Hello
I have installed my new AMD RX 9070 and would like to see the performance with Manjaro. I have installed mesa from aur, games running only with one problem: No audio. Even if i play a video with VLC or use Firefox for youtube. Since I installed the AMD RX 9070 I have no audio. I’ve already testet it with Manjaro Live ISO → Same problem.
Do anyone knows where I should start to debug?
My system:
[lucarelli@lucarelli-ws ~]$ inxi -Fxxxzo
Kernel: 6.13.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASRock model: X670E PG Lightning
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 3.16 date: 12/18/2024
Info: 6-core model: AMD Ryzen 5 7600X bits: 64 type: MCP smt: <unsupported>
arch: Zen 4 rev: 2 cache: L1: 384 KiB L2: 6 MiB L3: 32 MiB
Speed (MHz): avg: 2988 min/max: 545/5453 boost: enabled cores: 1: 2988
2: 2988 3: 2988 4: 2988 5: 2988 6: 2988 bogomips: 56299
Device-1: Advanced Micro Devices [AMD/ATI] vendor: Sapphire driver: amdgpu
v: kernel pcie: speed: 32 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550
class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: xfwm4 v: 4.20.0 driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1017x318mm (40.04x12.52")
s-diag: 1066mm (41.95")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: Samsung S24E650 serial: <filter> res: mode: 1920x1200 hz: 60
scale: 100% (1) dpi: 94 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
modes: max: 1920x1200 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Samsung S24E650
serial: <filter> res: mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") modes: max: 1920x1200
min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 3.3 vendor: amd mesa v: 25.1.0-devel
gfx1201 ACO DRM 3.61 6.13.5-2-MANJARO) device-ID: 1002:7550
API: Vulkan v: 1.4.304 layers: 9 surfaces: xcb,xlib device: 0
type: discrete-gpu driver: N/A device-ID: 1002:7550
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
gpu: amdgpu_top, corectrl, lact, radeontop x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel
pcie: speed: 32 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab40
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
lanes: 16 bus-ID: 19:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.5-2-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.7 status: off
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0 chip-ID: 10ec:8125
class-ID: 0200
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.6 TiB used: 528.52 GiB (32.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-3: /dev/sdb vendor: Samsung model: SSD 830 Series size: 238.47 GiB
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B1Q scheme: GPT
ID-1: / size: 915.33 GiB used: 330.42 GiB (36.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 300 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 48.1 C mobo: 31.5 C gpu: amdgpu temp: 35.0 C
mem: 58.0 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.93 GiB used: 2.6 GiB (8.4%)
Processes: 315 Power: uptime: 1m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 257 default: graphical
Packages: 1744 pm: pacman pkgs: 1740 pm: flatpak pkgs: 4 Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.37
aplay -l
[lucarelli@lucarelli-ws ~]$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: Generic [HD-Audio Generic], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: Generic [HD-Audio Generic], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 0: ALC897 Analog [ALC897 Analog]
Subdevices: 0/1
Note: In volume control the devices shows correclty and I see a graph who indicates that some audio are playing.
edit: updated inxi output
