I was trying to install manjaro for a while until i found out the root of my issue was my GPU, because when i took it out and used the iGPU on my CPU it works fine, but as soon as i put it back in my installation doesn’t boot, it works fine on windows. Do i just need to update my drivers or something for it to work?
CPU: Ryzen 5 3400g
GPU: Radeon rx 570
Kernel 5.9
Post install
You haven’t really given us any info to work off of.
What GPU? What CPU? What Kernel? Is this during the Manjaro LiveISO? Is this post install? Did it work before? Etc etc.
Sorry.
GPU: Radeon rx 570
CPU: Ryzen 5 3400g
Kernel 5.9
Post install, but it always crashed when trying to boot live ISO, until i removed it
I was recently trying to install Manjaro on my pc using the live USB media, but it had always crashed and would go black after a while
I found that the root issue was my GPU (Radeon Rx 570), when i removed the card and used the iGPU on my CPU (Ryzen 5 3400G) everything worked fine. But I don’t want to have to remove my GPU just to run it on my system.
what should i do?
I can provide more details if needed
CPU: Ryzen 5 3400G
GPU :Radeon Rx 570
Kernel 5.9 (but i have tried lower kernel’s such as 5.4)
Pre and post install
Strit
5 February 2021 13:19
5
You can try disabling the iGPU from the BIOS, to be certain only the dGPU is being used.
there is no option for that when the dGPU is plugged in, i can change where the output comes from (card or onboard) and the default is set to the card and i have tried the onboard output but it still does not show anything on boot
I found that the root issue was my GPU, when I removed the card and used the iGPU on my CPU everything worked fine. But I don’t want to have to remove my GPU just to run it on my system.
I think its a driver issue but I don’t know how I would go about fixing it
iGPU: Vega 11
dGPU :Radeon Rx 570
Pre and post install```
Hanzel
8 February 2021 16:57
8
Hi, to get more input on your problem from users they would probably like to see the output of these commands:
$ inxi -Fazy
$ mhwd --listinstalled
Post the output in this format for easy reading
paste console output here
Ok, ill try this when i get a chance
For the inxi -Fazy and mhwd --listinstalled
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=677d2fb0-9ad3-4bb3-a3e8-3bcf40fe07e6 ro quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F40 date: 05/16/2019
Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 L2 cache: 2 MiB
bogomips: 59112
Speed: 1258 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz):
1: 1258 2: 1258 3: 1258 4: 1374 5: 1310 6: 1258 7: 1258 8: 1316
disabled, RSB filling
Device-1: AMD Picasso driver: amdgpu v: kernel bus ID: 06:00.0
chip ID: 1002:15d8
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.39.0
5.9.16-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus ID: 06:00.1 chip ID: 1002:15de
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 06:00.6 chip ID: 1022:15e3
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo bus ID: 3-4:4
chip ID: 05a3:9331 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.36 TiB used: 42.13 GiB (3.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
size: 223.57 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 04RL
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: CC43
ID-3: /dev/sdc maj-min: 8:32 vendor: KingDian model: N480 240GB
serial: <filter> rev: 7A
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Lexar model: USB Flash Drive
size: 14.56 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 0250
ID-1: / raw size: 250 GiB size: 245.07 GiB (98.03%) used: 42.11 GiB (17.2%)
fs: ext4 dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
System Temperatures: cpu: 40.2 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 263 Uptime: 9m wakeups: 1 Memory: 13.68 GiB
used: 1.68 GiB (12.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1329 pacman: 1313 lib: 407 flatpak: 9 snap: 7 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.2.02
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Have you tried Kernel 5.10 yet? 5.9 is EOL.
Is Manjaro installed by now? Or you still using a LiveISO?
Does this happen regardless of the LiveISO you used? Have you tried the others?
It’s strange because RX 570 should work out of the box. The GPU drivers are built into the kernel itself.
Manjaro has been installed but it only works with my iGPU not my main rx 570
i have not tried using 5.10
the liveISO always crashed no matter what i used and even on other distros such as ubuntu or mint, even solus
OK so i tried kernel 5.10 and its the same result only now it just shows “@^” in the corner of the screen and freezes
I am just going to come to the conclusion that my GPU is defective, as it only works on windows but not any other linux distro (i have tried several)
system
Closed
26 February 2021 22:36
15
