AMD/Nvidia hybrid user needs help regarding display driver
Hi, I just completely switched from windows and have been using linux manjaro for a week, been playing dota for a week but have been getting below 20-50 FPS on lowest quality as I am using my built-in AMD Vega 8 GPU.
I tried installing nvidia-390xx from mhwd, but lightdm will always fail to start and I have to uninstall nvidia-390xx again to be able to get into DE.
Here is my inxi -Fxza --no-host:
  Kernel: 5.4.85-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=cf402b89-fabe-4ac9-9cba-6dd92e3e833a rw quiet
  acpi_backlight=none apparmor=1 security=apparmor
  resume=UUID=fcca9233-f193-40a8-acd8-e49937320513 udev.log_priority=3
  Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X570ZD_F570ZD
  v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: X570ZD v: 1.0 serial: <filter>
  UEFI: American Megatrends v: X570ZD.310 date: 07/04/2019
  ID-1: BAT0 charge: 41.3 Wh condition: 41.3/48.1 Wh (86%) volts: 11.7/11.7
  model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
  cycles: 173
  Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
  stepping: N/A microcode: 810100B L2 cache: 2 MiB
  bogomips: 31948
  Speed: 1370 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
  1: 1370 2: 1413 3: 1394 4: 1371 5: 1457 6: 1594 7: 1369 8: 1379
  disabled, RSB filling
  Device-1: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
  driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1c8d
  Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
  vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 04:00.0
  chip ID: 1002:15dd
  Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
  bus ID: 3-2.2:7 chip ID: 13d3:5a05 serial: <filter>
  Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati,nouveau
  unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.35.0
  5.4.85-1-MANJARO LLVM 11.0.0)
  v: 4.6 Mesa 20.3.1 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
  v: kernel bus ID: 04:00.1 chip ID: 1002:15de
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
  Device-3: C-Media SADES Wolfang type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-4:4 chip ID: 0d8c:0012
  Sound Server: ALSA v: k5.4.85-1-MANJARO
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f000
  bus ID: 02:00.0 chip ID: 8086:24fd
  vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: e000
  bus ID: 03:00.0 chip ID: 10ec:8168
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 238.47 GiB used: 65.48 GiB (27.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: V-Gen model: 07SM20AR256SDK 256GB
  size: 238.47 GiB block size: physical: 512 B logical: 512 B
  speed: 6.0 Gb/s serial: <filter> rev: 7B0
  ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%)
  used: 65.48 GiB (29.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 54.4 C mobo: N/A
  Fan Speeds (RPM): cpu: 2600
  GPU: device: amdgpu temp: 54.0 C device: nouveau temp: 40.0 C
  Processes: 226 Uptime: 34m wakeups: 1 Memory: 6.8 GiB
  used: 2.19 GiB (32.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  Packages: 1170 pacman: 1160 lib: 371 flatpak: 7 snap: 3 Shell: Bash
  v: 5.1.0 running in: xfce4-terminal inxi: 3.2.01
and my mhwd -li:
         network-r8168            2016.04.20                true            PCI
           video-linux            2018.05.04                true            PCI
I do not know how to make my Nvidia 1050 mobile GPU to be working, and needed help.
Do note also that my function keys for display brightness does not work and I need to right-click my battery manager to change my brightness.
Any sort of help is appreciated, Thanks!
Hi!
For that gpu combo you need the amd/nvidia hybrid drivers, i have the same laptop and works just fine with those drivers
To check what drivers are available
mhwd -l
Then install as suggested above the appropriate hybrid profile it should setup it properly. Maybe simply using the automatic install should also work:
sudo mhwd -a pci nonfree 0300
You probably need to reinstall mhwd-db, this should work:
sudo pacman -S mhwd-db
Alright, I am able to install my drivers with no problems, and lightdm works just fine using:
Finally my GPU is able to work well, thanks for the replies all!
