I cant use AMD DGPU. My laptop has hybrid GPU of Intel/AMD.
System Info:
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=21369c0f-bc2f-4c09-8f43-b82325d57ce7 rw quiet apparmor=1
security=apparmor udev.log_priority=3 radeon.cik_support=1 radeon.si_support=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.14.0
date: 01/13/2021
ID-1: BAT0 charge: 40.0 Wh (100.0%) condition: 40.0/41.4 Wh (96.4%) volts: 16.6
min: 14.8 model: LGC-LGC2.80 DELL 7PY0D0A type: Li-ion serial: <filter>
status: Full
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: DE cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
Speed: 3100 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3100 2: 3100 3: 3100
4: 3100
Type: l1tf
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520
Mobile]
vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 219.94 GiB (23.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: SDM3 scheme: GPT
ID-1: / raw-size: 120.12 GiB size: 117.67 GiB (97.97%) used: 9.81 GiB (8.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 288 KiB (0.1%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 810.89 GiB size: 797.09 GiB (98.30%)
used: 210.13 GiB (26.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 47.0 C mobo: 46.0 C gpu: radeon temp: 43.0 C
Fan Speeds (RPM): cpu: 2558
Processes: 174 Uptime: 12m wakeups: 1 Memory: 7.64 GiB used: 1.76 GiB (23.0%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 1271 lib: 351 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.04
AMD’s usage on Idle state:
AMD’s usage while playing steam games:
I have used the below commands in the launch option of the steam games:
On native games: (HOLLOW KNIGHT)
DRI_PRIME=1 %command%
and on games using Proton: (CUPHEAD and HADES)
DRI_PRIME=1 %command% PROTON_USE_WINED3D=1
several months earlier, with the help of above commands the games were running fine. and was running kernel 5.4
and I have tried kernel 5.4 and 5.10 as well nothing seems to solve the mentioned problem.
I also tried to launch other applications like GIMP, Inkscape with AMD, with command like:
DRI_PRIME=1 gimp
DRI_PRIME=1 inkscape
still no usage of AMD gpu.
afterwards I uninstalled gimp and inkscape.
I launched steam with DRI_PRIME=1, and launched the game no progress.
