpu: PERMISSION_FAULTS: 0x0
21.10.2022 17:17:54:260 kernel amdgpu 0000:09:00.0: amdgpu: MAPPING_ERROR: 0x0
21.10.2022 17:17:54:260 kernel amdgpu 0000:09:00.0: amdgpu: RW: 0x0
21.10.2022 17:17:57:458 kernel [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=13314677, emitted seq=13314679
21.10.2022 17:17:57:458 kernel [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process ACOdyssey.exe pid 26251 thread dxvk-submit pid 26294
21.10.2022 17:18:01:458 kernel [drm:amdgpu_dm_atomic_commit_tail [amdgpu]] *ERROR* Waiting for fences timed out!
21.10.2022 17:18:01:918 kernel amdgpu 0000:09:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_2.1.0 test failed (-110)
21.10.2022 17:18:01:918 kernel [drm:gfx_v10_0_hw_fini [amdgpu]] *ERROR* KGQ disable failed
21.10.2022 17:18:02:184 kernel [drm:gfx_v10_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
21.10.2022 17:18:02:315 kernel snd_hda_intel 0000:09:00.1: spurious response 0x0:0x0, last cmd=0x1f0500
21.10.2022 17:18:02:316 kernel snd_hda_intel 0000:09:00.1: spurious response 0x0:0x0, last cmd=0x1f0500
21.10.2022 17:18:02:317 kernel snd_hda_intel 0000:09:00.1: spurious response 0x0:0x0, last cmd=0x1f0500
21.10.2022 17:18:03:229 kernel [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
21.10.2022 17:18:03:238 kernel [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
21.10.2022 17:18:03:247 kernel [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
21.10.2022 17:18:03:254 kernel [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
It may happen after 3 minutes of playtime, or may not happen at all. Trying to fix this I have tried this, but it didn’t help and it doesn’t seem like some specific voltage/power consumption/temp causes this.
I have also set amdgpu.runpm=0 in kernel parameters.
Full system info
Kernel: 5.19.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=41600e73-c3ec-4481-bede-1e252c347923 rw quiet apparmor=1
security=apparmor udev.log_priority=3 amdgpu.runpm=0 pcie_aspm=off
amdgpu.gpu_recovery=1 amdgpu.lockup_timeout=3000
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF B450M-PRO GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2409
date: 12/02/2020
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.26 GiB used: 8.44 GiB (27.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2197 high: 2201 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2195 2: 2200
3: 2195 4: 2195 5: 2200 6: 2196 7: 2195 8: 2194 9: 2200 10: 2201 11: 2200
12: 2200 bogomips: 86276
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 09:00.0 chip-ID: 1002:73ff
class-ID: 0300
Device-2: Lenovo FHD Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-3:2 chip-ID: 17ef:4831 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: vesa dri: radeonsi gpu: amdgpu display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Dell P2319H
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: LG (GoldStar)
24MB35 serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 96
gamma: 1.2 size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9
modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 6600 XT (dimgrey_cavefish LLVM 14.0.6 DRM
3.47 5.19.16-2-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 1-3:2 gen: 4 chip-ID: 17ef:4831 class-ID: 0102 speed: 16 GT/s
serial: <filter> lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Lenovo FHD Webcam type: USB driver: snd-usb-audio,uvcvideo
Device-4: Blue Microphones Yeti Nano type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: b58e:0005
class-ID: 0300 serial: <filter>
Sound API: ALSA v: k5.19.16-2-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.58 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-4d194edfcefc state: down mac: <filter>
IF-ID-2: br-933ce09a1c5c state: down mac: <filter>
IF-ID-3: br-a580f76f80b8 state: down mac: <filter>
IF-ID-4: br-cc892718ad0e state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-5: br-d45c8f5c6eec state: down mac: <filter>
all]
IF-ID-6: docker0 state: down mac: <filter>
all]
Device-1: ASUSTek ASUS USB-BT500 type: USB driver: btusb v: 0.8
bus-ID: 1-6:4 chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 1.8 TiB used: 347.62 GiB (18.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV500480G
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 56R6 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD502HJ
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 436.13 GiB size: 428.21 GiB (98.18%) used: 201.87 GiB
(47.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 41600e73-c3ec-4481-bede-1e252c347923
ID-2: /Steam64 raw-size: 931.51 GiB size: 915.81 GiB (98.31%) used: 145.75
GiB (15.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: dd0df7f1-3c83-4656-8a5c-091c0245d18f
ID-3: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 288 KiB
(0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: D300-C45E
ID-1: /dev/sda2 maj-min: 8:2 size: 10 GiB fs: ext4 label: N/A
uuid: c8dd6dd5-9852-484b-8b39-32ecf61a9383
ID-2: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 44E8-6B2A
ID-3: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb3 maj-min: 8:19 size: 249.48 GiB fs: ntfs label: WIN10
uuid: B84EF9984EF9501C
ID-5: /dev/sdb4 maj-min: 8:20 size: 511 MiB fs: ntfs label: N/A
uuid: D254144554142EAB
ID-6: /dev/sdb5 maj-min: 8:21 size: 215.66 GiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: Lenovo FHD Webcam type: Video,Audio
power: 256mA chip-ID: 17ef:4831 class-ID: 0102 serial: <filter>
Device-2: 1-5:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 1-6:4 info: ASUSTek ASUS USB-BT500 type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0b05:190e
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Blue Microphones Yeti Nano type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: b58e:0005 class-ID: 0300
serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.1 C mobo: N/A gpu: amdgpu temp: 34.0 C
mem: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1060
Processes: 338 Uptime: 19m wakeups: 6 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 2059 pm: pacman pkgs: 2039 libs: 528 tools: pamac,yay pm: snap
pkgs: 20 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.22
