I faced this problem earlier to, so went to windows and got back to manjaro. in earlier case my system would freez if i try to play steam games with amd gpu, but now system is not even using it no usage is shown,
playing in intel gpu causes gaming performence issue. I have tried several other distros too this problem persists there as well.
system info:
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=31d4e9d8-2a48-4723-8a01-7044aaeabdb8 rw quiet apparmor=1
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.29 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.14.0
date: 01/13/2021
ID-1: BAT0 charge: 40.0 Wh (100.0%) condition: 40.0/41.4 Wh (96.4%)
volts: 16.7 min: 14.8 model: LGC-LGC2.80 DELL 7PY0D0A type: Li-ion
serial: <filter> status: Full
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: DE cache: L2: 3 MiB
bogomips: 21607
Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,intel,radeon
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 196.01 GiB (21.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM3 scheme: GPT
ID-1: / raw-size: 120 GiB size: 117.56 GiB (97.97%) used: 9.82 GiB (8.4%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 811.01 GiB size: 797.21 GiB (98.30%)
used: 186.19 GiB (23.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 48.0 C mobo: 47.0 C gpu: radeon temp: 45.0 C
Fan Speeds (RPM): cpu: 0
Processes: 214 Uptime: 2h 21m wakeups: 1 Memory: 7.64 GiB
used: 2.89 GiB (37.8%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1287 lib: 322 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: gnome-terminal inxi: 3.3.04 ```
