Amdgpu glitch on hybrid laptop
Hello everyone.
I just changed my laptop for a legion 5 pro with a ryzen 7 and a nvidia rtx 4070.
I installed manjaro (gnome) without issue and installed video-hybrid-amd-nvidia-prime with mhwd and it work very well.
DE is loaded with amdgpu and prime-run work well.
But, after some times -between 5 and 10 minutes- I got a lot of glitches (text in blank square, images dissapearing , css animation flickering…), its mainly on the browser but when it begin, it appear also on every app (terminal, file browser, also on window decoration).
I tried adding amdgpu-runpm=0 like I saw in multiple threads but it didn’t help.
I installed kde version first before installing gnome one (different subject, it was because I prefer gnome experience). and on kde, it was glitching but also freeze and reboot the laptop. On gnome version it only flicker.
I disabled switchable graphic for now (so I only run on nvidia) but I’d rather use the integrated graphic too to save some battery.
I also tried to install amdgpu-pro but did’nt succed at running it instead of amdgpu.
Does anyone have the same issue ?
try a different kernel, for example with the 6.4 and see if it has the same issues…
also provide full system info:
inxi -zav7
and use formatting:
your output here
or:
your output here
I juste installed 6.4 and waiting for glitches. I’ll update the post for changes.
Here my inxi in the meantime
  Kernel: 6.4.2-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
    root=UUID=ad6062ba-ce58-45f5-b085-cd65f60d63ee rw quiet splash apparmor=1
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: LENOVO product: 82WM v: Legion Pro 5 16ARX8
    serial: <superuser required> Chassis: type: 10 v: Legion Pro 5 16ARX8
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: LPCN25WW date: 03/06/2023
  ID-1: BAT0 charge: 78.4 Wh (98.0%) condition: 80.0/80.0 Wh (100.0%)
    volts: 17.3 min: 15.4 model: BYD L22B4PC0 type: Li-poly serial: <filter>
    status: not charging cycles: 3
  Device-1: hidpp_battery_0 model: Logitech MX Master 3S serial: <filter>
    charge: 65% rechargeable: yes status: discharging
  System RAM: total: 32 GiB note: est. available: 30.54 GiB
    used: 14.7 GiB (48.1%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 7 7745HX with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2087 high: 5122 min/max: 1500/5150 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2598 2: 1500
    3: 1500 4: 1500 5: 5099 6: 5122 7: 1500 8: 1500 9: 1500 10: 1500 11: 2036
    12: 1500 13: 2044 14: 1500 15: 1500 16: 1500 bogomips: 115037
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
    vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1
    xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
    conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile]
    vendor: Lenovo GN21-X6 driver: nvidia v: 535.54.03
    alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
    chip-ID: 10de:2860 class-ID: 0300
  Device-2: AMD Raphael vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 08:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 45.0 C
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:3
    chip-ID: 30c9:00ac class-ID: fe01 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0b11 serial: <filter>
    built: 2022 res: 2560x1600 dpi: 188 gamma: 1.2 size: 345x215mm (13.58x8.46")
    diag: 407mm (16") ratio: 16:10 modes: max: 2560x1600 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (gfx1036
    LLVM 15.0.7 DRM 3.52 6.4.2-3-MANJARO) direct-render: Yes
  Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1
    chip-ID: 10de:22bd class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 08:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.4.2-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.73 status: off tools: pw-cli
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
  IF-ID-1: br-3f79bb2a939c state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: br-80258d0e7d1d state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-3: docker0 state: down mac: <filter>
  Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-4: vethba72cf7 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-5: vethf2f280a state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.1:3
    chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Local Storage: total: 953.87 GiB used: 120.6 GiB (12.6%)
    model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: CL1QGXA7 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 531.49 GiB size: 522.08 GiB (98.23%)
    used: 79.5 GiB (15.2%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: ad6062ba-ce58-45f5-b085-cd65f60d63ee
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 57.8 MiB (11.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: C0A2-51CE
  ID-3: /data/windows raw-size: 390.62 GiB size: 390.62 GiB (100.00%)
    used: 41.05 GiB (10.5%) fs: ntfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 96F29110F290F629
  ID-1: swap-1 type: partition size: 31.25 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: f40a723e-7c2b-48cc-b3db-a08be0a0e150
  ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 3-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 3-2.4:3 info: Luxvisions Innotech Integrated Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:00ac class-ID: fe01
    serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-2:2 info: Realtek Hub ports: 3 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 5-1:2 info: Genesys Logic Hub ports: 3 rev: 2.0
  Device-1: 5-1.1:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Device-2: 5-1.2:4 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c103 class-ID: 0301
  Hub-9: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 62.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
  Processes: 413 Uptime: 3m wakeups: 3 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1364 libs: 361 tools: gnome-software,pamac,trizen pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.28
Well I don’t really know.
With 6.4 it seem better, less glitches and it only appears on chrome and when I close it and restart it (the browser) it diseapper for a time. But its still there for sure.
a picture to show the glitches I’ve got.
edit: funny.
When I take the screenshot, I see the glitches on the screenshot preview but after its just blank with transparent background. I’ll take photo next time.
after the glitches happen again, provide logs:
journalctl -b0 -p4 --no-pager
the buq appear again:
in the journal I got first this:
juil. 14 21:15:45 asgard gnome-shell[2532]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55c4f007ead0] is on because it needs an allocation.
juil. 14 21:15:45 asgard gnome-shell[2532]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55c4ef169260] is on because it needs an allocation.
juil. 14 21:15:46 asgard gnome-shell[2532]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55c4f007ead0] is on because it needs an allocation.
juil. 14 21:15:46 asgard gnome-shell[2532]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55c4ef169260] is on because it needs an allocation.
and now I got a bunch of :
juil. 14 21:16:18 asgard kernel: ACPI BIOS Error (bug): The DSDT has been corrupted or replaced - old, new headers below (20230331/tbutils-87)
juil. 14 21:16:18 asgard kernel: ACPI Error: Please send DMI info to linux-acpi@vger.kernel.org
                                 If system does not work as expected, please boot with acpi=copy_dsdt (20230331/tbutils-94)
juil. 14 21:16:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0.BAT0._BST.T], AE_NOT_FOUND (20230331/psargs-330)
juil. 14 21:16:18 asgard kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
that don’t seem to be related (bat0 mean battery i think, thats concerning but not related I think).
here a photo:
I startid chrome via cli and I got a bunch of
[15494:3:0714/212445.411999:ERROR:tracing_muxer_impl.cc(1608)] Could not find data source to clear incremental state for
[15200:3:0714/212445.915649:ERROR:tracing_muxer_impl.cc(1608)] Could not find data source to clear incremental state for
[15246:3:0714/212445.915685:ERROR:tracing_muxer_impl.cc(1608)] Could not find data source to clear incremental state for
[15237:3:0714/212445.915720:ERROR:tracing_muxer_impl.cc(1608)] Could not find data source to clear incremental state for
[15252:3:0714/212445.915723:ERROR:tracing_muxer_impl.cc(1608)] Could not find data source to clear incremental state for
[15257:3:0714/212445.915763:ERROR:tracing_muxer_impl.cc(1608)] Could not find data source to clear incremental state for
I restartted chrome again and my De blacked out et came back again (no restart, every window still here) and this in the cli of chrome
[15596:15596:0714/212506.616454:ERROR:shared_context_state.cc(905)] SharedContextState context lost via ARB/EXT_robustness. Reset status = GL_INNOCENT_CONTEXT_RESET_KHR
[15596:15596:0714/212506.616556:ERROR:gpu_service_impl.cc(1046)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
[15551:15551:0714/212506.640778:ERROR:gpu_process_host.cc(956)] GPU process exited unexpectedly: exit_code=8704
[15673:7:0714/212506.757089:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
[15694:1:0714/212506.894089:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[15551:15551:0714/212507.810093:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.ScreenSaver.GetActive: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NotSupported: This method is not implemented
I remember when I was testting kde manjaro, the de restarted the same way with a tooltip at the bottem saying that the gpu will restart shortly.
i wanted to see all the logs from the output…
when the glitch happens, are you forced to reboot?
if yes, provide logs from the previous boot with:
journalctl -b-1 -p4 --no-pager
but here is something:
so try booting with this parameter, and see:
sudo nano /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT - inside the quotes add this parameter:
acpi=copy_dsdt
dont remove anything from there, just add it to the existing parameters, save the file with ctrl+x, press ‘y’, then enter, and update grub with:
sudo update-grub
reboot and test
Just added it and rebooted, waiting for glitches to happen.
It does not force me to reboot when it happen, after a time, it just blackout, and reappear with all the windows already opened earlier (except chrome).
edit (10 minutes later): it happen again
if you dont have to reboot, post the full logs:
voila un log complet juste après un reboot du gpu.
Je precise qu’entre temps j’ai ausse tenté de passer sur wayland, qui me semblait plus stable mais au final non c’est pareil.
juil. 16 21:38:19 asgard kernel: TSC synchronization [CPU#0 -> CPU#1]:
juil. 16 21:38:19 asgard kernel: Measured 6870121506 cycles TSC warp between CPUs, turning off TSC clock.
juil. 16 21:38:19 asgard kernel:   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
juil. 16 21:38:19 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PB2], AE_NOT_FOUND (20230331/dswload2-162)
juil. 16 21:38:19 asgard kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230331/psobject-220)
juil. 16 21:38:19 asgard kernel: ACPI: IRQ 1 override to edge, high(!)
juil. 16 21:38:19 asgard kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
juil. 16 21:38:19 asgard kernel: pci 0000:00:00.2: PCI INT A: not connected
juil. 16 21:38:19 asgard kernel: Unstable clock detected, switching default tracing clock to "global"
                                 If you want to keep using the local clock, then add:
                                   "trace_clock=local"
                                 on the kernel command line
juil. 16 21:38:19 asgard kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
juil. 16 21:38:19 asgard kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
juil. 16 21:38:19 asgard kernel: usb: port power management may be unreliable
juil. 16 21:38:19 asgard kernel: memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
juil. 16 21:38:18 asgard systemd-vconsole-setup[404]: Failed to import credentials, ignoring: Aucun fichier ou dossier de ce type
juil. 16 21:38:19 asgard systemd-journald[409]: File /var/log/journal/a429a3d0ebff4e5c840253eb070c9dfb/system.journal corrupted or uncleanly shut down, renaming and replacing.
juil. 16 21:38:19 asgard kernel: wmi_bus wmi_bus-PNP0C14:01: WQA0 data block query control method not found
juil. 16 21:38:19 asgard kernel: wmi_bus wmi_bus-PNP0C14:01: WQA5 data block query control method not found
juil. 16 21:38:19 asgard kernel: nvidia: loading out-of-tree module taints kernel.
juil. 16 21:38:19 asgard kernel: nvidia: module license 'NVIDIA' taints kernel.
juil. 16 21:38:19 asgard kernel: Disabling lock debugging due to kernel taint
juil. 16 21:38:19 asgard kernel: nvidia: module license taints kernel.
juil. 16 21:38:19 asgard kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  535.54.03  Tue Jun  6 22:20:39 UTC 2023
juil. 16 21:38:19 asgard kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
juil. 16 21:38:20 asgard kernel: ATPX version 1, functions 0x00000801
juil. 16 21:38:20 asgard kernel: ATPX Hybrid Graphics
juil. 16 21:38:20 asgard systemd-modules-load[342]: Failed to find module 'options nvidia NVreg_PreserveVideoMemoryAllocations=1'
juil. 16 21:38:20 asgard systemd-modules-load[342]: Failed to find module 'options nvidia NVreg_TemporaryFilePath=/run'
juil. 16 21:38:20 asgard kernel: amdgpu: SRAT table not found
juil. 16 21:38:21 asgard kernel: ------------[ cut here ]------------
juil. 16 21:38:21 asgard kernel: WARNING: CPU: 10 PID: 210 at drivers/gpu/drm/amd/amdgpu/../display/dc/dcn20/dcn20_dsc.c:273 dsc2_disable+0x150/0x160 [amdgpu]
juil. 16 21:38:21 asgard kernel: Modules linked in: snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp nvidia_uvm(POE) snd_sof snd_sof_utils intel_rapl_msr intel_rapl_common snd_soc_core edac_mce_amd vfat snd_compress amdgpu fat ac97_bus snd_hda_codec_realtek mt7921e(+) snd_pcm_dmaengine kvm_amd snd_hda_codec_generic ledtrig_audio nvidia_drm(POE) snd_pci_ps mt7921_common kvm snd_hda_codec_hdmi mt76_connac_lib mt76 snd_hda_intel irqbypass snd_intel_dspcfg uvcvideo mousedev snd_rpl_pci_acp6x crct10dif_pclmul snd_acp_pci videobuf2_vmalloc snd_intel_sdw_acpi snd_pci_acp6x crc32_pclmul drm_buddy uvc polyval_clmulni snd_hda_codec nvidia_modeset(POE) polyval_generic videobuf2_memops snd_pci_acp5x gpu_sched gf128mul i2c_algo_bit btusb videobuf2_v4l2 ghash_clmulni_intel snd_hda_core sha512_ssse3 btrtl snd_rn_pci_acp3x drm_suballoc_helper mac80211 videodev snd_acp_config drm_ttm_helper snd_hwdep btbcm aesni_intel ttm btintel r8169 crypto_simd btmtk snd_pcm libarc4 snd_soc_acpi cryptd realtek hid_multitouch
juil. 16 21:38:21 asgard kernel:  bluetooth drm_display_helper videobuf2_common ideapad_laptop snd_timer ucsi_acpi sparse_keymap wmi_bmof cfg80211 typec_ucsi sp5100_tco mdio_devres snd cec platform_profile mc ecdh_generic rapl snd_pci_acp3x wdat_wdt pcspkr nvidia(POE) libphy typec ccp acpi_cpufreq soundcore video i2c_piix4 k10temp rfkill roles i2c_hid_acpi wmi i2c_hid joydev mac_hid crypto_user fuse dm_mod loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid serio_raw atkbd libps2 vivaldi_fmap nvme crc32c_intel nvme_core xhci_pci i8042 xhci_pci_renesas nvme_common serio
juil. 16 21:38:21 asgard kernel: CPU: 10 PID: 210 Comm: plymouthd Tainted: P           OE      6.4.2-3-MANJARO #1 b8b1fec9d2ca7e610dcda537ef3912d54df433f4
juil. 16 21:38:21 asgard kernel: Hardware name: LENOVO 82WM/LNVNB161216, BIOS LPCN25WW 03/06/2023
juil. 16 21:38:21 asgard kernel: RIP: 0010:dsc2_disable+0x150/0x160 [amdgpu]
juil. 16 21:38:21 asgard kernel: Code: 00 00 00 75 2c 48 83 c4 18 5b c3 cc cc cc cc 8b 4b 10 44 8b 44 24 0c be 02 00 00 00 31 ff 48 c7 c2 30 1a aa c5 e8 00 fd 7c cb <0f> 0b e9 6e ff ff ff e8 24 b6 c7 cb 0f 1f 40 00 90 90 90 90 90 90
juil. 16 21:38:21 asgard kernel: RSP: 0018:ffffa7a680883490 EFLAGS: 00010246
juil. 16 21:38:21 asgard kernel: RAX: 0000000000000000 RBX: ffff95030650b000 RCX: 0000000000000000
juil. 16 21:38:21 asgard kernel: RDX: ffffffffc5aa1a30 RSI: 0000000000000002 RDI: 0000000000000000
juil. 16 21:38:21 asgard kernel: RBP: 0000000000000001 R08: 0000000000000000 R09: 0000000000000004
juil. 16 21:38:21 asgard kernel: R10: 0000000000000001 R11: 0000000000000100 R12: ffff95030ee801e8
juil. 16 21:38:21 asgard kernel: R13: ffff9503072bc800 R14: ffff9503072bc800 R15: 0000000000000001
juil. 16 21:38:21 asgard kernel: FS:  00007f8abbcf0740(0000) GS:ffff950a3d880000(0000) knlGS:0000000000000000
juil. 16 21:38:21 asgard kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
juil. 16 21:38:21 asgard kernel: CR2: 00007f2a827cd000 CR3: 0000000104118000 CR4: 0000000000750ee0
juil. 16 21:38:21 asgard kernel: PKRU: 55555554
juil. 16 21:38:21 asgard kernel: Call Trace:
juil. 16 21:38:21 asgard kernel:  <TASK>
juil. 16 21:38:21 asgard kernel:  ? dsc2_disable+0x150/0x160 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? __warn+0x81/0x130
juil. 16 21:38:21 asgard kernel:  ? report_bug+0x171/0x1a0
juil. 16 21:38:21 asgard kernel:  ? handle_bug+0x3c/0x80
juil. 16 21:38:21 asgard kernel:  ? exc_invalid_op+0x17/0x70
juil. 16 21:38:21 asgard kernel:  ? asm_exc_invalid_op+0x1a/0x20
juil. 16 21:38:21 asgard kernel:  link_set_dsc_on_stream+0x30e/0x3e0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? drm_dp_dpcd_write+0xc3/0xe0 [drm_display_helper 950afc6d563760d93fa7ae8c63a17525eef1c81c]
juil. 16 21:38:21 asgard kernel:  ? dm_helpers_dp_write_dsc_enable+0x264/0x660 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  link_set_dsc_enable+0x75/0x90 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  link_set_dpms_off+0x17d/0x8a0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dmub_dcn31_get_fw_boot_status+0x20/0x30 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dmub_srv_get_fw_boot_status+0x2a/0x50 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dc_dmub_srv_is_restore_required+0x3c/0x80 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dm_read_reg_func+0x38/0xb0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  dc_commit_state_no_check+0xdd8/0xe60 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  dc_commit_streams+0x2e0/0x3f0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  amdgpu_dm_atomic_commit_tail+0x5e8/0x3a10 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dsc2_validate_stream+0x3b/0x60 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dcn20_validate_dsc+0x17a/0x1a0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dcn30_internal_validate_bw+0x90f/0x9d0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dcn31_validate_bandwidth+0x12f/0x2d0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dc_validate_global_state+0x307/0x3e0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  ? dma_resv_iter_first_unlocked+0x66/0x70
juil. 16 21:38:21 asgard kernel:  ? dma_resv_get_fences+0x61/0x220
juil. 16 21:38:21 asgard kernel:  ? wait_for_completion_timeout+0x13e/0x170
juil. 16 21:38:21 asgard kernel:  ? wait_for_completion_interruptible+0x139/0x1e0
juil. 16 21:38:21 asgard kernel:  ? dm_plane_helper_prepare_fb+0x17f/0x2f0 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  commit_tail+0x91/0x130
juil. 16 21:38:21 asgard kernel:  drm_atomic_helper_commit+0x11a/0x140
juil. 16 21:38:21 asgard kernel:  drm_atomic_commit+0x97/0xd0
juil. 16 21:38:21 asgard kernel:  ? __pfx___drm_printfn_info+0x10/0x10
juil. 16 21:38:21 asgard kernel:  drm_atomic_helper_set_config+0x74/0xb0
juil. 16 21:38:21 asgard kernel:  drm_mode_setcrtc+0x3c5/0x7f0
juil. 16 21:38:21 asgard kernel:  ? __pfx_drm_mode_setcrtc+0x10/0x10
juil. 16 21:38:21 asgard kernel:  drm_ioctl_kernel+0xca/0x170
juil. 16 21:38:21 asgard kernel:  drm_ioctl+0x26d/0x4b0
juil. 16 21:38:21 asgard kernel:  amdgpu_drm_ioctl+0x4e/0x90 [amdgpu 8e69a0b6301081bb6e64b0950e46c4ca83b229a3]
juil. 16 21:38:21 asgard kernel:  __x64_sys_ioctl+0x91/0xd0
juil. 16 21:38:21 asgard kernel:  do_syscall_64+0x5d/0x90
juil. 16 21:38:21 asgard kernel:  ? __x64_sys_ioctl+0x91/0xd0
juil. 16 21:38:21 asgard kernel:  ? syscall_exit_to_user_mode+0x1b/0x40
juil. 16 21:38:21 asgard kernel:  ? do_syscall_64+0x6c/0x90
juil. 16 21:38:21 asgard kernel:  entry_SYSCALL_64_after_hwframe+0x72/0xdc
juil. 16 21:38:21 asgard kernel: RIP: 0033:0x7f8abbf4676f
juil. 16 21:38:21 asgard kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
juil. 16 21:38:21 asgard kernel: RSP: 002b:00007ffe2b2cad30 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
juil. 16 21:38:21 asgard kernel: RAX: ffffffffffffffda RBX: 00007f8abbcf06c8 RCX: 00007f8abbf4676f
juil. 16 21:38:21 asgard kernel: RDX: 00007ffe2b2cadc0 RSI: 00000000c06864a2 RDI: 0000000000000009
juil. 16 21:38:21 asgard kernel: RBP: 00007ffe2b2cadc0 R08: 0000000000000000 R09: 000055f123ba6100
juil. 16 21:38:21 asgard kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00000000c06864a2
juil. 16 21:38:21 asgard kernel: R13: 0000000000000009 R14: 0000000000000001 R15: 000055f123ba6090
juil. 16 21:38:21 asgard kernel:  </TASK>
juil. 16 21:38:21 asgard kernel: ---[ end trace 0000000000000000 ]---
juil. 16 21:38:21 asgard bluetoothd[619]: src/plugin.c:plugin_init() System does not support csip plugin
juil. 16 21:38:21 asgard bluetoothd[619]: src/plugin.c:plugin_init() System does not support vcp plugin
juil. 16 21:38:21 asgard bluetoothd[619]: src/plugin.c:plugin_init() System does not support mcp plugin
juil. 16 21:38:21 asgard bluetoothd[619]: src/plugin.c:plugin_init() System does not support bass plugin
juil. 16 21:38:21 asgard bluetoothd[619]: src/plugin.c:plugin_init() System does not support bap plugin
juil. 16 21:38:21 asgard kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
juil. 16 21:38:21 asgard bluetoothd[619]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
juil. 16 21:38:21 asgard bluetoothd[619]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
juil. 16 21:38:21 asgard bluetoothd[619]: Failed to clear UUIDs: Failed (0x03)
juil. 16 21:38:21 asgard bluetoothd[619]: Failed to add UUID: Failed (0x03)
juil. 16 21:38:21 asgard bluetoothd[619]: Failed to set mode: Failed (0x03)
juil. 16 21:38:21 asgard bluetoothd[619]: Too small Add Device complete event
juil. 16 21:38:26 asgard gsettings[744]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:26 asgard gsettings[744]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:26 asgard gnome-session-b[743]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:26 asgard gnome-session-b[743]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:26 asgard gnome-session-binary[743]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
juil. 16 21:38:26 asgard kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230331/nsarguments-61)
juil. 16 21:38:26 asgard kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230331/nsarguments-61)
juil. 16 21:38:27 asgard gnome-shell[753]: Failed to open gpu '/dev/dri/card0': No suitable mode setting backend found
juil. 16 21:38:27 asgard gnome-shell[753]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:27 asgard gnome-shell[753]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:27 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=753 comm="/usr/bin/gnome-shell")
juil. 16 21:38:27 asgard at-spi-bus-laun[784]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
juil. 16 21:38:27 asgard at-spi-bus-laun[784]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
juil. 16 21:38:27 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Successfully activated service 'org.a11y.Bus'
juil. 16 21:38:27 asgard kernel: kauditd_printk_skb: 51 callbacks suppressed
juil. 16 21:38:27 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=753 comm="/usr/bin/gnome-shell")
juil. 16 21:38:27 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=753 comm="/usr/bin/gnome-shell")
juil. 16 21:38:27 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=753 comm="/usr/bin/gnome-shell")
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[790]: dbus-daemon[790]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=753 comm="/usr/bin/gnome-shell")
juil. 16 21:38:28 asgard geoclue[1064]: Failed to connect to avahi service: Daemon not running
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[790]: dbus-daemon[790]: Successfully activated service 'org.a11y.atspi.Registry'
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Successfully activated service 'org.gnome.Shell.Notifications'
juil. 16 21:38:28 asgard gsd-sharing[1176]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-sharing[1176]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-smartcard[1193]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-smartcard[1193]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-usb-protect[1179]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-usb-protect[1179]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-color[1180]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-color[1180]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-keyboard[1181]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-keyboard[1181]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-wacom[1197]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-wacom[1197]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1179 comm="/usr/lib/gsd-usb-protection")
juil. 16 21:38:28 asgard gsd-media-keys[1209]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-media-keys[1209]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-housekeepin[1222]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-a11y-settin[1214]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-housekeepin[1222]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-a11y-settin[1214]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-datetime[1206]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-datetime[1206]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-sound[1211]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-sound[1211]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-power[1230]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard gsd-power[1230]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=1176 comm="/usr/lib/gsd-sharing")
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
juil. 16 21:38:28 asgard gsd-sharing[1176]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.gtk.vfs.Daemon' requested by ':1.25' (uid=120 pid=1215 comm="ibus-daemon --panel disable")
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Successfully activated service 'org.gtk.vfs.Daemon'
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.freedesktop.portal.IBus' requested by ':1.25' (uid=120 pid=1215 comm="ibus-daemon --panel disable")
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Successfully activated service 'org.freedesktop.portal.IBus'
juil. 16 21:38:28 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Successfully activated service 'org.gnome.ScreenSaver'
juil. 16 21:38:28 asgard gsd-usb-protect[1179]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
juil. 16 21:38:28 asgard kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
juil. 16 21:38:29 asgard gsd-media-keys[1209]: Failed to grab accelerator for keybinding settings:magnifier-zoom-out
juil. 16 21:38:29 asgard gsd-media-keys[1209]: Failed to grab accelerator for keybinding settings:playback-repeat
juil. 16 21:38:29 asgard gsd-media-keys[1209]: Failed to grab accelerator for keybinding settings:hibernate
juil. 16 21:38:29 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Activating service name='org.freedesktop.portal.IBus' requested by ':1.37' (uid=120 pid=1729 comm="ibus-daemon --panel disable -r --xim")
juil. 16 21:38:29 asgard /usr/lib/gdm-wayland-session[742]: dbus-daemon[742]: [session uid=120 pid=742] Successfully activated service 'org.freedesktop.portal.IBus'
juil. 16 21:38:29 asgard gsd-xsettings[1219]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:29 asgard gsd-xsettings[1219]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:29 asgard mutter-x11-fram[1728]: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:29 asgard mutter-x11-fram[1728]: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce type; expect degraded performance
juil. 16 21:38:32 asgard gnome-shell[753]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Failed: Set global engine failed: L’opération a été annulée
                                           _promisify/proto[asyncFunc]/</<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:453:45
                                           ### Promise created here: ###
                                           _setEngine@resource:///org/gnome/shell/misc/ibusManager.js:304:30
                                           setEngine@resource:///org/gnome/shell/misc/ibusManager.js:327:24
                                           activateInputSource@resource:///org/gnome/shell/ui/status/keyboard.js:491:31
                                           _callHandlers@resource:///org/gnome/gjs/modules/core/_signals.js:130:42
                                           _emit@resource:///org/gnome/gjs/modules/core/_signals.js:119:10
                                           activate@resource:///org/gnome/shell/ui/status/keyboard.js:60:14
                                           _inputSourcesChanged@resource:///org/gnome/shell/ui/status/keyboard.js:625:33
                                           reload@resource:///org/gnome/shell/ui/status/keyboard.js:365:14
                                           _ibusSetContentType@resource:///org/gnome/shell/ui/status/keyboard.js:700:14
                                           _setContentType@resource:///org/gnome/shell/misc/ibusManager.js:279:14
juil. 16 21:38:43 asgard gdm-password][1854]: gkr-pam: unable to locate daemon control file
juil. 16 21:38:44 asgard systemd-journald[409]: File /var/log/journal/a429a3d0ebff4e5c840253eb070c9dfb/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
juil. 16 21:38:44 asgard systemd-xdg-autostart-generator[1912]: /home/eephyne/.config/autostart/manjaro-app-folder-settings.desktop: not generating unit, error parsing Exec= line: No such file or directory
juil. 16 21:38:44 asgard systemd-xdg-autostart-generator[1912]: /home/eephyne/.config/autostart/manjaro-starter.desktop: not generating unit, error parsing Exec= line: No such file or directory
juil. 16 21:38:44 asgard gnome-session-binary[1974]: WARNING: Desktop file /home/eephyne/.config/autostart/manjaro-starter.desktop for application manjaro-starter.desktop could not be parsed or references a missing TryExec binary
juil. 16 21:38:44 asgard gnome-session-binary[1974]: WARNING: Desktop file /home/eephyne/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
juil. 16 21:38:44 asgard gnome-keyring-daemon[1989]: discover_other_daemon: 1
juil. 16 21:38:44 asgard gnome-keyring-daemon[1990]: discover_other_daemon: 1
juil. 16 21:38:44 asgard gnome-keyring-daemon[1991]: discover_other_daemon: 1
juil. 16 21:38:44 asgard gnome-shell[1998]: Failed to open gpu '/dev/dri/card0': No suitable mode setting backend found
juil. 16 21:38:45 asgard gnome-shell[1998]: Some code accessed the property 'SecondaryMonitorDisplay' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
juil. 16 21:38:45 asgard gnome-shell[1998]: Some code accessed the property 'ThumbnailsBox' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
juil. 16 21:38:45 asgard systemd[1903]: Dependency failed for GNOME XSettings service.
juil. 16 21:38:45 asgard gnome-session-binary[1974]: GnomeDesktop-WARNING: Could not create transient scope for PID 2394: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2394 does not exist.
juil. 16 21:38:45 asgard gsd-usb-protect[2301]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
juil. 16 21:38:45 asgard pulseaudio[2138]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
juil. 16 21:38:45 asgard gnome-shell[1998]: Failed to create color profile from colord profile: Erreur lors de l’ouverture du fichier /var/lib/gdm/.local/share/icc/edid-3df377a1277bb0722fcc33fc120c255d.icc : Permission non accordée
juil. 16 21:38:45 asgard bluetoothd[619]: Failed to add UUID: Failed (0x03)
juil. 16 21:38:46 asgard gsd-media-keys[2279]: Failed to grab accelerator for keybinding settings:playback-repeat
juil. 16 21:38:46 asgard gsd-media-keys[2279]: Failed to grab accelerator for keybinding settings:magnifier-zoom-out
juil. 16 21:38:46 asgard gsd-media-keys[2279]: Failed to grab accelerator for keybinding settings:hibernate
juil. 16 21:38:46 asgard gnome-shell[753]: Connection to xwayland lost
juil. 16 21:38:46 asgard pulseaudio[1047]: X11 I/O error handler called
juil. 16 21:38:46 asgard pulseaudio[1047]: X11 I/O error exit handler called, preparing to tear down X11 modules
juil. 16 21:38:46 asgard gnome-shell[753]: Xwayland terminated, exiting since it was mandatory
juil. 16 21:38:46 asgard gnome-shell[753]: (../mutter/src/core/meta-context.c:501):meta_context_terminate: runtime check failed: (g_main_loop_is_running (priv->main_loop))
juil. 16 21:39:06 asgard kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
juil. 16 21:39:28 asgard kernel: mt7921e 0000:04:00.0: not ready 65535ms after FLR; giving up
juil. 16 21:39:29 asgard gnome-shell[1998]: Could not open device /dev/input/event16: GDBus.Error:System.Error.ENODEV: No such device
juil. 16 21:39:31 asgard gnome-keyring-daemon[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 16 21:39:31 asgard gnome-keyring-d[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 16 21:39:34 asgard wpa_supplicant[1116]: bgscan simple: Failed to enable signal strength monitoring
juil. 16 21:39:34 asgard kernel: warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
juil. 16 21:39:42 asgard gnome-shell[1998]: JS ERROR: Extension x11gestures@joseexposito.github.io: TypeError: obj._toucheggTracker is undefined
                                            unhook@/usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:171:5
                                            stop@/usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:160:23
                                            disable@/usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/extension.js:63:18
                                            _callExtensionDisable@resource:///org/gnome/shell/ui/extensionSystem.js:132:32
                                            _onEnabledExtensionsChanged@resource:///org/gnome/shell/ui/extensionSystem.js:565:24
                                            _sessionUpdated@resource:///org/gnome/shell/ui/extensionSystem.js:717:20
                                            ExtensionManager/<@resource:///org/gnome/shell/ui/extensionSystem.js:36:18
                                            _sync@resource:///org/gnome/shell/ui/sessionMode.js:208:14
                                            pushMode@resource:///org/gnome/shell/ui/sessionMode.js:167:14
                                            activate@resource:///org/gnome/shell/ui/screenShield.js:617:34
                                            lock@resource:///org/gnome/shell/ui/screenShield.js:684:14
                                            _prepareForSleep@resource:///org/gnome/shell/ui/screenShield.js:246:22
                                            _prepareForSleep@resource:///org/gnome/shell/misc/loginManager.js:205:14
                                            _convertToNativeSignal@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:152:19
juil. 16 21:39:42 asgard kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
juil. 16 22:27:19 asgard kernel: queueing ieee80211 work while going to suspend
juil. 16 22:27:19 asgard kernel: mt7921e 0000:04:00.0: Message 00020007 (seq 3) timeout
juil. 16 22:27:19 asgard kernel: mt7921e 0000:04:00.0: PM: dpm_run_callback(): pci_pm_resume+0x0/0xf0 returns -110
juil. 16 22:27:19 asgard kernel: mt7921e 0000:04:00.0: PM: failed to resume async: error -110
juil. 16 22:27:19 asgard rtkit-daemon[1073]: The canary thread is apparently starving. Taking action.
juil. 16 22:27:19 asgard kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
juil. 16 22:27:19 asgard kernel: atkbd serio0: Failed to enable keyboard on isa0060/serio0
juil. 16 22:27:22 asgard kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
juil. 16 22:27:22 asgard bluetoothd[619]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
juil. 16 22:27:23 asgard wpa_supplicant[1116]: bgscan simple: Failed to enable signal strength monitoring
juil. 16 22:27:29 asgard wpa_supplicant[1116]: bgscan simple: Failed to enable signal strength monitoring
juil. 16 22:28:20 asgard kernel: NVRM: GPU at PCI:0000:01:00: GPU-c89a9029-6ff1-abff-e7d5-efd228c8cf86
juil. 16 22:28:20 asgard kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=342, name=systemd-modules, Ch 00000003, intr 00000000. MMU Fault: ENGINE HOST2 HUBCLIENT_ESC faulted @ 0x1_01010000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
juil. 16 22:28:20 asgard kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=1718, name=python, Ch 00000010, intr 00000000. MMU Fault: ENGINE HOST0 HUBCLIENT_ESC faulted @ 0x2_00200000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
juil. 16 22:31:22 asgard rtkit-daemon[1073]: Recovering from system lockup, not allowing further RT threads.
juil. 16 22:31:22 asgard telegram-desktop[4479]: QPainter::begin: Paint device returned engine == 0, type: 2
juil. 16 22:31:22 asgard telegram-desktop[4479]: QWidget::render: Cannot render with an inactive painter
juil. 16 22:31:22 asgard telegram-desktop[4479]: qt.svg: Error while inflating gzip file: SVG format check failed
juil. 16 22:31:23 asgard telegram-desktop[4479]: qt.svg: Error while inflating gzip file: SVG format check failed
juil. 16 22:31:25 asgard telegram-desktop[4479]: qt.svg: Error while inflating gzip file: SVG format check failed
juil. 16 22:31:54 asgard gnome-shell[1998]: Object .Gjs_ui_messageTray_Notification (0x55cc4f213ca0), has been already disposed — impossible to emit any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 16 22:31:54 asgard gnome-shell[1998]: Object .Gjs_ui_messageTray_Notification (0x55cc4f213ca0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 16 22:39:26 asgard gnome-shell[1998]: Object .Gjs_ui_messageTray_Notification (0x55cc4be42b30), has been already disposed — impossible to emit any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 16 22:39:26 asgard gnome-shell[1998]: Object .Gjs_ui_messageTray_Notification (0x55cc4be42b30), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 16 22:39:30 asgard telegram-desktop[4479]: QTextCursor::setPosition: Position '-1' out of range
juil. 16 22:52:53 asgard gnome-keyring-daemon[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 16 22:52:53 asgard gnome-keyring-d[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 16 22:55:07 asgard gnome-keyring-daemon[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 16 22:55:07 asgard gnome-keyring-d[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 16 22:55:24 asgard kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
juil. 17 13:14:04 asgard kernel: queueing ieee80211 work while going to suspend
juil. 17 13:14:04 asgard kernel: mt7921e 0000:04:00.0: Message 00020007 (seq 3) timeout
juil. 17 13:14:04 asgard kernel: mt7921e 0000:04:00.0: PM: dpm_run_callback(): pci_pm_resume+0x0/0xf0 returns -110
juil. 17 13:14:04 asgard kernel: mt7921e 0000:04:00.0: PM: failed to resume async: error -110
juil. 17 13:14:04 asgard kernel: atkbd serio0: Spurious ACK on isa0060/serio0. Some program might be trying to access hardware directly.
juil. 17 13:14:04 asgard rtkit-daemon[1073]: The canary thread is apparently starving. Taking action.
juil. 17 13:14:04 asgard gdm[674]: GLib: Source ID 83 was not found when attempting to remove it
juil. 17 13:14:04 asgard gnome-shell[1998]: Could not release device '/dev/input/event17' (13,81): GDBus.Error:org.freedesktop.login1.DeviceNotTaken: Device not taken
juil. 17 13:14:05 asgard systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
juil. 17 13:14:05 asgard systemd[1]: Failed to start pkgfile database update.
juil. 17 13:14:06 asgard kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
juil. 17 13:14:07 asgard bluetoothd[619]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
juil. 17 13:16:36 asgard wpa_supplicant[1116]: bgscan simple: Failed to enable signal strength monitoring
juil. 17 13:19:03 asgard telegram-desktop[4479]: QTextCursor::setPosition: Position '8388607' out of range
juil. 17 13:21:45 asgard gnome-keyring-daemon[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 17 13:21:45 asgard gnome-keyring-d[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 17 13:43:56 asgard gnome-keyring-daemon[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 17 13:43:56 asgard gnome-keyring-d[1918]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
juil. 17 13:58:02 asgard kernel: nvidia 0000:01:00.0: can't suspend (nv_pmops_runtime_suspend [nvidia] returned -5)
juil. 17 14:13:28 asgard gnome-shell[1998]: Object St.Icon (0x55cc4c811620), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 17 14:13:28 asgard gnome-shell[1998]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55cc4c807c80), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 17 14:13:28 asgard gnome-shell[1998]: Object St.Icon (0x55cc4c8198f0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 17 14:13:28 asgard gnome-shell[1998]: Object St.Label (0x55cc4c8171c0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 17 14:13:28 asgard gnome-shell[1998]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
juil. 17 14:13:28 asgard gnome-shell[1998]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
juil. 17 14:13:28 asgard gnome-shell[1998]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
juil. 17 14:13:28 asgard gnome-shell[1998]: Object St.Label (0x55cc4c822ac0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 17 14:13:28 asgard gnome-shell[1998]: Object St.Label (0x55cc4c812a10), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 17 14:13:28 asgard gnome-shell[1998]: Object St.Label (0x55cc4c812a10), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
juil. 17 14:16:57 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:16:57 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:16:57 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:17:08 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:17:08 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:17:08 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:17:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:17:18 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:17:18 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:17:28 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:17:28 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:17:28 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:17:38 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:17:38 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:17:38 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:17:48 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:17:48 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:17:48 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:17:58 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:17:58 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:17:58 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:18:08 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:18:08 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:18:08 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:18:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:18:18 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:18:18 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:18:28 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:18:28 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:18:28 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:18:38 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:18:38 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:18:38 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:18:48 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:18:48 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:18:48 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:18:58 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:18:58 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:18:58 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:19:08 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:19:08 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:19:08 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:19:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:19:18 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:19:18 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:19:28 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:19:28 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:19:28 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:19:38 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:19:38 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:19:38 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:19:48 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:19:48 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:19:48 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:19:58 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:19:58 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:19:58 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:20:08 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:20:08 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:20:08 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:20:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:20:18 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:20:18 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:20:28 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:20:28 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:20:28 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:20:38 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:20:38 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:20:38 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:20:48 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:20:48 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:20:48 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:20:58 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:20:58 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:20:58 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:21:08 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:21:08 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:21:08 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:21:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:21:18 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:21:18 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:21:28 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:21:28 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:21:28 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:21:38 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:21:38 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:21:38 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:21:48 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:21:48 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:21:48 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:21:58 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:21:58 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:21:58 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:22:08 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:22:08 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:22:08 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:22:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:22:18 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:22:18 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:22:28 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:22:28 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:22:28 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:22:38 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:22:38 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:22:38 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:22:48 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:22:48 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:22:48 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:22:58 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:22:58 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:22:58 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:23:08 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:23:08 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:23:08 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:23:18 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:23:18 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:23:18 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:23:29 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:23:29 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:23:29 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:23:39 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:23:39 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:23:39 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:23:49 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:23:49 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:23:49 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:23:59 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:23:59 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:23:59 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:24:09 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:24:09 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:24:09 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:24:19 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:24:19 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:24:19 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:24:29 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:24:29 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:24:29 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:24:39 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:24:39 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:24:39 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:24:49 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:24:49 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:24:49 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:24:59 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:24:59 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:24:59 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:25:09 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:25:09 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:25:09 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:25:19 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:25:19 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:25:19 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:25:29 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:25:29 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:25:29 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:25:39 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:25:39 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:25:39 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:25:49 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:25:49 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:25:49 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:25:59 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:25:59 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:25:59 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:26:09 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:26:09 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:26:09 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:26:16 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_I._I._I._I._I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:26:16 asgard kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.AZAL._PS0 due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:26:16 asgard kernel: snd_hda_intel 0000:08:00.6: CORB reset timeout#2, CORBRP = 65535
juil. 17 14:26:17 asgard kernel: snd_hda_codec_realtek hdaudioC1D0: Unable to sync register 0x2b8000. -5
juil. 17 14:26:17 asgard pulseaudio[2138]: Failed to set switch of 'Speaker': Erreur d'entrée/sortie
juil. 17 14:26:17 asgard pulseaudio[2138]: Failed to set switch of 'Headphone': Erreur d'entrée/sortie
juil. 17 14:26:17 asgard pulseaudio[2138]: Failed to set volume of 'Internal Mic Boost': Erreur d'entrée/sortie
juil. 17 14:26:19 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:26:19 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:26:19 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:26:29 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:26:29 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:26:29 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:26:39 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:26:39 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:26:39 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:26:49 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:26:49 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:26:49 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:26:59 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:26:59 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:26:59 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:27:09 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:27:09 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:27:09 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:27:19 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:27:19 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:27:19 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:27:29 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:27:29 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:27:29 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:27:39 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:27:39 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:27:39 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:27:49 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:27:49 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:27:49 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:27:59 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:27:59 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:27:59 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:28:09 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:28:09 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:28:09 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:28:19 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:28:19 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:28:19 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:28:29 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:28:29 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:28:29 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:28:39 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:28:39 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:28:39 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:28:49 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:28:49 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:28:49 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:28:59 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:28:59 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:28:59 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:29:09 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:29:09 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:29:09 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:29:19 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:29:19 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:29:19 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:29:29 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:29:29 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:29:29 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:29:40 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:29:40 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:29:40 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:29:50 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:29:50 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:29:50 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:30:00 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:30:00 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:30:00 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:30:10 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:30:10 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:30:10 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:30:20 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:30:20 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:30:20 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:30:30 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:30:30 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:30:30 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:30:40 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:30:40 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:30:40 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:30:50 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:30:50 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:30:50 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:31:00 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:31:00 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:31:00 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:31:10 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:31:10 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:31:10 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:31:20 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:31:20 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:31:20 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:31:30 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:31:30 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:31:30 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:31:40 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:31:40 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:31:40 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:31:50 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:31:50 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:31:50 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:32:00 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:32:00 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:32:00 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:32:10 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:32:10 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:32:10 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:32:20 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:32:20 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:32:20 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:32:30 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:32:30 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:32:30 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:32:40 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:32:40 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:32:40 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:32:50 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:32:50 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:32:50 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:33:00 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:33:00 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:33:00 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:33:10 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:33:10 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:33:10 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:33:20 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:33:20 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:33:20 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:33:30 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:33:30 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:33:30 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:33:40 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:33:40 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:33:40 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:33:50 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:33:50 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:33:50 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:34:00 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:34:00 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:34:00 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:34:10 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:34:10 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:34:10 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:34:20 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:34:20 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:34:20 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:34:30 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:34:30 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:34:30 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:34:40 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:34:40 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:34:40 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:34:50 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:34:50 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:34:50 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:35:00 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:35:00 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:35:00 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:35:10 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:35:10 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:35:10 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:35:20 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:35:20 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:35:20 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:35:30 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:35:30 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:35:30 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:35:40 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:35:40 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:35:40 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:35:50 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:35:50 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:35:50 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:36:01 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:36:01 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:36:01 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:36:11 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:36:11 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:36:11 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:36:21 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:36:21 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:36:21 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:36:31 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:36:31 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:36:31 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:36:41 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:36:41 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:36:41 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:36:51 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:36:51 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:36:51 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:37:01 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:37:01 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:37:01 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:37:11 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:37:11 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:37:11 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:37:21 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:37:21 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:37:21 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:37:31 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:37:31 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:37:31 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:37:41 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:37:41 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:37:41 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:37:51 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:37:51 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:37:51 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:38:01 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:38:01 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:38:01 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:38:11 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:38:11 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:38:11 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:38:21 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:38:21 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:38:21 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:38:31 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:38:31 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:38:31 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:38:41 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:38:41 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:38:41 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:38:51 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:38:51 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:38:51 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:39:01 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:39:01 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:39:01 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:39:11 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:39:11 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:39:11 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:39:21 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:39:21 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:39:21 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:39:31 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:39:31 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:39:31 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:39:41 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:39:41 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:39:41 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:39:44 asgard gnome-shell[1998]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
juil. 17 14:39:51 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:39:51 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:39:51 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:7 pasid:32779, for process gnome-control-c pid 19674 thread gnome-cont:cs0 pid 19711)
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:   in page starting at address 0x000001944c3e9000 from client 0x1b (UTCL2)
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00700031
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          Faulty UTCL2 client ID: CB/DB (0x0)
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          MORE_FAULTS: 0x1
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          WALKER_ERROR: 0x0
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          PERMISSION_FAULTS: 0x3
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          MAPPING_ERROR: 0x0
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          RW: 0x0
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:   in page starting at address 0x000000e3895bf000 from client 0x1b (UTCL2)
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          MORE_FAULTS: 0x0
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:          PERMISSION_FAULTS: 0x0
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:   in page starting at address 0x00002de3895be000 from client 0x1b (UTCL2)
juil. 17 14:39:53 asgard kernel: amdgpu 0000:08:00.0: amdgpu:   in page starting at address 0x0000e8944c3e8000 from client 0x1b (UTCL2)
juil. 17 14:40:01 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:40:01 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:40:01 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6
juil. 17 14:40:04 asgard kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=165473, emitted seq=165475
juil. 17 14:40:04 asgard kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process gnome-control-c pid 19674 thread gnome-cont:cs0 pid 19711
juil. 17 14:40:05 asgard kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
juil. 17 14:40:11 asgard kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.TPM2._DSM.I], AE_NOT_FOUND (20230331/psargs-330)
juil. 17 14:40:11 asgard kernel: ACPI Error: Aborting method \_SB.TPM2._DSM due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
juil. 17 14:40:11 asgard kernel: tpm tpm0: tpm_try_transmit: send(): error -6```
Avec l'erreur du log, j'ai trouvé quelques info sur le wiki de arch , je vais tester ça dès que ça recommence pour voir l'effet.
J'ai trouvé aussi des discussions qui montre que visiblement ce souci est apparu il ya quelques années mais avait été visiblement résolu
i dont understand french…
you have there some amdgpu related logs, also some from nvidia, and a lot of those acpi errors…
post output from:
mhwd -l -li
ls /etc/modprobe.d
find /etc/X11/ -name "*.conf"
damn, sorry didn’t realize XD:
traduction :
here a complete log just after a gpu reboot.
I precise in the meantime , I tried using wayland, which seems stable , but not…
mhbd -li
           video-linux            2018.05.04                true            PCI
video-hybrid-amd-nvidia-prime            2023.03.23               false            PCI
ls /etc/modprobe.d                                         1 ✘
mhwd-gpu.conf
find /etc/X11/ -name "*.conf"                                ✔
/etc/X11/mhwd.d/nvidia.conf
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
try disabling tpm in bios, if you are not using it… probably will not help, but give it a try…
and these glitches dont happen when you are using nvidia?
no, when disabling integrated gpu (so only nvidia is working, I have absolutely no issue regarding the graphic and freeze.
Yeah I read some threads about TPM but I can’t find any related option in the bios.
edit: I’m trying something else, I changed integrated gpu memory allocated in the bios from 512 to 2g.
right now, it seem more stable. could it be simply memory full issue ?
Maybe … but it also reminds me of some buggy Caches…
for i in {Shader,GPU}; do find ~/.config -name *"$i"Cache*; done
You may try removing any of the directories that command prints.
(particularly those that pertain to your browser of course)
nothing found for ShaderCache or GPUCache
it could be because of that… if you no longer experience any issues, it was because of it…
@eephyne: I have the same 16ARX8 with NVIDIA 4070. Please also update your BIOS, mine is LPCN44WW while yours is LPCN25WW.
I am about to check Manjaro on that box as under Ubuntu/Linux Mint 21.2 with Kernel 6.2 I cannot suspend (as it immediately resumes) and also have some issues with WIFI mt7921e which sometimes gives kernel panic.
I fell less alone :slight_smile:
I have issue with sleep and mt7921e too but not exactly the same sa you do.
You saw difference after upgrading your bios ?
you can watch Bluetooth is not AutoEnabled - #10 by koshikas for my issue with the mt7921e card if you want.
For the sleep , it don’t wakeup instantly like you but sometime I can’t wakeup at all, and its very long to wakeup from sleep (deep or s2idle) (about 10 seconds).
edit : just updated my bios (using windows), didn’t think it was going to erase bios settings and reset efi partition
glitches still happen.
I’v checked the vram state and its not full (around 60-70%), so Its probably not related to an out of memory issue
