Alsamixer and amixer command not working
Hello!
I have no idea of why that happened, but I’ve used alsamixer command to change my ALSA sound card settings recently, but with no success. I did that some weeks ago and It worked.
I have no idea of what logs to put here, so if anything is required, ask me.
What may be causing that?
Thanks!
Did you change ALSA settings in alsamixer but the settings were not restored correctly when you rebooted system?
If that is the case, use this command to save ALSA settings after using alsamixer
sudo alsactl store
No, this is not my problem. I just can’t use alsamixer to change the settings, It shows me “the host is down”, returns and I can’t change anything.
Please post system information
inxi-Fazy
and ALSA information
sudo alsa.info.sh --upload
I’m sorry I don’t have that command on my system…
UPDATE: It’s here, and its called alsa-info.sh: http://alsa-project.org/db/?f=0c559cf95e8cc6b885804c808a1603e7d60ff955
inxi -Fazy reports this:
inxi -Fazy
Kernel: 5.11.16-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=b7b6829b-5b8c-415d-839a-746e7322d7d6 ro udev.log_priority=3
bootsplash.bootfile=/bootsplash-themes/inky/bootsplash
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: Gigabyte model: H310M DS2 v: x.x serial:
UEFI: American Megatrends v: F11 date: 09/18/2018
Info: 6-Core model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
cache: L2: 12 MiB
bogomips: 76831
Speed: 1200 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 1200 2: 2481
3: 1200 4: 1200 5: 928 6: 1200 7: 2531 8: 1200 9: 2736 10: 1200 11: 1199
12: 1200
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Gigabyte driver: nvidia
v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c81 class-ID: 0300
Device-2: Pixart Imaging GE 1.3 MP MiniCam Pro type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5:5 chip-ID: 093a:2700
class-ID: 0102
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1200 s-dpi: 93 s-size: 524x321mm (20.6x12.6")
s-diag: 615mm (24.2")
Monitor-1: DVI-D-0 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: Pixart Imaging GE 1.3 MP MiniCam Pro type: USB
class-ID: 0102
Sound Server-1: ALSA v: k5.11.16-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.18 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.26 running: no
Device-1: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8812
class-ID: 0280
IF: wlp2s0 state: down mac:
vendor: Gigabyte driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: docker0 state: down mac:
Local Storage: total: 3.4 TiB used: 547.82 GiB (15.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: rev: CC29 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD5000BEVT-22A0RT0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: rev: 1A01
scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
rotation: 5400 rpm serial: scheme: GPT
ID-1: / raw-size: 220.58 GiB size: 216.61 GiB (98.20%)
used: 129.22 GiB (59.7%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 488 MiB size: 487 MiB (99.80%)
used: 42.1 MiB (8.7%) fs: vfat dev: /dev/sda5 maj-min: 8:5
ID-1: swap-1 type: partition size: 1.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 68.0 C mobo: 27.8 C gpu: nvidia temp: 58 C
Processes: 311 Uptime: 29m wakeups: 0 Memory: 15.57 GiB
used: 3.78 GiB (24.3%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1951 lib: 511 Shell: Bash
v: 5.1.0 running-in: konsole inxi: 3.3.04
