Prior to the installation of the new Radeon RX 6800 I used the Ryzen-internal Graphics which worked fine.
After switching to the dedicated graphics card I have problems with the left (not main) monitor. Both displays are LG 4k displays connected with display port.
Windows on the left screen are having a strange font problem, the letter spacing is to low and it’s hard to read. If I drag the window from one screen to the other the letter spacing changes and Konsole even tells me that the window resizes.
Furthermore I had to create full screen screenshots and crop the Konsole windows because Spectacle made the screenshots in different resolution and position as selected.
I have added screenshots for both displays:
$ mhwd -li INT ✘
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
$inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 5.18.19-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=bba5403b-fdfb-4da7-8419-a1c6d3090ddb rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: Pro B550M-C v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 2423 date: 08/09/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
status: discharging
RAM: total: 31.15 GiB used: 6.51 GiB (20.9%)
Info: model: AMD Ryzen 7 PRO 5750G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 2454 high: 2994 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1811 2: 2395
3: 2394 4: 2392 5: 2992 6: 2391 7: 2395 8: 2394 9: 2994 10: 2394 11: 2395
12: 2395 13: 2654 14: 2394 15: 2488 16: 2395 bogomips: 121422
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73bf
class-ID: 0300
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1.4:4 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2030x571mm (79.92x22.48")
s-diag: 2109mm (83.02")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: LG (GoldStar) Ultra HD serial: <filter> built: 2017 res: 3840x2160
hz: 60 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-3 mapped: DisplayPort-2 pos: left model: LG (GoldStar) HDR 4K
serial: <filter> built: 2021 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon RX 6800 (navi21 LLVM
14.0.6 DRM 3.46 5.18.19-3-MANJARO) direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-2.1:4 pcie: chip-ID: 0b0e:24c7 gen: 4 class-ID: 0300 speed: 16 GT/s
lanes: 16 serial: <filter> bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A
link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: GN Netcom Jabra Link 380 type: USB
driver: jabra,snd-usb-audio,usbhid
Device-5: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
Device-6: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 0c76:161e
class-ID: 0300
Sound API: ALSA v: k5.18.19-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-227ef181c400 state: down mac: <filter>
IF-ID-2: br-9fa0851334f5 state: down mac: <filter>
IF-ID-3: br-cd6e775ba814 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8 bus-ID: 5-2:3
chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 2.69 TiB used: 1.43 TiB (53.1%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37960G
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61F1 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.43 TiB (79.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: bba5403b-fdfb-4da7-8419-a1c6d3090ddb
label: NO_LABEL uuid: 8EA5-52BD
ID-1: /dev/sda1 maj-min: 8:1 size: 894.25 GiB fs: ext4 label: N/A
uuid: 9a60b75a-a6bb-43e5-a6f2-146912ae44bf
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Cambridge Silicon Radio ports: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:4010 class-ID: 0900
Device-1: 1-2.1:4 info: GN Netcom Jabra Link 380 type: Audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
chip-ID: 0b0e:24c7 class-ID: 0300 serial: <filter>
Device-2: 1-8:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 3-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2812 class-ID: 0900
Device-1: 3-1.3:3 info: Logitech Illuminated Keyboard type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c318 class-ID: 0300
Device-2: 3-1.4:4 info: ARC Camera type: Video,Audio
power: 500mA chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0812 class-ID: 0900
Hub-8: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:161e class-ID: 0300
Device-2: 5-2:3 info: TP-Link UB500 Adapter type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 2357:0604
Hub-9: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
mem: 44.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 389 Uptime: 37m wakeups: 2 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1877
pm: pacman pkgs: 1872 libs: 484 tools: pamac,trizen pm: snap pkgs: 5
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
