Thanks everyone for giving me new input, I really appreciate your support!
I seem to have both mhwd-nvidia 570.133.07-2 and nvidia-550xx-dkms 550.144.03-1 on my system. Installing prime-run via sudo pacman -S nvidia-prime worked out fine. Running DaVinci Resolve with prime-run succesfully starts the program, but it crashes due to being unable to use the nvidia GPU:
GPU Initialization Failed
DaVinci Resolve could not initialize OpenGL. Please ensure that the latest graphics drivers are installed
Since the 550xx driver and utils doesn’t seem to function I removed them and instead installed the newest drivers supporting the prime-run function: Successfully installed video-hybrid-amd-nvidia-prime:
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
video-hybrid-amd-nvidia-prime 2025.01.13 false PCI
I ran sudo reboot and tested if the driver was initialized successfully:
nvidia-smi
No devices were found
@soundofthunder Thanks for pointing this out - I lost the snippet in the process of resetting my system to a fresh installation and will take precautions to avoid that in the future. I made sure to look into threads with similar issues and the Stable Update 2025-03-24 from where I got my first basic knowledge as a complete beginner with Linux. Unfortunately after a week of troubleshooting I wasn’t able to resolve the issue on my own which led me here.
Updated system info as suggested by soundofthunder:
inxi -zv8
Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a77c4fff-d627-4c1b-81ec-82548673cd36 rw quiet splash
resume=UUID=71acc1c3-ee22-4095-808a-a7374ec9de09 udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Mobo: ASUSTeK model: TUF GAMING B650-PLUS v: Rev 1.xx
UEFI: American Megatrends v: 1811 date: 10/07/2023
System RAM: total: 32 GiB available: 30.56 GiB used: 3.09 GiB (10.1%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX5M2E6000C36 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2982 min/max: 400/5050 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2982 2: 2982 3: 2982
4: 2982 5: 2982 6: 2982 7: 2982 8: 2982 9: 2982 10: 2982 11: 2982 12: 2982
13: 2982 14: 2982 15: 2982 16: 2982 bogomips: 134198
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1 empty: Writeback-1 bus-ID: 0c:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 40.0 C
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54") monitors: <missing: xrandr>
Monitor-1: DP-1 model: BenQ GL2780 serial: <filter> built: 2021
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.639 y: 0.337 green:
x: 0.314 y: 0.627 blue: x: 0.157 y: 0.055 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
640x480, 720x400
Monitor-2: HDMI-A-1 model: BenQ GL2780 serial: <filter> built: 2021
640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
raphael_mendocino LLVM 19.1.7 DRM 3.61 6.12.21-4-MANJARO)
device-ID: 1002:164e memory: 500 MiB unified: no
API: Vulkan v: 1.4.309 layers: 1 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 25.0.3-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib
wl: wayland-info x11: xdpyinfo,xprop
Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:1640
class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0c:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Swissonic UA-2X2 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 17c8:7002 class-ID: 0102
Device-5: SteelSeries ApS Arctis 7
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 1038:12ad class-ID: 0300
Device-6: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
Local Storage: total: 960.15 GiB used: 39.32 GiB (4.1%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra USB 3.0
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 46.57 GiB size: 45.53 GiB (97.78%) used: 31.59 GiB (69.4%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: a77c4fff-d627-4c1b-81ec-82548673cd36
ID-2: /boot/efi raw-size: 476.3 MiB size: 475.3 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 27B7-5ED2
ID-3: /home raw-size: 232.83 GiB size: 228.12 GiB (97.98%)
used: 7.72 GiB (3.4%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 05cd5584-e73a-4109-8a97-2315c9e598ad
ID-1: swap-1 type: partition size: 29.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 71acc1c3-ee22-4095-808a-a7374ec9de09
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 6095-5FCB
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 417.96 GiB fs: ntfs label: N/A
uuid: E44695F94695CCA4
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 662 MiB fs: ntfs label: N/A
uuid: A66C88D16C889DA5
ID-5: /dev/sda1 maj-min: 8:1 size: 4.03 GiB fs: iso9660
ID-6: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 97A3-D79B
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: SteelSeries ApS Rival 5 type: HID,mouse
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 200mA chip-ID: 1038:183c class-ID: 0300
Device-2: 1-7:3 info: SteelSeries ApS Apex 3 TKL type: keyboard,HID
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:1622 class-ID: 0300
Device-3: 1-11:4 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Device-1: 2-3:2 info: SanDisk Ultra Flair type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
serial: <filter>
Device-1: 3-1:2 info: Swissonic UA-2X2 type: HID,audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-1:2 info: SteelSeries ApS Arctis 7 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
Device-2: 5-2:3 info: Logitech C922 Pro Stream Webcam type: video,audio
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 63.6 C mobo: 35.5 C gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1218 libs: 332 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
2: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
3: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 368
1: cpu: 9.1% command: firefox pid: 1641 mem: 473.9 MiB (1.5%)
2: cpu: 3.1% command: firefox pid: 1938 mem: 390.6 MiB (1.2%)
3: cpu: 3.1% command: firefox pid: 1943 mem: 377.7 MiB (1.2%)
4: cpu: 3.0% command: firefox pid: 1946 mem: 297.0 MiB (0.9%)
5: cpu: 2.2% command: firefox pid: 1857 mem: 273.3 MiB (0.8%)
Memory top: 5 of 368
1: mem: 473.9 MiB (1.5%) command: firefox pid: 1641 cpu: 9.1%
2: mem: 390.6 MiB (1.2%) command: firefox pid: 1938 cpu: 3.1%
3: mem: 377.7 MiB (1.2%) command: firefox pid: 1943 cpu: 3.1%
4: mem: 347.9 MiB (1.1%) command: plasmashell pid: 1090 cpu: 1.4%
5: mem: 297.0 MiB (0.9%) command: firefox pid: 1946 cpu: 3.0%
Processes: 368 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.19 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.38
At this point I am really clueless on how to proceed. Any new idea is highly appreciated!
