ALSA Restore Service not restoring Sound correctly
Hey guys,
I have installed Manjaro GNOME on my desktop pc with 5.14.7-2 kernel version (dual boot with windows 10, fastboot disabled). I have plugged in speakers on the back of my case and headphones on the front panel. Also my monitor has built-in speakers which are connected via DisplayPort. Now to the problem:
The speakers are always muted when I start manjaro. I have to manually run alsamixer select my audio card and unmute “Front”. Then it works normally. Saving alsa settings with alsactl store does not work, I don’t get any error but speaker sound is muted again after reboot (running alsamixer or alsactl store or both as su, doesn’t change anything).
When I run sudo alsactl restore manually, it successfully restores the settings, but I get the following warning/error messages:
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HD-Audio Generic at 0xfc400000 irq 81)
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xfc080000 irq 79)
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:2 use case configuration -2
This is my hardware:
Mainboard Gigabyte Aorus Pro AX (Audio Chip: ALC1220)
Processor AMD Ryzen 5600x
This is the inxi -aA result:
Audio:     Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus-ID: 06:00.1 chip-ID: 10de:10f0 class-ID: 0403
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel
           v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
           Device-3: Logitech StreamCam type: USB driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-1.4:7
           chip-ID: 046d:0893 class-ID: 0300 serial: 77047235
           Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.37 running: no
Has anybody an idea what the exact problem could be?
I think it’s kinda related to this topic: “Alsa-restore is driving me crazy” (cannot copy a link, sorry). The solution/workaround suggested is not working for me unfortunately.Dieser Text wird ausgeblendet
can you try
alsactl init
I’ve got the exact same problem since a few weeks : I have to manually execute sudo alsactl restore after each reboot to unmute the front speakers. This happened after a normal packages update (wouldn’t be able to tell which particular update triggered this issue).
I use the onboard sound card of my mainboard (Intel PCH) :
cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf7230000 irq 41
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xf7080000 irq 17
2 [C920 ]: USB-Audio - HD Pro Webcam C920
HD Pro Webcam C920 at usb-0000:00:14.0-14, high speed
It seems that the service alsa-restore is not doing its job despite saying otherwise :
systemctl status alsa-restore.service
● alsa-restore.service - Save/Restore Sound Card State
Loaded: loaded (/usr/lib/systemd/system/alsa-restore.service; static)
Active: active (exited) since Sat 2021-10-02 14:15:52 CEST; 4h 15min ago
Main PID: 500 (code=exited, status=0/SUCCESS)
CPU: 2ms
oct. 02 14:15:52 blackhole systemd[1]: Starting Save/Restore Sound Card State…
oct. 02 14:15:52 blackhole alsactl[500]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xf7080000 irq 17)
oct. 02 14:15:52 blackhole alsactl[500]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
oct. 02 14:15:52 blackhole systemd[1]: Finished Save/Restore Sound Card State.
Here is the ouput of alsactl init :
sudo alsactl init [130]
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH at 0xf7230000 irq 41)
Found hardware: “HDA-Intel” “Realtek ALC1150” “HDA:10ec0900,1458a182,00100001” “0x1458” “0xa182”
Hardware is initialized using a generic method
Found hardware: “HDA-Intel” “Nvidia GPU 71 HDMI/DP” “HDA:10de0071,10438508,00100100” “0x1043” “0x8508”
Found hardware: “USB-Audio” “USB Mixer” “USB046d:08e5” “” “”
a work around could be to put the restore command to autostart
this is the result of alsactl init:
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HD-Audio Generic at 0xfc400000 irq 95)
Found hardware: "HDA-Intel" "Realtek ALC1220" "HDA:10ec1220,1458a0c3,00100101" "0x1458" "0xa0c3"
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xfc080000 irq 93)
Found hardware: "HDA-Intel" "Nvidia GPU 83 HDMI/DP" "HDA:10de0083,14623362,00100100" "0x1462" "0x3362"
Found hardware: "USB-Audio" "USB Mixer" "USB046d:0893" "" ""
It didn’t change anything unfortunately.
@darkcity : I tried that already but somehow it also does not work. I created a .desktop file inside of ~/.config/autostart with the following content:
[Desktop Entry]
Type=Application
Exec=sleep 10 && alsactl --file /home/chris/.config/asound.state restore
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
Name[de_DE]=Manuelles Wiederherstellen der ALSA-Einstellungen
Name=Manual Alsa Settings Restore
Comment[de_DE]=
Comment=
It’s weird because when I run the command in terminal it just works fine. My ImWheel.desktop file looks the same, is in the same directory has the same access rights and works. Has somebody a clue what’s wrong with the .desktop file?
I think it is because commands in Exec= aren’t executed in the same way as I line of bash in the terminal or a script file.
As per
https://askubuntu.com/questions/461434/lubuntu-how-to-execute-2-commands-in-desktop-file
So in your case something like
Exec=sh -c "sleep 10 && alsactl --file /home/chris/.config/asound.state restore"
I also have the same issue, but with a Creative AE-5 Soundcard:
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH at 0xef440000 irq 147)
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xef080000 irq 17)
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Creative at 0xef204000 irq 16)
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:2 use case configuration -6
Thanks, atleast the workaround seems to work for now.
I don’t know if I should mark your answer as the solution or if I should let the thread open since it’s “just” a workaround.
I’d let the thread continue, as a there is probably someone who can explain why the problem is happening.
Have you tried clearing file /var/lib/alsa/asound.state?
Removing old ALSA state file (asound.state) –Advanced Linux Sound Architecture/Troubleshooting
It might help to retain file /etc/alsa/state-daemon.conf to prevent system saving changes to ALSA settings during shutdown
Please post data to show ALSA audio settings for both
  1. non-working state after system booted
  2. corrected state with speakers unmuted
amixer --card=1
I’ve just joined the forums as I’ve been having the same problems as the OP. System is a Ryzen 3900X, Gigabyte X470 Aorus Gaming 7 wifi and a RTX3080. Like the OP I dual boot with Windows 10, but I have to run alsamixer and unmute.
uname -a
Linux Manjaro 5.13.19-2-MANJARO #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021 x86_64 GNU/Linux
Result of initialising Alsa:
alsactl init
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xfc080000 irq 119)
Found hardware: “HDA-Intel” “Nvidia GPU 9a HDMI/DP” “HDA:10de009a,10de1467,00100100” “0x10de” “0x1467”
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HD-Audio Generic at 0xfc900000 irq 121)
Found hardware: “HDA-Intel” “Realtek ALC1220” “HDA:10ec1220,1458a0cc,00100101” “0x1458” “0xa0cc”
Found hardware: “USB-Audio” “USB Mixer” “USB046d:082d” “” “”
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:3 use case configuration -2
Found hardware: “USB-Audio” “USB Mixer” “USB1852:7022” “” “”
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:4 use case configuration -2
Found hardware: “USB-Audio” “USB Mixer” “USBb58e:9e84” “” “”
0 [NVidia ]: HDA-Intel - HDA NVidia
1 [Generic ]: HDA-Intel - HD-Audio Generic
HD Pro Webcam C920 at usb-0000:0d:00.3-1, high speed
3 [Audio ]: USB-Audio - DigiHug USB Audio
FiiO DigiHug USB Audio at usb-0000:0d:00.3-3, full speed
4 [Microphone ]: USB-Audio - Yeti Stereo Microphone
Blue Microphones Yeti Stereo Microphone at usb-0000:0d:00.3-4.1, full speed
Output from amixer with the audio working (despite the mixer control being ‘headphone’ I actually have speakers connected to the audio line out on my motherboard). When I run alsamixer, the default ‘card’ is PulseAudio, F6 and choose card 1, the onboard sound. Then I unmute the ‘headphone’ channel and raise the volume, exit alsamixer and sound works:
amixer --card=1
Simple mixer control ‘Master’,0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 60 [69%] [-20.25dB] [on]
Simple mixer control ‘Headphone’,0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘PCM’,0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control ‘Front’,0
Mono:
Simple mixer control ‘Front Mic’,0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control ‘Front Mic Boost’,0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control ‘Surround’,0
Mono:
Simple mixer control ‘Center’,0
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘LFE’,0
Simple mixer control ‘Line’,0
Mono:
Front Left: Playback 31 [100%] [12.00dB] [on]
Front Right: Playback 31 [100%] [12.00dB] [on]
Simple mixer control ‘Line Boost’,0
Limits: 0 - 3
Simple mixer control ‘IEC958’,0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control ‘IEC958 Default PCM’,0
Mono: Playback [on]
Simple mixer control ‘Capture’,0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control ‘Capture’,1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control ‘Auto-Mute Mode’,0
Capabilities: enum
Items: ‘Disabled’ ‘Enabled’
Item0: ‘Enabled’
Simple mixer control ‘Input Source’,0
Capabilities: cenum
Items: ‘Front Mic’ ‘Rear Mic’ ‘Line’
Item0: ‘Rear Mic’
Simple mixer control ‘Input Source’,1
Capabilities: cenum
Item0: ‘Front Mic’
Simple mixer control ‘Loopback Mixing’,0
Capabilities: enum
Item0: ‘Disabled’
Simple mixer control ‘Rear Mic’,0
Mono:
Simple mixer control ‘Rear Mic Boost’,0
Limits: 0 - 3
Output from amixer with the audio muted upon reboot:
amixer --card=1
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Mono:
Mono:
Mono:
Limits: 0 - 3
Mono:
Mono:
Limits: 0 - 3
Mono: Playback [on]
Capabilities: enum
Item0: ‘Enabled’
Capabilities: cenum
Item0: ‘Rear Mic’
Capabilities: cenum
Item0: ‘Front Mic’
Capabilities: enum
Item0: ‘Disabled’
Mono:
Limits: 0 - 3
Is it an issue with Pulseaudio muting Alsa or is there an issue with the Realtek ALC1220 in Manjaro?
Thanks for any help, I’d really like to not have to run alsamixer to fix it!
ALSA settings in amixer show that Auto-Mute Mode is enabled, and that might be causing the headphone jack to be muted when system is booted
Auto-Mute Mode is useful for laptop syatems so that built-in speakers are muted when headphones are plugged in, but it can be an annoyance for desktop
Use this command to disable the Auto-Mute
amixer --card=1 sset ‘Auto-Mute Mode’ Disabled
The Headphone output might automatically unmute and restore audio level once the auto-mute is disabled. But if it does not, use this command to set the audio level and unmute
amixer --card=1 sset ‘Headphone’ 87 unmute
Thanks for the reply, yes I had noticed that and I am able to resolve the problem by unmuting the headphones and raising the volume level by running alsamixer - which appears to be doing exactly the same as your suggestion but just using a different tool?
I have tried using amixer as you suggested instead, it seems to run without any errors, but when I reboot the audio is still muted again. I tried running
alsactl store
To see if that would make the changes permanent but it hasn’t seemed to have any effect, as the audio is muted again on reboot :frowning_face:
I wonder if there is a user account setting somewhere overriding the attempts to retain audio unmuted on boot?
You could try making a temp user and using the alsa store command, then rebooting to that temp user.
Hello,
I also have the same problem for a few weeks. The problem appeared after the alsa-lib update:
[2021-06-14T17:20:20+0200] [ALPM] upgraded lib32-alsa-lib (1.2.4-2 → 1.2.5-2)
[2021-06-14T17:20:11+0200] [ALPM] upgraded alsa-lib (1.2.4-3 → 1.2.5-2)
I’m using the Cinnamon Edition (Cinnamon 5.0.5)
systemctl status alsa-restore.service:
Active: active (exited) since Wed 2021-10-13 06:44:04 CEST; 5min ago
Process: 4075 ExecStart=/usr/bin/alsactl restore (code=exited, status=0/SUCCESS)
Main PID: 4075 (code=exited, status=0/SUCCESS)
CPU: 5ms
Okt 13 06:44:04 obelix systemd[1]: Starting Save/Restore Sound Card State…
Okt 13 06:44:04 obelix alsactl[4075]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel HDMI >
Okt 13 06:44:04 obelix alsactl[4075]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configur>
Okt 13 06:44:04 obelix alsactl[4075]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH a>
Okt 13 06:44:04 obelix alsactl[4075]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configur>
Okt 13 06:44:04 obelix alsactl[4075]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0>
Okt 13 06:44:04 obelix alsactl[4075]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:2 use case configur>
Okt 13 06:44:04 obelix systemd[1]: Finished Save/Restore Sound Card State.
alsactl init:
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel HDMI at 0xf7b14000 irq 39)
Found hardware: “HDA-Intel” “Intel Haswell HDMI” “HDA:80862807,80860101,00100000” “0x8086” “0x2010”
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH at 0xf7b10000 irq 37)
Found hardware: “HDA-Intel” “Creative Recon3Di” “HDA:11020011,1458a026,00100918” “0x1458” “0xa026”
Found hardware: “HDA-Intel” “Nvidia GPU 40 HDMI/DP” “HDA:10de0040,1458360b,00100100” “0x1458” “0x360b”
inxi -aA:
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 9 Series Family HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8ca0 class-ID: 0403
Device-3: NVIDIA GK104 HDMI Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0e0a class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
CPU: Quad Core Intel Core i5-4670K (-MCP-)
Mainboard: Gigabyte Technology Co., Ltd. G1.Sniper Z97/G1.Sniper Z97, BIOS F8 09/19/2015
This is still an issue for me. Did any one solve this?
Preferable without a workaround (especially none with a sleep, I don’t want a race condition)
