Hi there!
I recently got myself a AMD Radeon RX Vega 64 with 8GB of vRAM replacing my old graphics card which just had 2GB of vRAM. But interestingly enough I have now encountered extreme stuttering when trying to play Phasmaphobia which worked flawlessly on my card before. The stuttering seems to occur everytime something new is loaded into the memory, making the game unplayable.
What could be the cause of this?
I am using the AMDGPU driver and have the video-linux
driver installed via mhwd
Output of inxi -Fnzy
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5861
date: 08/10/2021
Info: 8-core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 2136 min/max: 2200/3800 cores: 1: 2191 2: 2189 3: 2195
4: 2196 5: 2152 6: 1884 7: 2200 8: 2095 9: 2196 10: 2200 11: 2196 12: 2147
13: 2060 14: 2200 15: 2200 16: 1886
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] driver: amdgpu v: kernel
Display: x11 server: X.org v: 1.21.1.8 driver: X: loaded: amdgpu
unloaded: modesetting dri: radeonsi gpu: amdgpu resolution: 1: 1920x1080~60Hz
2: 1680x1050~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
renderer: AMD Radeon RX Vega (vega10 LLVM 16.0.6 DRM 3.54 6.5.5-1-MANJARO)
API: Vulkan v: 1.3.264 drivers: amd surfaces: xcb,xlib
Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
Device-3: C-Media TONOR TC-777 Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: Intel I211 Gigabit Network driver: igb
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] driver: rtw_8822bu
type: USB
IF: wlp12s0f3u1 state: down mac: <filter>
Local Storage: total: 2.05 TiB used: 139.64 GiB (6.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
ID-3: /dev/sda model: SATA SSD size: 238.47 GiB
ID-1: / size: 881.69 GiB used: 139.64 GiB (15.8%) fs: ext4
dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme1n1p1
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
dev: /dev/nvme1n1p3
System Temperatures: cpu: 38.1 C mobo: 42.0 C gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): cpu: 0 case-1: 0 case-2: 0 case-3: 0 gpu: amdgpu
fan: 1439
Processes: 383 Uptime: 21m Memory: total: 32 GiB available: 31.25 GiB
used: 4.54 GiB (14.5%) Shell: Bash inxi: 3.3.30
