Is it possible to install Manjaro 21.0 with an AMD 6700 XT?
More specifically, I keep getting stuck at install phase and yes I am a N00b.
Tried also pop_os and had no trouble installing it
Here is the output of inxi --admin --verbosity=7 --filter --no-host --width:
System: Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDEM_210 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1
Console: tty 2 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: N/A
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: N/A UEFI: American Megatrends LLC. v: F33f date: 03/23/2021
Memory: RAM: total: 15.64 GiB used: 876.9 MiB (5.5%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 8 GiB speed: 3600 MT/s type: DDR4 detail: synchronous unbuffered (unregistered)
bus-width: 64 bits total: 64 bits manufacturer: N/A part-no: CMW16GX4M2Z3600C18 serial: N/A
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 8 GiB speed: 3600 MT/s type: DDR4 detail: synchronous unbuffered (unregistered)
CPU: Info: 8-Core model: AMD Ryzen 7 3700X socket: AM4 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: N/A microcode: 8701021 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB bogomips: 115024
Speed: 3590 MHz min/max: 2200/3600 MHz base/boost: 3600/4400 boost: enabled volts: 1.1 V ext-clock: 100 MHz
Core speeds (MHz): 1: 3590 2: 2049 3: 2045 4: 2050 5: 2190 6: 2189 7: 2191 8: 2190 9: 2051 10: 2053 11: 2196
12: 2192 13: 2196 14: 2192 15: 3582 16: 2045
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr
fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep
sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 driver: N/A bus-ID: 0a:00.0 chip-ID: 1002:73df class-ID: 0300
Display: server: X.org 1.20.10 driver: loaded: N/A note: n/a (using device driver) tty: 128x48
Message: Advanced graphics data unavailable in console for root.
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Musical Fidelity V-DAC II type: USB driver: snd-usb-audio bus-ID: 5-2:3 chip-ID: 4d46:0002
class-ID: 0102
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.23 running: no
Network: Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel port: f000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Bluetooth: Message: No Bluetooth data was found.
Logical: Message: No LVM data was found.
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 4.38 TiB used: 65.4 MiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: S0118C temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 354d 5h cycles: 1,005 read-units: 10,439,337 [5.34 TB]
written-units: 27,175,500 [13.9 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD40EZRZ-00GXCB0 family: Blue size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 0A80 temp: 28 C
SMART: yes state: enabled health: PASSED on: 250d 22h cycles: 703
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDS240G2G0B-00EPW0 family: WD Blue / Red / Green SSDs
size: 223.58 GiB block-size: physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 0000 temp: 43 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 18d 23h cycles: 300
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.82 GiB block-size:
physical: 512 B logical: 512 B serial: <filter> scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.86 GiB block-size:
physical: 512 B logical: 512 B serial: <filter> rev: PMAP
Partition: ID-1: /mnt raw-size: 28.86 GiB size: 28.86 GiB (100.00%) used: 65.4 MiB (0.2%) fs: ntfs block-size: 4096 B
dev: /dev/sdd maj-min: 8:48 label: N/A uuid: 130D547C4575EB2E
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A uuid: D8BB-66BF
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 7.81 GiB fs: swap label: N/A uuid: 489e0f54-ba07-4d2d-aaeb-057c3bb1937d
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 48.83 GiB fs: ext4 label: N/A
uuid: 79f37346-03e7-4bdb-be61-99ae81b0fd93
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 419.8 GiB fs: ext4 label: N/A
uuid: 4ec7fc6a-455d-4e92-bfa4-9d364e400d1b
ID-5: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A uuid: 167A-16A3
ID-6: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-7: /dev/sdb3 maj-min: 8:19 size: 222.97 GiB fs: ntfs label: N/A uuid: 7842860F4285D274
ID-8: /dev/sdb4 maj-min: 8:20 size: 506 MiB fs: ntfs label: N/A uuid: 96FACADDFACAB92F
ID-9: /dev/sdc1 maj-min: 8:33 size: 2.19 GiB fs: iso9660 label: MANJARO_KDEM_210 uuid: 2021-03-18-18-58-22-00
ID-10: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI uuid: ECDD-5890
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 05e3:0608
Device-1: 1-3.3:4 info: Corsair CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b49 class-ID: 0300
serial: <filter>
Device-2: 1-4:3 info: Integrated Express IT8297 RGB LED Controller type: Keyboard driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Device-3: 1-5:5 info: Xiaomi Mi/Redmi series (MTP) type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 2717:ff40 class-ID: 0000 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-5: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 05e3:0608
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 4-3:3 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 504mA chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Device-2: 4-4:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 296mA chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 5-1:2 info: Kingsis ZOWIE Gaming mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1af3:0001 class-ID: 0301
Device-2: 5-2:3 info: Musical Fidelity V-DAC II type: Audio driver: snd-usb-audio interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 4d46:0002 class-ID: 0102
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 35.9 C mobo: 16.8 C
Info: Processes: 265 Uptime: 13m wakeups: 0 Init: systemd v: 247 tool: systemctl Compilers: gcc: N/A Packages:
pacman: 1063 lib: 288 Shell: Bash (su) v: 5.1.0 running-in: tty 2 inxi: 3.3.03
Thanks for the response.
I have no idea how to get the output for cmd inxi --admin --verbosity=7 --filter --no-host --width from the tty.
I can try to cat it to a file, but typing it all out would be somewhat painstaking.
The problem is with the new 6700xt and the gpu driver not loading.
Thanks again
class-ID: 0403
class-ID: 0102
serial: <filter>
pacman: 1063 lib: 288 Shell: Bash (su) v: 5.1.0 running-in: tty 2 inxi: 3.3.03 ```
I’m not an expert, but I had the same problem with my 5600XT. According to the above line from inxi it doesn’t look like the amdgpu driver is loaded.
Try this, edit your /etc/mkinitcpio.conf file to add ‘amdgpu radeon’ to the modules section. Then run sudo mkinitcpio -P to rebuild your modules.
Fabby
1 April 2021 20:52
8
OP doesn’t have anything installed yet. He/she’s just booting the ISO…
Hey, I’m not sure if this helps, but I am having the EXACT same problem with my Manjaro install. I have Manjaro KDE installed as of now. The problem started a couple of nights ago, the input on my machine would work fine for a few moments, then the screen would go black… first time this happened it took me an hour of rebooting to fix. Happened again today. I booted from USB on Manjaro KDE, and it had the same problem. When booting from Linux mint XFCE from USB, the problem did not persist, and it booted into the desktop environment like a breeze. Hope my input helps! I am currently trying to figure out what to do about this myself…
CPU: Quad Core AMD Ryzen 3 2200G with Radeon Vega Graphics
Hmmmm, in that case I’d modify the bootparam’s to include nomodeset on the line starting with linux.
nomodeset did not help, the installation stops at [OK] reached target graphical interface
I have no problems with pop_os, they updated the driver for the new radeons. OS was using llvmpipe driver before
Update on my install, i let it sit for an hour or so, came back and it magically works fine? not sure why haha… but it sent me to the login screen which is a pleasant surprise. this is a really odd issue though, I hope your issue kets resolved @Kesto-v
Tried Release 202104040259 , but the same issue remains
gfunk
20 April 2021 08:46
15
sorry it’s not related to the core issue but just to note, I purchased a 6700XT and
LightDM failed to start, i uncommented a line about waiting for graphical interface
in /etc/lightdm/lightdm.conf you uncomment
#logind-check-graphical=false
There were green and black artifacts on the screen, I was on Mesa 21.0.1(stable) switched to mesa-git(21.2) and everything is working now, except some OpenCL stuff.
more info about LightDM here:
https://bbs.archlinux.org/viewtopic.php?id=264462
I presume you uncommented the line in grub? What did you change so I can also try that
Thanks
gfunk
21 April 2021 23:22
17
updated my post with more info
Bless you, this fixed the graphical glitching on the desktop for me as well.
Thanks to everyone who answered.
I got it finally working. I have been using ubuntu on for a while now, but missed Manjaros arch with ease. I used “brute force” and first installed Manjaro with a older GPU from another PC. Then updated the kernel to: 5.12.0-1. Then switched back to 6700 XT and this is the first post with this setup under Manjaro. I also did the edit for mkninitcpio
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 1: 2560x1440~165Hz 2: 1080x1920~60Hz
OpenGL: renderer: AMD NAVY_FLOUNDER (DRM 3.40.0 5.12.0-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3
