AMD CPU and Radeon graphics card.
Kernel 5.10.123 LTS boots and runs perfectly.
After upgrade to 5.15 LTS, system boots and I can log in normally but system crashes within the first few minutes. REISUB to shut down does not work, have to reset.
Tried all the other kernel versions later than 5.10.123 LTS and they all do the same.
Any suggestions?
can you report
inxi -Fza
have you checked your log journal on boot 5.15 ?
see with
sudo journalctl -bn (n=0 current , -1 boot before etc ... )
Thank you for the reply.
Result of inxi -Fza:
Kernel: 5.10.123-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=e0934903-6ca8-4514-a731-8babda0d79b0 rw quiet
resume=UUID=a51794b0-eee5-46ee-af32-171e43ed85c9
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: A320M PRO-M2 V2 (MS-7B84) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: 3.10
date: 01/30/2019
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2510 high: 2986 min/max: N/A cores: 1: 2403 2: 2569
3: 2408 4: 2376 5: 2411 6: 2413 7: 2412 8: 2411 9: 2407 10: 2421 11: 2909
12: 2986 bogomips: 97229
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DP-2,HDMI-A-2 empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 1f:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: Dell P2214H
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,left
model: Dell SE2717H/HX serial: <filter> built: 2018 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 1f:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.123-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 1b:00.0
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.04 TiB used: 125.09 GiB (4.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX900 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: R1115D0
temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: TS64GSSD720
size: 59.63 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Hikvision model: HS-SSD-E100 1024G
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 8A0 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: MBR
ID-5: /dev/sdg maj-min: 8:96 type: USB vendor: Generic
model: STORAGE DEVICE size: 7.41 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 9744 scheme: MBR
ID-1: / raw-size: 59.62 GiB size: 59.6 GiB (99.95%) used: 41.26 GiB (69.2%)
fs: xfs dev: /dev/sda1 maj-min: 8:1
used: 25.5 MiB (26.5%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 507.81 GiB size: 507.56 GiB (99.95%)
used: 83.81 GiB (16.5%) fs: xfs dev: /dev/sdc3 maj-min: 8:35
ID-1: swap-1 type: partition size: 33.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc4 maj-min: 8:36
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1072
Processes: 317 Uptime: 8m wakeups: 0 Memory: 15.64 GiB
used: 1.52 GiB (9.7%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1707
lib: 481 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.19
IN BIOS: activate “Typical Current Idle” may help…
– If the system saves too much power even though more power is needed…
you can check for update UEFI motherboard ( not the beta version )
https://www.msi.com/Motherboard/A320M-PRO-M2-V2/support
you can also add theses parameters on boot
in /etc/default/grub
on line GRUB_CMDLINE_LINUX_DEFAULT=
amd_iommu=on iommu=pt processor.max_cstate=5 rcu_nocbs=0_11 systemd.unified_cgroup_hierarchy=true scsi_mod.use_blk_mq=1
