Hello,
I’m new to Linux and coming from a decade of using Apple.
Since two days I search the forums and look for similar problems and try to solve my issue with my second monitor. It actually is a Beamer connected to the HDMI out of my AMD Radeon RX 580.
I have my primary display connected via DisplayPort and the second on the HDMI output.
In the native Display Settings the second Display is seen, but cannot be activated. Also it seems like it’s loosing the connection every couple of seconds. Here is a video showing how it looks like in the settings.
I switched to mesa-git driver and also tried the experimentel Kernel 5.17, but still cannot activate the display.
The following system information was requested in similar threads, so I will post them here as well.
Drivers:
[lzee@abc ~]$ mhwd -la
> All PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-470xx 2021.12.18 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.12.18 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-nvidia-390xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-s3 2020.01.18 true PCI
video-vesa 2017.03.12 true PCI
video-sisusb 2020.01.18 true PCI
video-voodoo 2017.03.12 true PCI
video-hybrid-amd-nvidia-470xx-prime 2021.12.18 false PCI
video-virtualmachine 2021.07.26 true PCI
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
video-openchrome 2020.01.18 true PCI
video-rendition 2020.01.18 true PCI
network-broadcom-wl 2018.10.07 false PCI
network-slmodem 2013.12.07 true PCI
network-rt3562sta 2013.12.07 true PCI
network-r8168 2016.04.20 true PCI
Warning: No USB configs found!
General System (stripped for graphic relevant device):
[lzee@abc ~]$ lspci -k
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] (rev e7)
Subsystem: Tul Corporation / PowerColor Radeon RX 580
Kernel driver in use: amdgpu
Kernel modules: amdgpu
xrandr output
[lzee@abc ~]$ xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x59 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 6 outputs: 5 associated providers: 0 name:AMD Radeon RX 580 Series @ pci:0000:01:00.0
[lzee@abc ~]$ inxi -Fxxxz
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Acidanthera product: iMac20,1 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-XXX
Mobo: Acidanthera model: Mac-XXX v: iMac20,1
serial: <superuser required> UEFI: Acidanthera v: 1715.40.15.0.0
date: 10/03/2021
Info: 8-core model: Intel Core i7-10700K bits: 64 type: MT MCP smt: enabled
arch: Comet Lake rev: 5 cache: L1: 512 KiB L2: 2 MiB L3: 16 MiB
Speed (MHz): avg: 1348 high: 4035 min/max: 800/5100 cores: 1: 851 2: 1200
3: 907 4: 1579 5: 3320 6: 4035 7: 800 8: 800 9: 1149 10: 1055 11: 1200
12: 1155 13: 1130 14: 800 15: 800 16: 800 bogomips: 121639
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Tul driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-5:3 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: 5120x1440~120Hz s-dpi: 96
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 13.0.1 DRM
3.42 5.15.21-1-MANJARO)
v: 4.6 Mesa 22.1.0-devel (git-4ed9fd62c9) direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Tul driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 6.14 TiB used: 14.95 GiB (0.2%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HDS724040ALE640
size: 3.64 TiB speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: A580 scheme: GPT
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdc vendor: Western Digital model: WD20EZRX-00D8PB0
size: 1.82 TiB speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-4: /dev/sdd vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 043 scheme: GPT
ID-1: / size: 457.09 GiB used: 14.95 GiB (3.3%) fs: ext4 dev: /dev/sdd2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sdd1
System Temperatures: cpu: 38.0 C pch: 42.0 C mobo: 16.8 C gpu: amdgpu
temp: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1162
Processes: 390 Uptime: 1h 1m wakeups: 0 Memory: 31.27 GiB
used: 5.18 GiB (16.6%) Init: systemd v: 250 Compilers: gcc: 11.1.0
clang: 13.0.1 Packages: pacman: 1121 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.12
Would be nice to get some help, as I would really like to make the switch.
Thanks!
Mark
Edit:
I tried this:
[lzee@abc ~]$ xrandr | grep " connected " | awk '{ print$1 }'
DisplayPort-1
HDMI-A-0
[lzee@abc ~]$ xrandr --output HDMI-A-0 --mode 1920x1080
xrandr: Configure crtc 1 failed
[lzee@abc ~]$ xrandr --verbose --output HDMI-A-0 --mode 1920x1080
screen 0: 5120x1440 1354x381 mm 96.00dpi
crtc 1: 1920x1080 60.00 +0+0 "HDMI-A-0"
crtc 0: disable
crtc 1: disable
crtc 2: disable
crtc 3: disable
crtc 4: disable
crtc 5: disable
screen 0: revert
crtc 0: revert
crtc 1: revert
crtc 2: revert
crtc 3: revert
crtc 4: revert
crtc 5: revert
Also tried other ports now, I got an adapter from HDMI to DisplayPort. They work individually, but not when connected together.
And I tried this: GitHub - geyslan/xrasengan: An xrandr wrapper to make your multi-monitor setup easier
[lzee@abc ~]$ xrasengan -f -on DisplayPort-2 --crtc 2
/usr/bin/xrandr: Configure crtc 1 failed
And I testet all variations from crtc 1 to crtc 5, no luck.
