AMD GPU Display freezing, soft lockup
Since installing Manjaro on my PC (few weeks), occasionally the display output will freeze. Sound continues to play for a few seconds until it stops aswell. Switching to other TTYs leads to no output at all and the Display going into sleep.
I have to REISUB to get any logs past freezing.
Those freezes happen unpredictably - sometimes within minutes, sometimes within hours, sometimes there are multiple days without freezes. I’m on Kernel 6.12.29 - I tried 6.14.7, same issue.
Before changing SDDM itself to Wayland, I was sometimes able to change to TTY2 (running SDDM) and regain display output - but only for this TTY, I was able to move the mouse cursor but not able to do anything else.
With SDDM under X11, the locked up CPU was CPU#0. Since I moved SDDM to Wayland, the locked up CPU is never CPU#0.
Every time it happened, the system didn’t do any intensive work. Most times only Firefox or Brave was open, sometimes a youtube video or twitch stream was running, one time I was playing Guild Wars 1 (20 year old game). I am now running the Display off my iGPU since I just had a freeze while writing this Topic.
I will disable LACT since it is sometimes mentioned in the logs before the freeze happens. (I used LACT for undervolting, the undervolt is stable in Windows. I already reverted the OC settings to default and disabled the OC capability in LACT as a troubleshooting step.)
I am unsure what to do to troubleshoot this issue further.
Manjaro Testing - happened on Stable aswell
KDE Plasma 6 (Wayland)
Kernel 6.12.29 LTS
Logs
Log-Lines that are present at time of freeze, consistent between freezes
May 26 15:08:08 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
May 26 15:08:23 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000029 SMN_C2PMSG_82:0x00000000
May 26 15:08:23 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Failed to disable gfxoff!
May 26 15:08:43 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=9949, emitted seq=9951
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process alacritty pid 3191 thread alacritty:cs0 pid 3194
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset failure
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
May 26 15:08:56 daniel-pc-manjaro kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 26s! [journalctl:3472]
Log-Lines that are sometimes present and worth mentioning
May 25 14:49:58 daniel-pc-manjaro kwin_wayland[1981]: kwin_wayland_drm: Pageflip timed out! This is a bug in the amdgpu kernel driver
May 25 14:49:58 daniel-pc-manjaro kwin_wayland[1981]: kwin_wayland_drm: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
May 25 14:49:58 daniel-pc-manjaro kwin_wayland[1981]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Due to character limitation I cannot post the links here, therefore I created pastebins. But I am not allowed to post links, so full logs are missing for now. I could put the links into codeblocks but don’t want to risk a ban in case that’s not allowed…
last freeze
May 26 15:01:02 daniel-pc-manjaro kernel: Linux version 6.14.7-1-MANJARO (linux614@manjaro) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Sun, 18 May 2025 07:38:33 +0000
May 26 15:01:02 daniel-pc-manjaro kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64 root=UUID=3bcde3f4-9600-421f-a623-2f1fe8351e26 rw rootflags=subvol=@ quiet splash udev.log_priority=3 pci=noaer
... boot logs removed due to character limit
May 26 15:01:08 daniel-pc-manjaro systemd[1600]: Startup finished in 145ms.
May 26 15:01:08 daniel-pc-manjaro sddm-helper-start-wayland[1679]: Starting Wayland process "kwin_wayland --drm --no-lockscreen --no-global-shortcuts --locale1" "sddm"
May 26 15:01:08 daniel-pc-manjaro sddm-helper-start-wayland[1679]: started succesfully "kwin_wayland --drm --no-lockscreen --no-global-shortcuts --locale1"
May 26 15:01:08 daniel-pc-manjaro sddm-helper-start-wayland[1679]: Directory "/run/user/959" has changed, checking for Wayland socket
May 26 15:01:08 daniel-pc-manjaro sddm-helper-start-wayland[1679]: Found Wayland socket "/run/user/959/wayland-0"
May 26 15:01:08 daniel-pc-manjaro systemd[1600]: Created slice User Core Session Slice.
May 26 15:01:08 daniel-pc-manjaro sddm-helper-start-wayland[1679]: "Accepting client connections on sockets: QList(\"wayland-0\")\n"
May 26 15:01:08 daniel-pc-manjaro systemd[1600]: Starting D-Bus User Message Bus...
May 26 15:01:08 daniel-pc-manjaro sddm-greeter-qt6[1684]: High-DPI autoscaling Enabled
May 26 15:01:08 daniel-pc-manjaro dbus-broker-launch[1685]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
May 26 15:01:08 daniel-pc-manjaro dbus-broker-launch[1685]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
May 26 15:01:08 daniel-pc-manjaro dbus-broker-launch[1685]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
May 26 15:01:08 daniel-pc-manjaro dbus-broker-launch[1685]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
May 26 15:01:08 daniel-pc-manjaro dbus-broker-launch[1685]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
May 26 15:01:08 daniel-pc-manjaro systemd[1600]: Started D-Bus User Message Bus.
May 26 15:01:08 daniel-pc-manjaro dbus-broker-launch[1685]: Ready
May 26 15:01:08 daniel-pc-manjaro tlp[1479]: Applying power save settings...done.
May 26 15:01:08 daniel-pc-manjaro tlp[1479]: Setting battery charge thresholds...done.
May 26 15:01:08 daniel-pc-manjaro systemd[1]: Finished TLP system startup/shutdown.
May 26 15:01:08 daniel-pc-manjaro systemd[1]: Startup finished in 14.440s (firmware) + 5.623s (loader) + 7.536s (kernel) + 6.922s (userspace) = 34.523s.
May 26 15:01:08 daniel-pc-manjaro systemd[1]: systemd-rfkill.service: Deactivated successfully.
May 26 15:01:09 daniel-pc-manjaro systemd[1]: Starting Locale Service...
May 26 15:01:09 daniel-pc-manjaro systemd[1]: Started Locale Service.
May 26 15:01:09 daniel-pc-manjaro sddm-helper-start-wayland[1679]: "kwin_xkbcommon: XKB: [XKB-489] us:825:72: numeric keysym \"0x1002039\" (16785465)\nkwin_xkbcommon: XKB: [XKB-489] us:826:72: numeric keysym \"0x100203a\" (16785466)\nkwin_xkbcommon: XKB: [XKB-489] us:831:72: numeric keysym \"0x1001e9e\" (16785054)\n"
May 26 15:01:09 daniel-pc-manjaro sddm-helper-start-wayland[1679]: "kwin_xkbcommon: XKB: [XKB-489] us:898:81: numeric keysym \"0x1002039\" (16785465)\nkwin_xkbcommon: XKB: [XKB-489] us:906:81: numeric keysym \"0x100203a\" (16785466)\n"
May 26 15:01:09 daniel-pc-manjaro sddm-helper-start-wayland[1679]: "kwin_xkbcommon: XKB: Multiple definitions of group 0 name in map 'altgr-intl'; Using 'English (intl., with AltGr dead keys)', ignoring 'English (US, intl., with dead keys)'\n"
May 26 15:01:09 daniel-pc-manjaro sddm-helper-start-wayland[1679]: "kwin_core: Failed to load cursor theme \"default\"\n"
May 26 15:01:09 daniel-pc-manjaro systemd[1600]: Started PipeWire Multimedia Service.
May 26 15:01:09 daniel-pc-manjaro systemd[1600]: Started Multimedia Service Session Manager.
May 26 15:01:09 daniel-pc-manjaro systemd[1]: Starting RealtimeKit Scheduling Policy Service...
May 26 15:01:09 daniel-pc-manjaro wireplumber[1752]: wp-internal-comp-loader: Loading profile 'main'
May 26 15:01:09 daniel-pc-manjaro systemd[1]: Started RealtimeKit Scheduling Policy Service.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Successfully called chroot.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Successfully dropped privileges.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Successfully limited resources.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Running.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Canary thread running.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Watchdog thread running.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 0 threads of 0 processes of 0 users.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 1750 of process 1750 owned by '959' high priority at nice level -11.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 1 threads of 1 processes of 1 users.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 1755 of process 1750 owned by '959' RT at priority 20.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 2 threads of 1 processes of 1 users.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 1752 of process 1752 owned by '959' high priority at nice level -11.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 3 threads of 2 processes of 1 users.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 1762 of process 1752 owned by '959' RT at priority 20.
May 26 15:01:09 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 4 threads of 2 processes of 1 users.
May 26 15:01:09 daniel-pc-manjaro lact[1477]: 2025-05-26T13:01:09.237245Z  INFO lact_daemon::socket: listening on "/run/lactd.sock"
May 26 15:01:09 daniel-pc-manjaro lact[1477]: 2025-05-26T13:01:09.237260Z  INFO lact_daemon::server: TCP listener disabled
May 26 15:01:09 daniel-pc-manjaro lact[1477]: 2025-05-26T13:01:09.247738Z  INFO lact_daemon::server::handler: Intel DRM initialized
May 26 15:01:09 daniel-pc-manjaro lact[1477]: 2025-05-26T13:01:09.247880Z  INFO lact_daemon::server::handler: initialized i915 controller for GPU 8086:A780-1458:D000-0000:00:02.0 at '/sys/class/drm/card1/device'
May 26 15:01:09 daniel-pc-manjaro lact[1477]: 2025-05-26T13:01:09.248046Z  INFO lact_daemon::server::handler: AMDGPU DRM initialized
May 26 15:01:09 daniel-pc-manjaro lact[1477]: 2025-05-26T13:01:09.248296Z  INFO lact_daemon::server::handler: initialized amdgpu controller for GPU 1002:73BF-1849:5202-0000:03:00.0 at '/sys/class/drm/card2/device'
May 26 15:01:09 daniel-pc-manjaro lact[1477]: 2025-05-26T13:01:09.248460Z  INFO lact_daemon::server::handler: initialized 2 GPUs
May 26 15:01:09 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: [drm] amdgpu: AUX reply command not ACK: 0x02.
May 26 15:01:09 daniel-pc-manjaro wireplumber[1752]: spa.alsa: The decibel volume range for element 'PCM' (-7400 dB - -100 dB) has negative maximum. Disabling the decibel range.
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Reading from "/usr/local/share/wayland-sessions/plasmawayland.desktop"
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Reading from "/usr/local/share/xsessions/plasma.desktop"
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Reading from "/usr/share/xsessions/plasma.desktop"
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Connected to the daemon.
May 26 15:01:09 daniel-pc-manjaro sddm[1478]: Message received from greeter: Connect
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Loading file:///usr/share/sddm/themes/breath/Main.qml...
May 26 15:01:09 daniel-pc-manjaro wireplumber[1752]: spa.alsa: The decibel volume range for element 'Mic' (-7400 dB - -100 dB) has negative maximum. Disabling the decibel range.
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Adding view for "DP-4" QRect(0,0 2991x1252)
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Message received from daemon: Capabilities
May 26 15:01:09 daniel-pc-manjaro sddm-greeter-qt6[1684]: Message received from daemon: HostName
May 26 15:01:09 daniel-pc-manjaro kernel: usb 3-1.2: 5:2: cannot get freq at ep 0x2
May 26 15:01:10 daniel-pc-manjaro wireplumber[1752]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
May 26 15:01:10 daniel-pc-manjaro wireplumber[1752]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
May 26 15:01:10 daniel-pc-manjaro wireplumber[1752]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
May 26 15:01:10 daniel-pc-manjaro kernel: Bluetooth: RFCOMM TTY layer initialized
May 26 15:01:10 daniel-pc-manjaro kernel: Bluetooth: RFCOMM socket layer initialized
May 26 15:01:10 daniel-pc-manjaro kernel: Bluetooth: RFCOMM ver 1.11
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/ldac
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSink/aptx_hd
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_hd
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSink/aac
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aac
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSink/opus_g
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/opus_g
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSink/sbc
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/sbc
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/faststream
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSink/opus_05
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/opus_05
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSink/opus_05_duplex
May 26 15:01:10 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.25 path=/MediaEndpoint/A2DPSource/opus_05_duplex
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8944] device (enp6s0): carrier: link connected
May 26 15:01:10 daniel-pc-manjaro kernel: r8169 0000:06:00.0 enp6s0: Link is Up - 1Gbps/Full - flow control off
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8950] device (enp6s0): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8956] policy: auto-activating connection 'Wired connection 1' (a94f5f31-4c7a-3588-b51d-ff761a3e69db)
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8962] device (enp6s0): Activation: starting connection 'Wired connection 1' (a94f5f31-4c7a-3588-b51d-ff761a3e69db)
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8962] device (enp6s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8965] manager: NetworkManager state is now CONNECTING
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8966] device (enp6s0): state change: prepare -> config (reason 'none', managed-type: 'full')
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8974] device (enp6s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.8979] dhcp4 (enp6s0): activation: beginning transaction (timeout in 45 seconds)
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.9019] dhcp4 (enp6s0): state changed no lease
May 26 15:01:10 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264470.9057] dhcp4 (enp6s0): state changed new lease, address=192.168.178.83, acd pending
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0630] dhcp4 (enp6s0): state changed new lease, address=192.168.178.83
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0641] policy: set 'Wired connection 1' (enp6s0) as default for IPv4 routing and DNS
May 26 15:01:11 daniel-pc-manjaro dbus-broker-launch[1356]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0734] device (enp6s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0756] device (enp6s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0759] device (enp6s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0762] manager: NetworkManager state is now CONNECTED_SITE
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0765] device (enp6s0): Activation: successful, device activated.
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.0777] manager: startup complete
May 26 15:01:11 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264471.1097] manager: NetworkManager state is now CONNECTED_GLOBAL
May 26 15:01:11 daniel-pc-manjaro ModemManager[1419]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:05:00.0': not supported by any plugin
May 26 15:01:11 daniel-pc-manjaro ModemManager[1419]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:06:00.0': not supported by any plugin
May 26 15:01:12 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264472.3396] dhcp6 (enp6s0): activation: beginning transaction (timeout in 45 seconds)
May 26 15:01:12 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264472.3402] device (enp6s0): ip:dhcp6: restarting (release lease)
May 26 15:01:12 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264472.3403] dhcp6 (enp6s0): canceled DHCP transaction
May 26 15:01:12 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264472.3403] dhcp6 (enp6s0): state changed no lease
May 26 15:01:12 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264472.3404] dhcp6 (enp6s0): activation: beginning transaction (timeout in 45 seconds)
May 26 15:01:12 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264472.3415] policy: set 'Wired connection 1' (enp6s0) as default for IPv6 routing and DNS
May 26 15:01:13 daniel-pc-manjaro sddm-greeter-qt6[1684]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
May 26 15:01:13 daniel-pc-manjaro sddm-greeter-qt6[1684]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
May 26 15:01:13 daniel-pc-manjaro sddm[1478]: Message received from greeter: Login
May 26 15:01:13 daniel-pc-manjaro sddm[1478]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
May 26 15:01:13 daniel-pc-manjaro sddm[1478]: Session "/usr/share/wayland-sessions/plasmawayland.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland" for VT 2
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: [PAM] Starting...
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: [PAM] Authenticating...
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: [PAM] Preparing to converse...
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: [PAM] Conversation with 1 messages
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: [PAM] returning.
May 26 15:01:13 daniel-pc-manjaro sddm[1478]: Authentication for user  "daniel"  successful
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: pam_unix(sddm:session): session opened for user daniel(uid=1000) by daniel(uid=0)
May 26 15:01:13 daniel-pc-manjaro systemd-logind[1363]: New session 2 of user daniel.
May 26 15:01:13 daniel-pc-manjaro systemd[1]: Created slice User Slice of UID 1000.
May 26 15:01:13 daniel-pc-manjaro systemd[1]: Starting User Runtime Directory /run/user/1000...
May 26 15:01:13 daniel-pc-manjaro sddm-greeter-qt6[1684]: Message received from daemon: LoginSucceeded
May 26 15:01:13 daniel-pc-manjaro systemd[1]: Finished User Runtime Directory /run/user/1000.
May 26 15:01:13 daniel-pc-manjaro systemd[1]: Starting User Manager for UID 1000...
May 26 15:01:13 daniel-pc-manjaro (systemd)[1864]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[daniel] ruser=[<unknown>] rhost=[<unknown>]
May 26 15:01:13 daniel-pc-manjaro (systemd)[1864]: pam_unix(systemd-user:session): session opened for user daniel(uid=1000) by daniel(uid=0)
May 26 15:01:13 daniel-pc-manjaro systemd-logind[1363]: New session 3 of user daniel.
May 26 15:01:13 daniel-pc-manjaro sddm-helper-start-wayland[1679]: wayland greeter finished 0 QProcess::NormalExit
May 26 15:01:13 daniel-pc-manjaro sddm-helper-start-wayland[1679]: quitting helper-start-wayland
May 26 15:01:13 daniel-pc-manjaro sddm-helper-start-wayland[1679]: Stopping... "kwin_wayland"
May 26 15:01:13 daniel-pc-manjaro sddm-helper-start-wayland[1679]: "kwin_scene_opengl: Could not delete render time query because no context is current\n"
May 26 15:01:13 daniel-pc-manjaro sddm-helper-start-wayland[1679]: wayland compositor finished 15 QProcess::NormalExit
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1513]: [PAM] Closing session
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1513]: pam_unix(sddm-greeter:session): session closed for user sddm
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1513]: [PAM] Ended.
May 26 15:01:13 daniel-pc-manjaro sddm[1478]: Auth: sddm-helper exited successfully
May 26 15:01:13 daniel-pc-manjaro sddm[1478]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
May 26 15:01:13 daniel-pc-manjaro systemd[1]: session-c1.scope: Deactivated successfully.
May 26 15:01:13 daniel-pc-manjaro systemd[1]: session-c1.scope: Consumed 1.308s CPU time, 370.4M memory peak.
May 26 15:01:13 daniel-pc-manjaro systemd-logind[1363]: Session c1 logged out. Waiting for processes to exit.
May 26 15:01:13 daniel-pc-manjaro systemd-logind[1363]: Removed session c1.
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/ldac
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSink/aptx_hd
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_hd
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSink/aac
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aac
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSink/opus_g
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/opus_g
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSink/sbc
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/sbc
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/faststream
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSink/opus_05
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/opus_05
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSink/opus_05_duplex
May 26 15:01:13 daniel-pc-manjaro bluetoothd[1360]: Endpoint unregistered: sender=:1.25 path=/MediaEndpoint/A2DPSource/opus_05_duplex
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Queued start job for default target Main User Target.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Created slice User Application Slice.
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Reached target Paths.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Reached target Timers.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Starting D-Bus User Message Bus Socket...
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on GnuPG network certificate management daemon.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on GnuPG cryptographic agent and passphrase cache.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on GnuPG public key management service.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on p11-kit server.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on PipeWire PulseAudio.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on PipeWire Multimedia System Sockets.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Listening on D-Bus User Message Bus Socket.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Reached target Sockets.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Reached target Basic System.
May 26 15:01:13 daniel-pc-manjaro systemd[1]: Started User Manager for UID 1000.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Starting Update XDG user dir configuration...
May 26 15:01:13 daniel-pc-manjaro systemd[1]: Started Session 2 of User daniel.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Finished Update XDG user dir configuration.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Reached target Main User Target.
May 26 15:01:13 daniel-pc-manjaro systemd[1864]: Startup finished in 146ms.
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1907]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1858]: Starting Wayland user session: "/usr/share/sddm/scripts/wayland-session" "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1909]: Jumping to VT 2
May 26 15:01:13 daniel-pc-manjaro sddm-helper[1909]: VT mode didn't need to be fixed
May 26 15:01:13 daniel-pc-manjaro sddm[1478]: Session started true
May 26 15:01:13 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: [drm] amdgpu: AUX reply command not ACK: 0x02.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Created slice User Core Session Slice.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting D-Bus User Message Bus...
May 26 15:01:14 daniel-pc-manjaro dbus-broker-launch[1926]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
May 26 15:01:14 daniel-pc-manjaro dbus-broker-launch[1926]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
May 26 15:01:14 daniel-pc-manjaro dbus-broker-launch[1926]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
May 26 15:01:14 daniel-pc-manjaro dbus-broker-launch[1926]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
May 26 15:01:14 daniel-pc-manjaro dbus-broker-launch[1926]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started D-Bus User Message Bus.
May 26 15:01:14 daniel-pc-manjaro dbus-broker-launch[1926]: Ready
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Reload requested from client PID 1909 ('startplasma-way')...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Reloading...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Reloading finished in 95 ms.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Created slice Slice /app/dbus-:1.2-org.kde.KSplash.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started dbus-:1.2-org.kde.KSplash@0.service.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Created slice User Background Tasks Slice.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Reached target Session services which should run early before the graphical session is brought up.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting KDE Global Shortcuts Server...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting KDE Window Manager...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting Baloo File Indexer Daemon...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started KDE Window Manager.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting KDE Config Module Initialization...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting Splash screen shown during boot...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started KDE Global Shortcuts Server.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started Baloo File Indexer Daemon.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting Portal service...
May 26 15:01:14 daniel-pc-manjaro systemd[1]: Starting Disk Manager...
May 26 15:01:14 daniel-pc-manjaro udisksd[1949]: udisks daemon version 2.10.1 starting
May 26 15:01:14 daniel-pc-manjaro kernel: nvme nvme0: using unchecked data buffer
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting sandboxed app permission store...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started sandboxed app permission store.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting flatpak document portal service...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started flatpak document portal service.
May 26 15:01:14 daniel-pc-manjaro kwin_wayland[1940]: No backend specified, automatically choosing drm
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 4 threads of 2 processes of 1 users.
May 26 15:01:14 daniel-pc-manjaro kernel: block nvme0n1: No UUID available providing old NGUID
May 26 15:01:14 daniel-pc-manjaro systemd[1]: Started Disk Manager.
May 26 15:01:14 daniel-pc-manjaro udisksd[1949]: Acquired the name org.freedesktop.UDisks2 on the system message bus
May 26 15:01:14 daniel-pc-manjaro systemd[1]: Starting Daemon for power management...
May 26 15:01:14 daniel-pc-manjaro kwin_wayland[1940]: kwin_xkbcommon: XKB: [XKB-489] us:825:72: numeric keysym "0x1002039" (16785465)
May 26 15:01:14 daniel-pc-manjaro kwin_wayland[1940]: kwin_xkbcommon: XKB: [XKB-489] us:826:72: numeric keysym "0x100203a" (16785466)
May 26 15:01:14 daniel-pc-manjaro kwin_wayland[1940]: kwin_xkbcommon: XKB: [XKB-489] us:831:72: numeric keysym "0x1001e9e" (16785054)
May 26 15:01:14 daniel-pc-manjaro kwin_wayland[1940]: kwin_xkbcommon: XKB: [XKB-489] us:898:81: numeric keysym "0x1002039" (16785465)
May 26 15:01:14 daniel-pc-manjaro kwin_wayland[1940]: kwin_xkbcommon: XKB: [XKB-489] us:906:81: numeric keysym "0x100203a" (16785466)
May 26 15:01:14 daniel-pc-manjaro kwin_wayland[1940]: kwin_xkbcommon: XKB: Multiple definitions of group 0 name in map 'altgr-intl'; Using 'English (intl., with AltGr dead keys)', ignoring 'English (US, intl., with dead keys)'
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started PipeWire Multimedia Service.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started Multimedia Service Session Manager.
May 26 15:01:14 daniel-pc-manjaro systemd[1]: Started Daemon for power management.
May 26 15:01:14 daniel-pc-manjaro wireplumber[2030]: wp-internal-comp-loader: Loading profile 'main'
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 2029 of process 2029 owned by '1000' high priority at nice level -11.
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 5 threads of 3 processes of 2 users.
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 2033 of process 2029 owned by '1000' RT at priority 20.
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 6 threads of 3 processes of 2 users.
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 2030 of process 2030 owned by '1000' high priority at nice level -11.
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 7 threads of 4 processes of 2 users.
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 2040 of process 2030 owned by '1000' RT at priority 20.
May 26 15:01:14 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 8 threads of 4 processes of 2 users.
May 26 15:01:14 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: [drm] amdgpu: AUX reply command not ACK: 0x02.
May 26 15:01:14 daniel-pc-manjaro baloo_file[1939]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.37'
May 26 15:01:14 daniel-pc-manjaro baloo_file[1939]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.40'
May 26 15:01:14 daniel-pc-manjaro wireplumber[2030]: spa.alsa: The decibel volume range for element 'PCM' (-7400 dB - -100 dB) has negative maximum. Disabling the decibel range.
May 26 15:01:14 daniel-pc-manjaro kcminit_startup[1944]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2078]: The XKEYBOARD keymap compiler (xkbcomp) reports:
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2078]: > Warning:          Could not resolve keysym XF86RefreshRateToggle
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2078]: > Warning:          Could not resolve keysym XF86Accessibility
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2078]: > Warning:          Could not resolve keysym XF86DoNotDisturb
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2078]: Errors from xkbcomp are not fatal to the X server
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2083]: The XKEYBOARD keymap compiler (xkbcomp) reports:
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2083]: > Warning:          Unsupported maximum keycode 708, clipping.
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2083]: >                   X11 cannot support keycodes above 255.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting Accessibility services bus...
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2083]: > Warning:          Could not resolve keysym XF86RefreshRateToggle
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2083]: > Warning:          Could not resolve keysym XF86Accessibility
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2083]: > Warning:          Could not resolve keysym XF86DoNotDisturb
May 26 15:01:14 daniel-pc-manjaro kwin_wayland_wrapper[2083]: Errors from xkbcomp are not fatal to the X server
May 26 15:01:14 daniel-pc-manjaro kcminit_startup[1944]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_style.so"
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started Accessibility services bus.
May 26 15:01:14 daniel-pc-manjaro kcminit[2085]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
May 26 15:01:14 daniel-pc-manjaro kcminit[2085]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_style.so"
May 26 15:01:14 daniel-pc-manjaro dbus-broker-launch[2097]: Ready
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Created slice Slice /app/dbus-:1.19-org.a11y.atspi.Registry.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started dbus-:1.19-org.a11y.atspi.Registry@0.service.
May 26 15:01:14 daniel-pc-manjaro at-spi2-registryd[2106]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
May 26 15:01:14 daniel-pc-manjaro wireplumber[2030]: spa.alsa: The decibel volume range for element 'Mic' (-7400 dB - -100 dB) has negative maximum. Disabling the decibel range.
May 26 15:01:14 daniel-pc-manjaro kcminit_startup[1944]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started KDE Config Module Initialization.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting KDE Session Management Server...
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Started Unlock kwallet from pam credentials.
May 26 15:01:14 daniel-pc-manjaro systemd[1864]: Starting KDE Daemon 6...
May 26 15:01:14 daniel-pc-manjaro pam_kwallet_init[2133]: 2025/05/26 15:01:14 socat[2133] W address is opened in read-write mode but only supports read-only
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started KDE Daemon 6.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting KDE Configuration Module Initialization (Phase 1)...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting User preferences database...
May 26 15:01:15 daniel-pc-manjaro kernel: logitech-hidpp-device 0003:046D:407F.0009: HID++ 4.2 device connected.
May 26 15:01:15 daniel-pc-manjaro kcminit_startup[1944]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings_qwidgets/kcm_kgamma.so"
May 26 15:01:15 daniel-pc-manjaro kcminit_startup[1944]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started User preferences database.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Finished KDE Configuration Module Initialization (Phase 1).
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: org.kde.colorcorrectlocationupdater: Geolocator stopped
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started KDE Session Management Server.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting KDE Plasma Workspace...
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: QDBusObjectPath: invalid path "/modules/oom-notifier"
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: org.kde.kameleon: found no RGB LED devices
May 26 15:01:15 daniel-pc-manjaro NetworkManager[1358]: <info>  [1748264475.1057] agent-manager: agent[ffd74038ec0c2df3,:1.43/org.kde.plasma.networkmanagement/1000]: agent registered
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started PipeWire PulseAudio.
May 26 15:01:15 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 8 threads of 4 processes of 2 users.
May 26 15:01:15 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 2208 of process 2208 owned by '1000' high priority at nice level -11.
May 26 15:01:15 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 9 threads of 5 processes of 2 users.
May 26 15:01:15 daniel-pc-manjaro rtkit-daemon[1758]: Successfully made thread 2215 of process 2208 owned by '1000' RT at priority 20.
May 26 15:01:15 daniel-pc-manjaro rtkit-daemon[1758]: Supervising 10 threads of 5 processes of 2 users.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting KActivityManager Activity manager Service...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started KDE Plasma Workspace.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Reached target KDE Plasma Workspace Core.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started Proxies GTK DBus menus to a Plasma readable format.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started KAccess.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting KDE PolicyKit Authentication Agent...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting Powerdevil...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting Xdg Desktop Portal For KDE...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started Handle legacy xembed system tray icons.
May 26 15:01:15 daniel-pc-manjaro kactivitymanagerd[2240]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
May 26 15:01:15 daniel-pc-manjaro kaccess[2242]: Xlib XKB extension major= 1  minor= 0
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started KActivityManager Activity manager Service.
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Starting libddcutil. library built Not set at Not set. stdout_stderr_redirected=true
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started KDE PolicyKit Authentication Agent.
May 26 15:01:15 daniel-pc-manjaro polkit-kde-authentication-agent-1[2243]: New PolkitAgentListener  0x5e02d54e4620
May 26 15:01:15 daniel-pc-manjaro polkit-kde-authentication-agent-1[2243]: Adding new listener  PolkitQt1::Agent::Listener(0x5e02d54e4210) for  0x5e02d54e4620
May 26 15:01:15 daniel-pc-manjaro polkit-kde-authentication-agent-1[2243]: Listener online
May 26 15:01:15 daniel-pc-manjaro polkitd[1361]: Registered Authentication Agent for unix-session:2 (system bus name :1.50 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 26 15:01:15 daniel-pc-manjaro polkit-kde-authentication-agent-1[2243]: Authentication agent result: true
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started Xdg Desktop Portal For KDE.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started Portal service.
May 26 15:01:15 daniel-pc-manjaro kaccess[2242]: X server XKB extension major= 1  minor= 0
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Initializing libddcutil.  ddcutil version: 2.2.0, shared library: /usr/lib/libddcutil.so.5.2.0
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Options passed from client:
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Applying combined libddcutil options:
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-0 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-1 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-2 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-3 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-4 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-5 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-6 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-7 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-8 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Device /dev/i2c-9 lacks R/W permissions
May 26 15:01:15 daniel-pc-manjaro plasmashell[2195]: kf.plasma.quick: Applet preload policy set to 1
May 26 15:01:15 daniel-pc-manjaro plasmashell[2195]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
                                                     file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/ldac
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/aptx_hd
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/aptx_hd
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/aac
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/aac
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/opus_g
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/opus_g
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/faststream
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/opus_05
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/opus_05
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/opus_05_duplex
May 26 15:01:15 daniel-pc-manjaro bluetoothd[1360]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/opus_05_duplex
May 26 15:01:15 daniel-pc-manjaro wireplumber[2030]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
May 26 15:01:15 daniel-pc-manjaro wireplumber[2030]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: QDBusObjectPath: invalid path "/modules/wpad-detector"
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
May 26 15:01:15 daniel-pc-manjaro kconf_update[2343]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
May 26 15:01:15 daniel-pc-manjaro kconf_update[2343]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
May 26 15:01:15 daniel-pc-manjaro kconf_update[2343]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
May 26 15:01:15 daniel-pc-manjaro kconf_update[2343]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
May 26 15:01:15 daniel-pc-manjaro plasmashell[2195]: Toolbox not loading, toolbox package is either invalid or disabled.
May 26 15:01:15 daniel-pc-manjaro kded6[2348]: xsettingsd: Loaded 14 settings from /home/daniel/.config/xsettingsd/xsettingsd.conf
May 26 15:01:15 daniel-pc-manjaro kded6[2348]: xsettingsd: Created window 0xe00001 on screen 0 with timestamp 21148
May 26 15:01:15 daniel-pc-manjaro kded6[2348]: xsettingsd: Selection _XSETTINGS_S0 is owned by 0x0
May 26 15:01:15 daniel-pc-manjaro kded6[2348]: xsettingsd: Took ownership of selection _XSETTINGS_S0
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: kf.bluezqt: PendingCall Error: "The name is not activatable"
May 26 15:01:15 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: [drm] amdgpu: AUX reply command not ACK: 0x02.
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Library initialization complete.
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Watching for display connection changes, resolved watch mode = Watch_Mode_Xevent, poll loop interval = 100 millisec
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244]                                          extra_stabilization_millisec: 0,  stabilization_poll_millisec: 100
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] libddcutil recheck thread (nil) started
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] libddcutil watch thread 0x60e3dd6010b0 started
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error(s) opening ddc devices
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-0
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-1
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-2
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-3
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-4
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-5
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-6
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-7
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error(s) opening ddc devices
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-8
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: Error EACCES(-13): Permission denied opening /dev/i2c-9
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-0
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-1
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-2
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-3
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-4
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-5
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-6
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-7
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-8
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2244] Error EACCES(-13): Permission denied opening /dev/i2c-9
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
May 26 15:01:15 daniel-pc-manjaro backlighthelper[2392]: org.kde.powerdevil: no kernel backlight interface found
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: [  2370] (dw_recheck_displays_func) Recheck interval: Slept for 200 millisec
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started Powerdevil.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Reached target KDE Plasma Workspace.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Reached target Current graphical user session.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Reached target plasma-workspace-wayland.target.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting AT-SPI D-Bus Bus...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting MSM Notifier...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting KDE Connect...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting Plasma Session Restore...
May 26 15:01:15 daniel-pc-manjaro org_kde_powerdevil[2244]: org.kde.powerdevil: Handle button events action could not check for screen configuration
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting Update Notifier...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting Update Notifier Tray Icon...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting Print Queue Applet...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting xapp-sn-watcher...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting KSplash "ready" Stage...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Starting KDE Session Restoration...
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started MSM Notifier.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started KDE Connect.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: app-at\x2dspi\x2ddbus\x2dbus@autostart.service: Skipped due to 'exec-condition'.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Condition check resulted in AT-SPI D-Bus Bus being skipped.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: app-pamac\x2dtray@autostart.service: Skipped due to 'exec-condition'.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Condition check resulted in Update Notifier being skipped.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: app-pamac\x2dtray\x2dbudgie@autostart.service: Skipped due to 'exec-condition'.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: app-print\x2dapplet@autostart.service: Skipped due to 'exec-condition'.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Condition check resulted in Print Queue Applet being skipped.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Finished KSplash "ready" Stage.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started Plasma Session Restore.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Finished KDE Session Restoration.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started Update Notifier Tray Icon.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started xapp-sn-watcher.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Reached target Startup of XDG autostart applications.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Finished Splash screen shown during boot.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: plasma-ksplash.service: Consumed 297ms CPU time, 107.8M memory peak.
May 26 15:01:15 daniel-pc-manjaro plasmashell[2195]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: Registering ":1.52/StatusNotifierItem" to system tray
May 26 15:01:15 daniel-pc-manjaro kded6[2131]: Registering ":1.53/StatusNotifierItem" to system tray
May 26 15:01:15 daniel-pc-manjaro pamac-tray-plas[2431]: updates_checker.vala:59: check updates
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Starting Pamac Daemon...
May 26 15:01:15 daniel-pc-manjaro kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Created slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
May 26 15:01:15 daniel-pc-manjaro systemd[1]: Started Pamac Daemon.
May 26 15:01:15 daniel-pc-manjaro systemd[1864]: Started dbus-:1.2-org.freedesktop.Notifications@0.service.
May 26 15:01:16 daniel-pc-manjaro plasmashell[2195]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
May 26 15:01:16 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: [drm] amdgpu: AUX reply command not ACK: 0x02.
May 26 15:01:17 daniel-pc-manjaro systemd[1]: pamac-daemon.service: Deactivated successfully.
May 26 15:01:17 daniel-pc-manjaro systemd[1864]: Started Brave - Web Browser.
May 26 15:01:18 daniel-pc-manjaro systemd[1864]: Created slice Slice /app/dbus-:1.2-org.kde.kwalletd6.
May 26 15:01:18 daniel-pc-manjaro systemd[1864]: Started dbus-:1.2-org.kde.kwalletd6@0.service.
May 26 15:01:18 daniel-pc-manjaro brave[2598]: libva error: /usr/lib/dri/i965_drv_video.so init failed
May 26 15:01:18 daniel-pc-manjaro kwalletd6[2600]: g_dbus_proxy_get_object_path: assertion 'G_IS_DBUS_PROXY (proxy)' failed
May 26 15:01:18 daniel-pc-manjaro kwin_wayland[1940]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 26 15:01:18 daniel-pc-manjaro systemd[1864]: Started app-org.chromium.Chromium-2545.scope.
May 26 15:01:21 daniel-pc-manjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
May 26 15:01:21 daniel-pc-manjaro brave[2598]: [2598:2598:0526/150121.207798:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 1 times!
May 26 15:01:22 daniel-pc-manjaro brave[2545]: [2545:2545:0526/150122.361822:ERROR:mojo/public/cpp/bindings/lib/interface_endpoint_client.cc:725] Message 0 rejected by interface blink.mojom.WidgetHost
May 26 15:01:24 daniel-pc-manjaro systemd[1]: Stopping User Manager for UID 959...
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Activating special unit Exit the Session...
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped target Main User Target.
May 26 15:01:24 daniel-pc-manjaro wireplumber[1752]: wireplumber: stopped by signal: Terminated
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopping Multimedia Service Session Manager...
May 26 15:01:24 daniel-pc-manjaro wireplumber[1752]: wireplumber: disconnected from pipewire
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped Multimedia Service Session Manager.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopping PipeWire Multimedia Service...
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped PipeWire Multimedia Service.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped target Basic System.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped target Paths.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped target Sockets.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped target Timers.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed GnuPG network certificate management daemon.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed GnuPG cryptographic agent (ssh-agent emulation).
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed GnuPG cryptographic agent and passphrase cache.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed GnuPG public key management service.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed p11-kit server.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed PipeWire PulseAudio.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed PipeWire Multimedia System Sockets.
May 26 15:01:24 daniel-pc-manjaro dbus-broker[1686]: Dispatched 447 messages @ 2(±4)μs / message.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopping D-Bus User Message Bus...
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Stopped D-Bus User Message Bus.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Removed slice User Core Session Slice.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Closed D-Bus User Message Bus Socket.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Removed slice User Application Slice.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Reached target Shutdown.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Finished Exit the Session.
May 26 15:01:24 daniel-pc-manjaro systemd[1600]: Reached target Exit the Session.
May 26 15:01:24 daniel-pc-manjaro systemd-logind[1363]: Removed session 1.
May 26 15:01:24 daniel-pc-manjaro (sd-pam)[1621]: pam_unix(systemd-user:session): session closed for user sddm
May 26 15:01:24 daniel-pc-manjaro systemd[1]: user@959.service: Deactivated successfully.
May 26 15:01:24 daniel-pc-manjaro systemd[1]: Stopped User Manager for UID 959.
May 26 15:01:24 daniel-pc-manjaro systemd[1]: Stopping User Runtime Directory /run/user/959...
May 26 15:01:24 daniel-pc-manjaro systemd[1]: run-user-959.mount: Deactivated successfully.
May 26 15:01:24 daniel-pc-manjaro systemd[1]: user-runtime-dir@959.service: Deactivated successfully.
May 26 15:01:24 daniel-pc-manjaro systemd[1]: Stopped User Runtime Directory /run/user/959.
May 26 15:01:24 daniel-pc-manjaro systemd[1]: Removed slice User Slice of UID 959.
May 26 15:01:24 daniel-pc-manjaro systemd[1]: user-959.slice: Consumed 1.845s CPU time, 406.5M memory peak.
May 26 15:01:25 daniel-pc-manjaro systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
May 26 15:01:25 daniel-pc-manjaro systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
May 26 15:01:26 daniel-pc-manjaro systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
May 26 15:01:34 daniel-pc-manjaro brave[2598]: [2598:2598:0526/150134.799352:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 2 times!
May 26 15:01:36 daniel-pc-manjaro brave[2598]: [2598:2598:0526/150136.412445:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 3 times!
May 26 15:01:37 daniel-pc-manjaro systemd[1]: systemd-hostnamed.service: Deactivated successfully.
May 26 15:01:44 daniel-pc-manjaro systemd[1]: systemd-localed.service: Deactivated successfully.
May 26 15:01:44 daniel-pc-manjaro systemd-timesyncd[544]: Timed out waiting for reply from [2003:a:47f:abe4::1]:123 (2.manjaro.pool.ntp.org).
May 26 15:01:48 daniel-pc-manjaro chrome[2545]: [2545:2564:0526/150148.226619:INFO:chrome/browser/extensions/extension_garbage_collector.cc:184] Garbage collection for extensions on file thread is complete.
May 26 15:01:48 daniel-pc-manjaro brave[2545]: [2545:2686:0526/150148.250116:ERROR:../src/content/browser/browser_main_loop.cc:278] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
May 26 15:01:48 daniel-pc-manjaro brave[2545]: [2545:2688:0526/150148.250117:ERROR:../src/content/browser/browser_main_loop.cc:278] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
May 26 15:01:48 daniel-pc-manjaro brave[2545]: [2545:2687:0526/150148.250124:ERROR:../src/content/browser/browser_main_loop.cc:278] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
May 26 15:01:55 daniel-pc-manjaro systemd-timesyncd[544]: Timed out waiting for reply from [2a01:4f8:150:60c3::2]:123 (2.manjaro.pool.ntp.org).
May 26 15:02:05 daniel-pc-manjaro systemd-timesyncd[544]: Timed out waiting for reply from [2a02:8106:21:9400::3]:123 (2.manjaro.pool.ntp.org).
May 26 15:02:15 daniel-pc-manjaro systemd-timesyncd[544]: Timed out waiting for reply from [2a03:4000:6b:191:9825:1cff:fe34:bbe]:123 (2.manjaro.pool.ntp.org).
May 26 15:02:15 daniel-pc-manjaro systemd-timesyncd[544]: Contacted time server 131.188.3.222:123 (2.manjaro.pool.ntp.org).
May 26 15:02:15 daniel-pc-manjaro systemd-timesyncd[544]: Initial clock synchronization to Mon 2025-05-26 15:02:15.940630 CEST.
May 26 15:02:36 daniel-pc-manjaro plasmashell[2195]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
May 26 15:02:36 daniel-pc-manjaro plasmashell[2195]: qt.svg: <input>:1:13693: Could not resolve property: #linearGradient10962
May 26 15:02:36 daniel-pc-manjaro systemd[1864]: Starting KRunner provider for baloo file indexer...
May 26 15:02:36 daniel-pc-manjaro systemd[1864]: Started KRunner provider for baloo file indexer.
May 26 15:02:38 daniel-pc-manjaro kwin_wayland[1940]: qt.svg: <input>:1:13693: Could not resolve property: #linearGradient10962
May 26 15:02:38 daniel-pc-manjaro systemd[1864]: Started Alacritty - Terminal.
May 26 15:02:46 daniel-pc-manjaro sudo[3261]:   daniel : TTY=pts/1 ; PWD=/root ; USER=root ; COMMAND=/usr/bin/bash
May 26 15:02:46 daniel-pc-manjaro sudo[3261]: pam_unix(sudo:session): session opened for user root(uid=0) by daniel(uid=1000)
May 26 15:04:59 daniel-pc-manjaro kernel: usb 3-1.2: USB disconnect, device number 8
May 26 15:04:59 daniel-pc-manjaro kded6[2131]: org.kde.pulseaudio: No object for name "alsa_input.usb-Audeze_LLC_Audeze_Maxwell_XBOX_Dongle_0000000000000000-01.mono-fallback"
May 26 15:04:59 daniel-pc-manjaro kded6[2131]: org.kde.pulseaudio: No object for name "alsa_output.usb-Audeze_LLC_Audeze_Maxwell_XBOX_Dongle_0000000000000000-01.analog-stereo"
May 26 15:04:59 daniel-pc-manjaro plasmashell[2195]: org.kde.pulseaudio: No object for name "alsa_input.usb-Audeze_LLC_Audeze_Maxwell_XBOX_Dongle_0000000000000000-01.mono-fallback"
May 26 15:04:59 daniel-pc-manjaro plasmashell[2195]: org.kde.pulseaudio: No object for name "alsa_output.usb-Audeze_LLC_Audeze_Maxwell_XBOX_Dongle_0000000000000000-01.analog-stereo"
May 26 15:05:01 daniel-pc-manjaro kernel: usb 3-1.2: new high-speed USB device number 9 using xhci_hcd
May 26 15:05:01 daniel-pc-manjaro kernel: usb 3-1.2: New USB device found, idVendor=3329, idProduct=4b18, bcdDevice= 1.00
May 26 15:05:01 daniel-pc-manjaro kernel: usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 26 15:05:01 daniel-pc-manjaro kernel: usb 3-1.2: Product: Audeze Maxwell XBOX Dongle
May 26 15:05:01 daniel-pc-manjaro kernel: usb 3-1.2: Manufacturer: Audeze LLC
May 26 15:05:01 daniel-pc-manjaro kernel: usb 3-1.2: SerialNumber: 0000000000000000
May 26 15:05:01 daniel-pc-manjaro kernel: input: Audeze LLC Audeze Maxwell XBOX Dongle Consumer Control as /devices/pci0000:00/0000:00:1d.0/0000:07:00.0/0000:08:01.0/0000:0a:00.0/0000:0b:00.0/0000:0c:00.0/usb3/3-1/3-1.2/3-1.2:1.0/0003:3329:4B18.000B/input/input42
May 26 15:05:01 daniel-pc-manjaro kernel: input: Audeze LLC Audeze Maxwell XBOX Dongle as /devices/pci0000:00/0000:00:1d.0/0000:07:00.0/0000:08:01.0/0000:0a:00.0/0000:0b:00.0/0000:0c:00.0/usb3/3-1/3-1.2/3-1.2:1.0/0003:3329:4B18.000B/input/input43
May 26 15:05:01 daniel-pc-manjaro kernel: input: Audeze LLC Audeze Maxwell XBOX Dongle as /devices/pci0000:00/0000:00:1d.0/0000:07:00.0/0000:08:01.0/0000:0a:00.0/0000:0b:00.0/0000:0c:00.0/usb3/3-1/3-1.2/3-1.2:1.0/0003:3329:4B18.000B/input/input44
May 26 15:05:01 daniel-pc-manjaro kernel: hid-generic 0003:3329:4B18.000B: input,hiddev99,hidraw4: USB HID v1.10 Device [Audeze LLC Audeze Maxwell XBOX Dongle] on usb-0000:0c:00.0-1.2/input0
May 26 15:05:01 daniel-pc-manjaro mtp-probe[3341]: checking bus 3, device 9: "/sys/devices/pci0000:00/0000:00:1d.0/0000:07:00.0/0000:08:01.0/0000:0a:00.0/0000:0b:00.0/0000:0c:00.0/usb3/3-1/3-1.2"
May 26 15:05:01 daniel-pc-manjaro mtp-probe[3341]: bus: 3, device: 9 was not an MTP device
May 26 15:05:01 daniel-pc-manjaro boltd[1423]: probing: started [1000]
May 26 15:05:02 daniel-pc-manjaro mtp-probe[3371]: checking bus 3, device 9: "/sys/devices/pci0000:00/0000:00:1d.0/0000:07:00.0/0000:08:01.0/0000:0a:00.0/0000:0b:00.0/0000:0c:00.0/usb3/3-1/3-1.2"
May 26 15:05:02 daniel-pc-manjaro mtp-probe[3371]: bus: 3, device: 9 was not an MTP device
May 26 15:05:04 daniel-pc-manjaro boltd[1423]: probing: timeout, done: [2954123] (2000000)
May 26 15:05:59 daniel-pc-manjaro brave[2545]: [2545:2545:0526/150559.066684:ERROR:mojo/public/cpp/bindings/lib/interface_endpoint_client.cc:725] Message 5 rejected by interface blink.mojom.WidgetHost
May 26 15:08:08 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
May 26 15:08:19 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
May 26 15:08:20 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
May 26 15:08:23 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000029 SMN_C2PMSG_82:0x00000000
May 26 15:08:23 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Failed to disable gfxoff!
May 26 15:08:27 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000029 SMN_C2PMSG_82:0x00000000
May 26 15:08:27 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Failed to disable gfxoff!
May 26 15:08:29 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
May 26 15:08:33 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000029 SMN_C2PMSG_82:0x00000000
May 26 15:08:33 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Failed to disable gfxoff!
May 26 15:08:36 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000029 SMN_C2PMSG_82:0x00000000
May 26 15:08:36 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Failed to disable gfxoff!
May 26 15:08:40 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000029 SMN_C2PMSG_82:0x00000000
May 26 15:08:40 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Failed to disable gfxoff!
May 26 15:08:43 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000029 SMN_C2PMSG_82:0x00000000
May 26 15:08:43 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Failed to disable gfxoff!
May 26 15:08:43 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=9949, emitted seq=9951
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process alacritty pid 3191 thread alacritty:cs0 pid 3194
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset failure
May 26 15:08:44 daniel-pc-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
May 26 15:08:48 daniel-pc-manjaro brave[2547]: [0526/150848.060314:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
May 26 15:08:56 daniel-pc-manjaro kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 26s! [journalctl:3472]
In the last log the amdgpu dump mentions the process “alacritty” - this was the first time alacritty was open at the time of freeze. In the other 3 logs the process “plasmashell” is mentioned instead.
As a troubleshooting step I disabled GFXOFF via the amdgpu.ppfeaturemask kernel module parameter, afterwards the journal messages regarding the crashes have always been:
No combination of amdgpu.ppfeaturemask and amdgpu.ppdebugmask made any difference. In the meantime I updated the whole system, including Mesa from 25.0.5 to 25.1.1, which contained fixed regarding “Random mesa crashes in kwin_wayland on a 6600XT” (this particular fix was in 25.1.0) and the problem didn’t change at all.
A few days ago I switched from Plasma to Sway and currently I’m switching back and forth between Sway and Hyprland. I haven’t had a single crash since moving away from Plasma - except for one situation:
I started the PC and logged into Plasma to disable KWallet, logged out and logged into Sway. A few minutes later there was a crash, seemingly because Plasma was started at some point that boot.
Since this issue only persists when using Plasma, I do not believe this to be an amdgpu driver issue (as stated in the kwin_wayland error messages). Maybe it is, but Plasma triggers it. On Sway and Hyprland this doesn’t happen.
I’m going to report this issue at AMD but for the time being, I am simply moving away from Plasma since a system that’s crashing every few minutes on some days is not useable.
Hello.
Perhaps it could help you. In the link down below, somebody mentioned that the problem could be solved by using X11. I think you could keep using Plasma if that works until somebody fixes that issue or you find a solution.
https://bugs.kde.org/show_bug.cgi?id=493277
Also I think I saw that you already reported in their Gitlab. If you find anything, reporting here can help someone that is facing the same problem.
:vulcan_salute:t2: May the Force Live with You, Long and Prosper :milky_way: .
I reported the issue to amd here and am currently trying the patch that was provided. Looks good so far.
the patch fixed the issue and since it is included in the 6.12.32-1-MANJARO kernel (which currently is in the testing branch), I don’t have to run my own kernel anymore. I’m calling this solved and already closed the upsteam issue.
