Hello there!
I recently did a complete system update because my Amd Radeon 5700 XT had been crashing regularly before kernel 5.8 and its performance has been very low ever since (~130 average fps in CS:GO, ~4000-12000 glmark2 score, no smooth video streaming).
Are there common ways to start debugging issues that could be related to this?
System information
❯ inxi -Fxxx
System: Host: zill Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2 tk: Gtk 3.24.20
info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: Z270 Pro4 serial: <superuser/root required> UEFI: American Megatrends v: P2.70
date: 03/16/2018
CPU: Topology: Quad Core model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 67224
Speed: 930 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 1860 2: 1947 3: 1689 4: 1988 5: 1768 6: 1972 7: 1683
8: 2046
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: ASUSTeK
driver: amdgpu v: kernel bus ID: 03:00.0 chip ID: 1002:731f
Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: vfio-pci v: 0.2 bus ID: 06:00.0
chip ID: 10de:1c03
Display: x11 server: X.Org 1.20.8 driver: amdgpu resolution: 1: 1920x1080 2: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.38.0 5.8.6-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.7
direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:ab38
Device-3: NVIDIA GP106 High Definition Audio vendor: ASUSTeK driver: vfio-pci v: 0.2 bus ID: 06:00.1
chip ID: 10de:10f1
Device-4: Logitech Logitech G633 Gaming Headset type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-9:4
chip ID: 046d:0a5c serial: 00000000
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: 3.2.6-k port: f000 bus ID: 00:1f.6
chip ID: 8086:15b8
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: 70:85:c2:50:33:b7
IF-ID-1: virbr0 state: down mac: 52:54:00:88:12:3f
IF-ID-2: virbr0-nic state: down mac: 52:54:00:88:12:3f
Drives: Local Storage: total: 3.75 TiB used: 1.17 TiB (31.2%)
ID-1: /dev/sda vendor: Toshiba model: HDWD130 size: 2.73 TiB speed: 6.0 Gb/s rotation: 7200 rpm serial: 78BWD5TAS
rev: ACF0 scheme: GPT
ID-2: /dev/sdb vendor: SanDisk model: SDSSDP128G size: 117.38 GiB speed: 6.0 Gb/s serial: 140710405777 scheme: GPT
ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s serial: S2RFNX0J126430R
rev: 2B6Q scheme: GPT
Partition: ID-1: / size: 80.84 GiB used: 62.58 GiB (77.4%) fs: ext4 dev: /dev/sdb2
Swap: ID-1: swap-1 type: partition size: 34.44 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3
Sensors: System Temperatures: cpu: 74.0 C mobo: 37.0 C gpu: amdgpu temp: 62 C
Fan Speeds (RPM): fan-1: 0 fan-2: 2064 fan-3: 0 fan-4: 0 fan-5: 0 gpu: amdgpu fan: 995
Voltages: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.18
Info: Processes: 306 Uptime: 17m Memory: 31.33 GiB used: 3.41 GiB (10.9%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1330 Shell: Zsh v: 5.8 running in: xfce4-terminal inxi: 3.1.05
I have also set the grub parameters amdgpu.noretry=0
and amdgpu.gpu_recovery=1
Any help would be greatly appreciated!
