My whole system have been crashing regularly (keyboard unresponsive) while using the browser. More specifically while opening external links from applications like Thunderbird, Fluentreader, Telegram. While looking at the logs of journalctl I’ve found these two lines before the crash.
Oct 18 11:14:49 manjaro kernel: [drm:atom_op_jump [radeon]] *ERROR* atombios stuck in loop for more than 5secs aborting
Oct 18 11:14:49 manjaro kernel: [drm:atom_execute_table_locked [radeon]] *ERROR* atombios stuck executing 69B8 (len 237, WS 0, PS 4) @ 0x69C6
Oct 18 11:14:49 manjaro kernel: [drm:atom_execute_table_locked [radeon]] *ERROR* atombios stuck executing 6324 (len 78, WS 12, PS 8) @ 0x635D
Oct 18 11:14:49 manjaro kernel: [drm] PCIE gen 3 link speeds already enabled
Oct 18 11:14:49 manjaro kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 18 11:14:49 manjaro kernel: [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
Oct 18 11:14:49 manjaro kernel: radeon 0000:01:00.0: WB enabled
Oct 18 11:14:49 manjaro kernel: radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
Oct 18 11:14:49 manjaro kernel: radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
Oct 18 11:14:49 manjaro kernel: radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
Oct 18 11:14:49 manjaro kernel: radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
Oct 18 11:14:49 manjaro kernel: radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
Oct 18 11:14:50 manjaro kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x850C)=0xCAFEDEAD)
Oct 18 11:14:50 manjaro kernel: [drm:si_resume [radeon]] *ERROR* si startup failed on resume
I also noticed those error regarding Radeon happened before even before the crash.
This is my inxi output:
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=95e643e5-40b5-4e6a-8550-a55cc45cf527 ro quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 81EC v: 61.61 serial: <filter> UEFI: Insyde v: F.49
date: 06/26/2020
RAM: total: 7.54 GiB used: 4.65 GiB (61.7%)
Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache:
L2: 3 MiB bogomips: 19204
Speed: 900 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD type: USB
driver: uvcvideo bus-ID: 1-5:4 chip-ID: 05c8:038f class-ID: 0e02
serial: <filter>
loaded: ati,modesetting unloaded: radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.04 TiB used: 1.67 TiB (81.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD Elements 2620 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1018 scheme: GPT
ID-1: / raw-size: 80.2 GiB size: 78.44 GiB (97.81%) used: 69.16 GiB (88.2%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 95e643e5-40b5-4e6a-8550-a55cc45cf527
used: 25.4 MiB (26.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 3084-AA3F
ID-3: /media/Elements raw-size: 1.63 TiB size: 1.63 TiB (100.00%)
used: 1.5 TiB (92.2%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: Elements
uuid: A2A63560A63535DF
ID-4: /media/timeshift raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
used: 102.72 GiB (53.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
label: Timeshift uuid: 2d904797-d36c-4097-a23b-92d2befbf90c
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 142.78 GiB fs: ntfs label: N/A
uuid: BE06979706974F71
ID-3: /dev/sda4 maj-min: 8:4 size: 482 MiB fs: ntfs label: N/A
uuid: 96A651F2A651D2FB
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: KYE Systems (Mouse Systems) Genius DX-120 Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 0458:0186 class-ID: 0300
Device-2: 1-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b008
Device-3: 1-5:4
info: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD type: Video
chip-ID: 05c8:038f class-ID: 0e02 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 2-1:2 info: Western Digital Elements 2620 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 1058:2620 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 38.5 C mobo: 29.8 C gpu: radeon temp: 34.0 C
Processes: 253 Uptime: 1h 0m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1994 pacman: 1969
lib: 499 flatpak: 25 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
[andree@manjaro ~]$ export LANG=C
[andree@manjaro ~]$ inxi --admin --verbosity=7 --filter --no-host --width
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:es",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_MONETARY = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_MEASUREMENT = "es_PE.UTF-8",
LC_TIME = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "C"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
date: 06/26/2020
RAM: total: 7.54 GiB used: 4.69 GiB (62.2%)
Speed: 869 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 869 2: 882 3: 868
4: 872
Type: l1tf
520 Mobile]
serial: <filter>
diag: 395mm (15.5")
direct render: Yes
class-ID: 0200
uuid: 3084-AA3F
Device-3: 1-5:4
Processes: 255 Uptime: 1h 0m wakeups: 1 Init: systemd v: 249 tool: systemctl
This is my Xorg log:
[ 11.367] (--) Log file renamed from "/var/log/Xorg.pid-635.log" to "/var/log/Xorg.0.log"
[ 11.371]
X.Org X Server 1.20.13
[ 11.371] Build Operating System: Linux Manjaro Linux
[ 11.371] Current Operating System: Linux manjaro 5.10.70-1-MANJARO #1 SMP PREEMPT Thu Sep 30 15:29:01 UTC 2021 x86_64
[ 11.371] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=95e643e5-40b5-4e6a-8550-a55cc45cf527 ro quiet apparmor=1 security=apparmor udev.log_priority=3
[ 11.371] Build Date: 24 August 2021 10:21:29AM
[ 11.371]
[ 11.371] Current version of pixman: 0.40.0
[ 11.371] Before reporting problems, check http://wiki.x.org
[ 11.371] Markers: (--) probed, (**) from config file, (==) default setting,
[ 11.371] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Oct 18 10:14:23 2021
[ 11.373] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 11.373] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.377] (==) ServerLayout "layout"
[ 11.377] (==) No screen section available. Using defaults.
[ 11.377] (**) |-->Screen "Default Screen Section" (0)
[ 11.377] (**) | |-->Monitor "<default monitor>"
[ 11.377] (==) No monitor specified for screen "Default Screen Section".
[ 11.377] (==) Automatically adding devices
[ 11.377] (==) Automatically enabling devices
[ 11.377] (==) Automatically adding GPU devices
[ 11.377] (==) Automatically binding GPU devices
[ 11.377] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.381] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 11.381] Entry deleted from font path.
[ 11.381] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 11.381] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 11.381] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 11.381] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 11.381] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 11.381] (II) The server relies on udev to provide the list of input devices.
[ 11.381] (II) Module ABI versions:
[ 11.381] X.Org ANSI C Emulation: 0.4
[ 11.381] X.Org Video Driver: 24.1
[ 11.381] X.Org XInput driver : 24.1
[ 11.381] X.Org Server Extension : 10.0
[ 11.382] (++) using VT number 1
[ 11.382] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.382] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 11.399] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.402] (--) PCI:*(0@0:2:0) 8086:1916:103c:81ec rev 7, Mem @ 0xa0000000/16777216, 0x90000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
[ 11.402] (--) PCI: (1@0:0:0) 1002:6660:103c:81ec rev 131, Mem @ 0x80000000/268435456, 0xa1300000/262144, I/O @ 0x00005000/256, BIOS @ 0x????????/131072
[ 11.402] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 11.402] (II) LoadModule: "glx"
[ 11.411] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.422] (II) Module glx: vendor="X.Org Foundation"
[ 11.422] compiled for 1.20.13, module version = 1.0.0
[ 11.422] ABI class: X.Org Server Extension, version 10.0
[ 11.422] (II) Applying OutputClass "intel" to /dev/dri/card1
[ 11.422] loading driver: modesetting
[ 11.422] (II) Applying OutputClass "Radeon" to /dev/dri/card0
[ 11.422] loading driver: radeon
[ 11.422] (==) Matched modesetting as autoconfigured driver 0
[ 11.422] (==) Matched radeon as autoconfigured driver 1
[ 11.422] (==) Matched ati as autoconfigured driver 2
[ 11.422] (==) Matched fbdev as autoconfigured driver 3
[ 11.422] (==) Matched vesa as autoconfigured driver 4
[ 11.422] (==) Assigned the driver to the xf86ConfigLayout
[ 11.422] (II) LoadModule: "modesetting"
[ 11.422] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 11.427] (II) Module modesetting: vendor="X.Org Foundation"
[ 11.427] compiled for 1.20.13, module version = 1.20.13
[ 11.427] Module class: X.Org Video Driver
[ 11.427] ABI class: X.Org Video Driver, version 24.1
[ 11.427] (II) LoadModule: "radeon"
[ 11.427] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 11.438] (II) Module radeon: vendor="X.Org Foundation"
[ 11.438] compiled for 1.20.8, module version = 19.1.0
[ 11.438] Module class: X.Org Video Driver
[ 11.438] ABI class: X.Org Video Driver, version 24.1
[ 11.438] (II) LoadModule: "ati"
[ 11.438] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 11.439] (II) Module ati: vendor="X.Org Foundation"
[ 11.439] compiled for 1.20.8, module version = 19.1.0
[ 11.439] Module class: X.Org Video Driver
[ 11.439] ABI class: X.Org Video Driver, version 24.1
[ 11.439] (II) LoadModule: "fbdev"
[ 11.440] (WW) Warning, couldn't open module fbdev
[ 11.440] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 11.440] (II) LoadModule: "vesa"
[ 11.440] (WW) Warning, couldn't open module vesa
[ 11.440] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 11.440] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 11.440] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 11.449] (II) modeset(0): using drv /dev/dri/card1
[ 11.449] (II) modeset(G0): using drv /dev/dri/card0
[ 11.450] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 11.450] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 11.450] (==) modeset(0): RGB weight 888
[ 11.450] (==) modeset(0): Default visual is TrueColor
[ 11.450] (II) Loading sub module "glamoregl"
[ 11.450] (II) LoadModule: "glamoregl"
[ 11.450] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 11.466] (II) Module glamoregl: vendor="X.Org Foundation"
[ 11.466] compiled for 1.20.13, module version = 1.0.1
[ 11.466] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.912] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 520 (SKL GT2)
[ 11.912] (II) modeset(0): glamor initialized
[ 11.913] (II) modeset(0): Output eDP-1 has no monitor section
[ 11.917] (II) modeset(0): Output HDMI-1 has no monitor section
[ 11.918] (II) modeset(0): EDID for output eDP-1
[ 11.918] (II) modeset(0): Manufacturer: LGD Model: 503 Serial#: 0
[ 11.918] (II) modeset(0): Year: 2015 Week: 0
[ 11.918] (II) modeset(0): EDID Version: 1.4
[ 11.918] (II) modeset(0): Digital Display Input
[ 11.918] (II) modeset(0): 6 bits per channel
[ 11.918] (II) modeset(0): Digital interface is DisplayPort
[ 11.918] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 11.918] (II) modeset(0): Gamma: 2.20
[ 11.918] (II) modeset(0): No DPMS capabilities specified
[ 11.918] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 11.918] (II) modeset(0): First detailed timing is preferred mode
[ 11.918] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 11.918] (II) modeset(0): redX: 0.567 redY: 0.344 greenX: 0.332 greenY: 0.561
[ 11.918] (II) modeset(0): blueX: 0.159 blueY: 0.119 whiteX: 0.313 whiteY: 0.329
[ 11.918] (II) modeset(0): Manufacturer's mask: 0
[ 11.918] (II) modeset(0): Supported detailed timing:
[ 11.918] (II) modeset(0): clock: 76.3 MHz Image Size: 344 x 194 mm
[ 11.918] (II) modeset(0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1610 h_border: 0
[ 11.918] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 790 v_border: 0
[ 11.919] (II) modeset(0): clock: 50.9 MHz Image Size: 344 x 194 mm
[ 11.919] (II) modeset(0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1610 h_border: 0
[ 11.919] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 790 v_border: 0
[ 11.919] (II) modeset(0): Unknown vendor-specific block 2
[ 11.919] (II) modeset(0): EDID (in hex):
[ 11.919] (II) modeset(0): 00ffffffffffff0030e4030500000000
[ 11.919] (II) modeset(0): 00190104952213780a42e59158558f28
[ 11.919] (II) modeset(0): 1e505400000001010101010101010101
[ 11.919] (II) modeset(0): 010101010101d01d56f4500016303020
[ 11.919] (II) modeset(0): 350058c21000001be01356f450001630
[ 11.919] (II) modeset(0): 3020350058c21000001b000000000000
[ 11.919] (II) modeset(0): 00000000000000000000000000000002
[ 11.919] (II) modeset(0): 000c47ff0a3c6e12141d6e00000000a5
[ 11.919] (II) modeset(0): Printing probed modes for output eDP-1
[ 11.919] (II) modeset(0): Modeline "1366x768"x60.0 76.32 1366 1414 1446 1610 768 771 776 790 +hsync -vsync (47.4 kHz eP)
[ 11.919] (II) modeset(0): Modeline "1366x768"x40.0 50.88 1366 1414 1446 1610 768 771 776 790 +hsync -vsync (31.6 kHz e)
[ 11.919] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 11.919] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 11.919] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 11.919] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 11.919] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 11.920] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 11.920] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 11.920] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 11.920] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 11.920] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 11.920] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 11.920] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 11.920] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 11.920] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 11.920] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 11.920] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 11.920] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 11.920] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 11.920] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 11.920] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 11.920] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 11.920] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 11.920] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 11.920] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 11.920] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 11.920] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 11.920] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 11.920] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 11.920] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 11.920] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 11.920] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 11.920] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 11.920] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 11.921] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 11.921] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 11.921] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 11.921] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 11.921] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 11.921] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 11.924] (II) modeset(0): EDID for output HDMI-1
[ 11.924] (II) modeset(0): Output eDP-1 connected
[ 11.924] (II) modeset(0): Output HDMI-1 disconnected
[ 11.924] (II) modeset(0): Using exact sizes for initial modes
[ 11.924] (II) modeset(0): Output eDP-1 using initial mode 1366x768 +0+0
[ 11.924] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.924] (==) modeset(0): DPI set to (96, 96)
[ 11.924] (II) Loading sub module "fb"
[ 11.924] (II) LoadModule: "fb"
[ 11.924] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.926] (II) Module fb: vendor="X.Org Foundation"
[ 11.926] compiled for 1.20.13, module version = 1.0.0
[ 11.926] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.926] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 11.926] (==) modeset(G0): RGB weight 888
[ 11.926] (==) modeset(G0): Default visual is TrueColor
[ 11.926] (II) Loading sub module "glamoregl"
[ 11.926] (II) LoadModule: "glamoregl"
[ 11.926] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 11.926] (II) Module glamoregl: vendor="X.Org Foundation"
[ 11.926] compiled for 1.20.13, module version = 1.0.1
[ 11.942] (II) modeset(G0): glamor X acceleration enabled on AMD HAINAN (DRM 2.50.0, 5.10.70-1-MANJARO, LLVM 12.0.1)
[ 11.942] (II) modeset(G0): glamor initialized
[ 11.942] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.942] (==) modeset(G0): DPI set to (96, 96)
[ 11.942] (II) Loading sub module "fb"
[ 11.942] (II) LoadModule: "fb"
[ 11.942] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.942] (II) Module fb: vendor="X.Org Foundation"
[ 11.942] compiled for 1.20.13, module version = 1.0.0
[ 11.942] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.942] (II) UnloadModule: "radeon"
[ 11.942] (II) Unloading radeon
[ 12.007] (==) modeset(0): Backing store enabled
[ 12.007] (==) modeset(0): Silken mouse disabled
[ 12.083] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 12.083] (==) modeset(0): DPMS enabled
[ 12.083] (II) modeset(0): [DRI2] Setup complete
[ 12.083] (II) modeset(0): [DRI2] DRI driver: iris
[ 12.083] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 12.108] (==) modeset(G0): Backing store enabled
[ 12.108] (==) modeset(G0): Silken mouse disabled
[ 12.108] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 12.108] (==) modeset(G0): DPMS enabled
[ 12.109] (II) modeset(G0): [DRI2] Setup complete
[ 12.109] (II) modeset(G0): [DRI2] DRI driver: radeonsi
[ 12.109] (II) modeset(G0): [DRI2] VDPAU driver: radeonsi
[ 12.109] (II) Initializing extension Generic Event Extension
[ 12.109] (II) Initializing extension SHAPE
[ 12.109] (II) Initializing extension MIT-SHM
[ 12.110] (II) Initializing extension XInputExtension
[ 12.110] (II) Initializing extension XTEST
[ 12.110] (II) Initializing extension BIG-REQUESTS
[ 12.111] (II) Initializing extension SYNC
[ 12.111] (II) Initializing extension XKEYBOARD
[ 12.111] (II) Initializing extension XC-MISC
[ 12.112] (II) Initializing extension SECURITY
[ 12.112] (II) Initializing extension XFIXES
[ 12.112] (II) Initializing extension RENDER
[ 12.113] (II) Initializing extension RANDR
[ 12.113] (II) Initializing extension COMPOSITE
[ 12.114] (II) Initializing extension DAMAGE
[ 12.114] (II) Initializing extension MIT-SCREEN-SAVER
[ 12.114] (II) Initializing extension DOUBLE-BUFFER
[ 12.115] (II) Initializing extension RECORD
[ 12.115] (II) Initializing extension DPMS
[ 12.115] (II) Initializing extension Present
[ 12.116] (II) Initializing extension DRI3
[ 12.116] (II) Initializing extension X-Resource
[ 12.116] (II) Initializing extension XVideo
[ 12.117] (II) Initializing extension XVideo-MotionCompensation
[ 12.117] (II) Initializing extension GLX
[ 12.137] (II) AIGLX: Loaded and initialized iris
[ 12.137] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 12.137] (II) Initializing extension XFree86-VidModeExtension
[ 12.137] (II) Initializing extension XFree86-DGA
[ 12.138] (II) Initializing extension XFree86-DRI
[ 12.138] (II) Initializing extension DRI2
[ 12.138] (II) modeset(G0): Damage tracking initialized
[ 12.139] (II) modeset(0): Damage tracking initialized
[ 12.139] (II) modeset(0): Setting screen physical size to 361 x 203
[ 12.222] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 12.222] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 12.222] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 12.222] (**) Power Button: Applying InputClass "system-keyboard"
[ 12.222] (II) LoadModule: "libinput"
[ 12.222] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 12.229] (II) Module libinput: vendor="X.Org Foundation"
[ 12.229] compiled for 1.20.13, module version = 1.2.0
[ 12.229] Module class: X.Org XInput Driver
[ 12.229] ABI class: X.Org XInput driver, version 24.1
[ 12.229] (II) Using input driver 'libinput' for 'Power Button'
[ 12.229] (**) Power Button: always reports core events
[ 12.229] (**) Option "Device" "/dev/input/event1"
[ 12.229] (**) Option "_source" "server/udev"
[ 12.249] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 12.250] (II) event1 - Power Button: device is a keyboard
[ 12.250] (II) event1 - Power Button: device removed
[ 12.276] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 12.276] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 12.276] (**) Option "xkb_layout" "latam"
[ 12.313] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 12.313] (II) event1 - Power Button: device is a keyboard
[ 12.314] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 12.314] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 12.314] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 12.314] (**) Video Bus: Applying InputClass "system-keyboard"
[ 12.314] (II) Using input driver 'libinput' for 'Video Bus'
[ 12.314] (**) Video Bus: always reports core events
[ 12.314] (**) Option "Device" "/dev/input/event7"
[ 12.314] (**) Option "_source" "server/udev"
[ 12.316] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 12.316] (II) event7 - Video Bus: device is a keyboard
[ 12.316] (II) event7 - Video Bus: device removed
[ 12.369] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9/event7"
[ 12.369] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 12.369] (**) Option "xkb_layout" "latam"
[ 12.372] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 12.372] (II) event7 - Video Bus: device is a keyboard
[ 12.374] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 12.375] (II) No input driver specified, ignoring this device.
[ 12.375] (II) This device may have been added with another device file.
[ 12.377] (II) config/udev: Adding input device KYE SYSTEMS CORP. Wired Mouse (/dev/input/event8)
[ 12.378] (**) KYE SYSTEMS CORP. Wired Mouse: Applying InputClass "evdev pointer catchall"
[ 12.378] (**) KYE SYSTEMS CORP. Wired Mouse: Applying InputClass "libinput pointer catchall"
[ 12.378] (II) Using input driver 'libinput' for 'KYE SYSTEMS CORP. Wired Mouse'
[ 12.378] (**) KYE SYSTEMS CORP. Wired Mouse: always reports core events
[ 12.378] (**) Option "Device" "/dev/input/event8"
[ 12.378] (**) Option "_source" "server/udev"
[ 12.436] (II) event8 - KYE SYSTEMS CORP. Wired Mouse: is tagged by udev as: Mouse
[ 12.436] (II) event8 - KYE SYSTEMS CORP. Wired Mouse: device is a pointer
[ 12.437] (II) event8 - KYE SYSTEMS CORP. Wired Mouse: device removed
[ 12.489] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:0458:0186.0001/input/input12/event8"
[ 12.489] (II) XINPUT: Adding extended input device "KYE SYSTEMS CORP. Wired Mouse" (type: MOUSE, id 8)
[ 12.490] (**) Option "AccelerationScheme" "none"
[ 12.490] (**) KYE SYSTEMS CORP. Wired Mouse: (accel) selected scheme none/0
[ 12.490] (**) KYE SYSTEMS CORP. Wired Mouse: (accel) acceleration factor: 2.000
[ 12.490] (**) KYE SYSTEMS CORP. Wired Mouse: (accel) acceleration threshold: 4
[ 12.549] (II) event8 - KYE SYSTEMS CORP. Wired Mouse: is tagged by udev as: Mouse
[ 12.550] (II) event8 - KYE SYSTEMS CORP. Wired Mouse: device is a pointer
[ 12.552] (II) config/udev: Adding input device KYE SYSTEMS CORP. Wired Mouse (/dev/input/mouse1)
[ 12.552] (II) No input driver specified, ignoring this device.
[ 12.552] (II) This device may have been added with another device file.
[ 12.554] (II) config/udev: Adding input device HP TrueVision HD: HP TrueVision (/dev/input/event16)
[ 12.554] (**) HP TrueVision HD: HP TrueVision: Applying InputClass "evdev keyboard catchall"
[ 12.554] (**) HP TrueVision HD: HP TrueVision: Applying InputClass "libinput keyboard catchall"
[ 12.554] (**) HP TrueVision HD: HP TrueVision: Applying InputClass "system-keyboard"
[ 12.554] (II) Using input driver 'libinput' for 'HP TrueVision HD: HP TrueVision'
[ 12.554] (**) HP TrueVision HD: HP TrueVision: always reports core events
[ 12.554] (**) Option "Device" "/dev/input/event16"
[ 12.554] (**) Option "_source" "server/udev"
[ 12.558] (II) event16 - HP TrueVision HD: HP TrueVision: is tagged by udev as: Keyboard
[ 12.558] (II) event16 - HP TrueVision HD: HP TrueVision: device is a keyboard
[ 12.558] (II) event16 - HP TrueVision HD: HP TrueVision: device removed
[ 12.609] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input18/event16"
[ 12.609] (II) XINPUT: Adding extended input device "HP TrueVision HD: HP TrueVision" (type: KEYBOARD, id 9)
[ 12.609] (**) Option "xkb_layout" "latam"
[ 12.613] (II) event16 - HP TrueVision HD: HP TrueVision: is tagged by udev as: Keyboard
[ 12.613] (II) event16 - HP TrueVision HD: HP TrueVision: device is a keyboard
[ 12.615] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[ 12.616] (II) No input driver specified, ignoring this device.
[ 12.616] (II) This device may have been added with another device file.
[ 12.617] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event10)
[ 12.617] (II) No input driver specified, ignoring this device.
[ 12.617] (II) This device may have been added with another device file.
[ 12.618] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[ 12.618] (II) No input driver specified, ignoring this device.
[ 12.618] (II) This device may have been added with another device file.
[ 12.619] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event12)
[ 12.619] (II) No input driver specified, ignoring this device.
[ 12.619] (II) This device may have been added with another device file.
[ 12.620] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event13)
[ 12.620] (II) No input driver specified, ignoring this device.
[ 12.620] (II) This device may have been added with another device file.
[ 12.621] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event14)
[ 12.621] (II) No input driver specified, ignoring this device.
[ 12.621] (II) This device may have been added with another device file.
[ 12.622] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event15)
[ 12.622] (II) No input driver specified, ignoring this device.
[ 12.622] (II) This device may have been added with another device file.
[ 12.624] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 12.624] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 12.624] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 12.624] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 12.624] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 12.624] (**) AT Translated Set 2 keyboard: always reports core events
[ 12.624] (**) Option "Device" "/dev/input/event2"
[ 12.624] (**) Option "_source" "server/udev"
[ 12.627] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 12.627] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 12.628] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 12.676] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 12.676] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 12.676] (**) Option "xkb_layout" "latam"
[ 12.679] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 12.679] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 12.682] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 12.682] (II) No input driver specified, ignoring this device.
[ 12.682] (II) This device may have been added with another device file.
[ 12.690] (II) config/udev: Adding input device Synaptics TM3127-001 (/dev/input/event6)
[ 12.690] (**) Synaptics TM3127-001: Applying InputClass "evdev touchpad catchall"
[ 12.690] (**) Synaptics TM3127-001: Applying InputClass "libinput touchpad catchall"
[ 12.690] (**) Synaptics TM3127-001: Applying InputClass "touchpad"
[ 12.690] (II) Using input driver 'libinput' for 'Synaptics TM3127-001'
[ 12.690] (**) Synaptics TM3127-001: always reports core events
[ 12.690] (**) Option "Device" "/dev/input/event6"
[ 12.690] (**) Option "_source" "server/udev"
[ 12.692] (II) event6 - Synaptics TM3127-001: is tagged by udev as: Touchpad
[ 12.695] (II) event6 - Synaptics TM3127-001: device is a touchpad
[ 12.695] (II) event6 - Synaptics TM3127-001: device removed
[ 12.756] (**) Option "Tapping" "on"
[ 12.757] (**) Option "config_info" "udev:/sys/devices/rmi4-00/input/input8/event6"
[ 12.757] (II) XINPUT: Adding extended input device "Synaptics TM3127-001" (type: TOUCHPAD, id 11)
[ 12.759] (**) Option "AccelerationScheme" "none"
[ 12.759] (**) Synaptics TM3127-001: (accel) selected scheme none/0
[ 12.759] (**) Synaptics TM3127-001: (accel) acceleration factor: 2.000
[ 12.759] (**) Synaptics TM3127-001: (accel) acceleration threshold: 4
[ 12.761] (II) event6 - Synaptics TM3127-001: is tagged by udev as: Touchpad
[ 12.764] (II) event6 - Synaptics TM3127-001: device is a touchpad
[ 12.765] (II) config/udev: Adding input device Synaptics TM3127-001 (/dev/input/mouse0)
[ 12.766] (**) Synaptics TM3127-001: Applying InputClass "touchpad"
[ 12.766] (II) Using input driver 'libinput' for 'Synaptics TM3127-001'
[ 12.766] (**) Synaptics TM3127-001: always reports core events
[ 12.766] (**) Option "Device" "/dev/input/mouse0"
[ 12.766] (**) Option "_source" "server/udev"
[ 12.849] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 12.849] (EE) libinput: Synaptics TM3127-001: Failed to create a device for /dev/input/mouse0
[ 12.849] (EE) PreInit returned 2 for "Synaptics TM3127-001"
[ 12.849] (II) UnloadModule: "libinput"
[ 12.850] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event3)
[ 12.851] (**) HP Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[ 12.851] (**) HP Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[ 12.851] (**) HP Wireless hotkeys: Applying InputClass "system-keyboard"
[ 12.851] (II) Using input driver 'libinput' for 'HP Wireless hotkeys'
[ 12.851] (**) HP Wireless hotkeys: always reports core events
[ 12.851] (**) Option "Device" "/dev/input/event3"
[ 12.851] (**) Option "_source" "server/udev"
[ 12.852] (II) event3 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 12.852] (II) event3 - HP Wireless hotkeys: device is a keyboard
[ 12.853] (II) event3 - HP Wireless hotkeys: device removed
[ 12.916] (**) Option "config_info" "udev:/sys/devices/virtual/input/input4/event3"
[ 12.916] (II) XINPUT: Adding extended input device "HP Wireless hotkeys" (type: KEYBOARD, id 12)
[ 12.916] (**) Option "xkb_layout" "latam"
[ 12.918] (II) event3 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 12.918] (II) event3 - HP Wireless hotkeys: device is a keyboard
[ 12.920] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event5)
[ 12.920] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 12.920] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 12.920] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[ 12.920] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 12.920] (**) HP WMI hotkeys: always reports core events
[ 12.920] (**) Option "Device" "/dev/input/event5"
[ 12.920] (**) Option "_source" "server/udev"
[ 12.922] (II) event5 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 12.922] (II) event5 - HP WMI hotkeys: device is a keyboard
[ 12.922] (II) event5 - HP WMI hotkeys: device removed
[ 12.956] (**) Option "config_info" "udev:/sys/devices/virtual/input/input7/event5"
[ 12.956] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 13)
[ 12.956] (**) Option "xkb_layout" "latam"
[ 12.958] (II) event5 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 12.958] (II) event5 - HP WMI hotkeys: device is a keyboard
[ 14.715] (EE) event6 - Synaptics TM3127-001: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.19.1/touchpad-jumping-cursors.html for details
[ 19.764] (II) modeset(0): EDID vendor "LGD", prod id 1283
[ 19.764] (II) modeset(0): Printing DDC gathered Modelines:
[ 19.764] (II) modeset(0): Modeline "1366x768"x0.0 76.32 1366 1414 1446 1610 768 771 776 790 +hsync -vsync (47.4 kHz eP)
[ 19.764] (II) modeset(0): Modeline "1366x768"x0.0 50.88 1366 1414 1446 1610 768 771 776 790 +hsync -vsync (31.6 kHz e)
[ 22.052] (II) modeset(0): EDID vendor "LGD", prod id 1283
[ 22.052] (II) modeset(0): Printing DDC gathered Modelines:
[ 22.052] (II) modeset(0): Modeline "1366x768"x0.0 76.32 1366 1414 1446 1610 768 771 776 790 +hsync -vsync (47.4 kHz eP)
[ 22.052] (II) modeset(0): Modeline "1366x768"x0.0 50.88 1366 1414 1446 1610 768 771 776 790 +hsync -vsync (31.6 kHz e)
And mhw -l output
> 0000:01:00.0 (0380:1002:6660) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
> 0000:00:02.0 (0300:8086:1916) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
What steps should I follow now? I tried switching to LTS kernel, same result. I’m using an Intel/amd hybrid system on a laptop.
