Amdgpu & microcode hook
Should you use the modules amdgpu with the microcode hook ?
Its technically a little more than a yes or no answer.
  • amdgpu in MODULES will allow for early kernel mode setting.
  • microcode in HOOKS is desirable for loading the microcode into initramfs.
    This is how its done now - it is no longer part of the preset files so if you want that microcode it should be included in HOOKS.
https://wiki.archlinux.org/title/Kernel_mode_setting
https://wiki.archlinux.org/title/Mkinitcpio
https://wiki.archlinux.org/title/Microcode
For me that equates to a general ‘yes you should’ for most people, and these options are present on my system.
They are not directly related. amdgpu is the GPU driver, the microcode updates the CPU.
So, add both and enjoy a generally smoother boot process.
