ALSA Monitor Retry Loop Creates a Failed Duplicate HDMI Sink
After upgrading WirePlumber from 0.5.15-1 to 0.5.16-1, the ALSA monitor repeatedly attempted to create a second node for an already-active HDMI output.
wplua: [string "alsa.lua"]:446: attempt to call a nil value (method 'store_managed_pending')
Observed behavior
Before service restart:
The HDMI output was the default sink, unmuted, and set to 14%.
Firefox playback was routed to that HDMI output.
PipeWire exposed two HDMI sinks with the same node.name.
The valid sink was running, while the extra sink had no state in the PulseAudio view.
PipeWire repeatedly retried creation of alsa_output.pci-0000_04_00.1.hdmi-stereo-extra1-86 approximately every five seconds.
Each retry failed because hdmi:0,1 was busy.
GNOME master-volume changes appeared ineffective during this state
Summary
pipewire[16462]: spa.alsa: 'hdmi:0,1': playback open failed: Device or resource busy
pipewire[16462]: pw.node: (alsa_output.pci-0000_04_00.1.hdmi-stereo-extra1-86) suspended -> error (Start error: Device or resource busy)
wireplumber[16463]: s-monitors: Failed to create ALSA node alsa_output.pci-0000_04_00.1.hdmi-stereo-extra1: Object activation aborted: PipeWire proxy destroyed
wireplumber[16463]: wplua: [string "alsa.lua"]:446: attempt to call a nil value (method 'store_managed_pending')
Recovered master functionality with :
systemctl --user restart wireplumber pipewire pipewire-pulse
Summary
  • WirePlumber: 0.5.16-1
  • Previous WirePlumber version: 0.5.15-1
  • WirePlumber upgrade time: 2026-09-01 16:28:51 +0200
  • PipeWire: 1:1.6.8-1
  • pipewire-audio: 1:1.6.8-1
  • pipewire-pulse: 1:1.6.8-1
  • ALSA library: 1.2.16.1-1
  • ALSA UCM configuration: 1.2.16.1-1
  • ALSA utilities: 1.2.16-1
  • Desktop: GNOME
  • Audio server: PulseAudio (on PipeWire 1.6.8)
  • Active output: Raven/Raven2/Fenghuang HDMI/DP Audio Controller Digital Stereo (HDMI 2) [27P2DG5]
  • Relevant PCM: hdmi:0,1 (/dev/snd/pcmC0D7p)
Summary
  Kernel: 7.2.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    clocksource: hpet avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-7.2-x86_64
    root=UUID=ff1416bb-6075-4ba5-bc47-2584d8a9e41b rw quiet splash apparmor=1
  Desktop: GNOME v: 50.4 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 50.2 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: HP product: HP EliteBook 755 G5 v: SBKPFV3
  Mobo: HP model: 83D5 v: KBC Version 08.63.00 serial: <superuser required>
    part-nu: 3UN79EA#ABZ uuid: <superuser required> Firmware: UEFI vendor: HP
    v: Q81 Ver. 01.29.00 date: 07/01/2025
  ID-1: BAT0 charge: 33.3 Wh (98.5%) condition: 33.8/55.4 Wh (60.9%)
    volts: 11.4 min: 11.55 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> charging: status: not charging cycles: 35
  System RAM: total: 32 GiB available: 30.29 GiB used: 9.81 GiB (32.4%)
  Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 2667 MT/s actual: 2400 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471A2K43DB1-CTD serial: <filter>
  Device-2: Bottom-Slot 2(right) type: DDR4 detail: synchronous unbuffered
    manufacturer: Kingston part-no: 9905663-030.A00G serial: <filter>
  Info: model: AMD Ryzen 7 PRO 2700U w/ Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
    family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
    desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2716 min/max: 1600/3800 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2716 2: 2716 3: 2716
    4: 2716 5: 2716 6: 2716 7: 2716 8: 2716 bogomips: 35132
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
    lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
    svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
    / Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DP-1,eDP-1 empty: DP-2,DP-3
    bus-ID: 04:00.0 chip-ID: 1002:15dd class-ID: 0300 temp: 66.0 C
  Device-2: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-2:3 chip-ID: 04f2:b5e7
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: AOC 27P2DG5 serial: <filter> built: 2025
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.302 y: 0.616 blue: x: 0.149 y: 0.086 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: eDP-1 model: LG Display 0x062e built: 2019 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.369 green: x: 0.349 y: 0.557
    blue: x: 0.153 y: 0.110 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.1-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Vega 10 Graphics (radeonsi raven
    ACO DRM 3.64 7.2.2-1-MANJARO) device-ID: 1002:15dd memory: 1000 MiB
    unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.357 layers: 6 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 10 Graphics (RADV RAVEN) driver: mesa radv v: 26.2.1-arch1.1
    device-ID: 1002:15dd surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-doctor
    gpu: amd-smi x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
    Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k7.2.2-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3300 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  IF-ID-2: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  IF-ID-3: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-4: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.1:4
    chip-ID: 8087:0a2b class-ID: e001
  Device-1: luks-f50d53e0-b9e4-4865-8236-7375d2025439 maj-min: 253:0
    type: LUKS dm: dm-0 size: 754.41 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 754.41 GiB
  Local Storage: total: 931.51 GiB used: 677.14 GiB (72.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: XPG SPECTRIX S20G
    lanes: 4 tech: SSD serial: <filter> fw-rev: VC0S036H temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 175.78 GiB size: 171.96 GiB (97.83%)
    used: 92.24 GiB (53.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: root uuid: ff1416bb-6075-4ba5-bc47-2584d8a9e41b
  ID-2: /boot raw-size: 1000 MiB size: 965.9 MiB (96.59%)
    used: 220.5 MiB (22.8%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: boot uuid: 814fe8fe-da70-4bd5-aaaa-af8a06d4b9cb
  ID-3: /boot/efi raw-size: 350 MiB size: 349.3 MiB (99.80%)
    used: 32.5 MiB (9.3%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: efi
    uuid: 3498-53B1
  ID-4: /home raw-size: 754.41 GiB size: 741.5 GiB (98.29%)
    used: 584.65 GiB (78.8%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-f50d53e0-b9e4-4865-8236-7375d2025439 label: home
    uuid: 4d09c9c7-e876-4eda-8975-c3d66e294054
  Hub-1: 1-0:1 info: full speed or root hub ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 2-1:2 info: Yubicom Yubikey 4/5 U2F type: HID
    lanes: 1 mode: 1.1 power: 30mA chip-ID: 1050:0402 class-ID: 0300
  Device-2: 2-3:3 info: Areson Corp Philips USB Receiver
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 25a7:fa67 class-ID: 0301
  Hub-3: 3-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 4-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 4-1.1:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Device-2: 4-1.3:5 info: Validity Sensors type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 138a:00ab class-ID: ff00 serial: <filter>
  Device-3: 4-2:3 info: Chicony HP HD Camera type: video driver: uvcvideo
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b5e7 class-ID: 0e02 serial: <filter>
  Hub-6: 5-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 67.0 C mobo: N/A gpu: amdgpu temp: 66.0 C
  Fan Speeds (rpm): N/A
  Packages: 2991 pm: pacman pkgs: 2955 libs: 613 tools: gnome-software,
    octopi, pamac, yay pm: rpm pkgs: 0 pm: flatpak pkgs: 36
    1: https://ftp.lysator.liu.se/pub/manjaro/unstable/$repo/$arch
    2: https://distrohub.kyiv.ua/manjaro/unstable/$repo/$arch
    3: https://ohioix.mm.fcix.net/manjaro/unstable/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/unstable/$repo/$arch
    5: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
    6: https://mirror.fcix.net/manjaro/unstable/$repo/$arch
    7: https://mirror.xeonbd.com/manjaro/unstable/$repo/$arch
    8: https://gsl-syd.mm.fcix.net/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 402
  1: cpu: 200% command: ps pid: 413371 mem: 3.93 MiB (0.0%)
  2: cpu: 40.4% command: gnome-shell pid: 5161 mem: 501.1 MiB (1.6%)
  3: cpu: 34.6% command: firefox pid: 62767 mem: 1521.6 MiB (4.9%)
  4: cpu: 18.9% command: firefox pid: 63236 mem: 92.8 MiB (0.2%)
  5: cpu: 7.7% command: firefox pid: 208659 mem: 546.9 MiB (1.7%)
  Memory top: 5 of 402
  1: mem: 1576.8 MiB (5.0%) command: clamd pid: 1023 cpu: 0.8%
  2: mem: 1521.6 MiB (4.9%) command: firefox pid: 62767 cpu: 34.6%
  3: mem: 849.1 MiB (2.7%) command: QtWebEngineProcess pid: 9032 cpu: 1.1%
  4: mem: 708.9 MiB (2.2%) command: firefox pid: 63754 cpu: 3.8%
  5: mem: 644.2 MiB (2.0%) command: firefox pid: 91373 cpu: 6.1%
  Processes: 402 Power: uptime: 1h 23m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.03 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.8 gcc: 16.2.1 alt: 14 Shell: Bash v: 5.3.15
    running-in: kgx inxi: 3.3.41
Mod note:- Instead of the default Summary appearing in disclosure elements, you can add your own short text… :eyes:
Something like this:
[details="Look, look, it works..."]
Content here...
[/details]
Noted @soundofthunder
Second occurrence after an idle period
After the audio path remained idle for several hours, the master-volume control stopped affecting playback and three HDMI sink objects were present for the same ALSA endpoint. The primary sink was running while two duplicate sinks were suspended. No matching WirePlumber error was recorded during this occurrence, so it should be reported as a suspected recurrence of the morning failure, not as an identical confirmed error.
No, seriously now @Aragorn, who can I bug about this, reporting a bug? It’s the third occurrence this morning with the difference that in this 3rd occurrence the system soundless. I looked in the developers section but haven’t seen something suitable for that.
Well, apart from the local audio expert (@nikgnomic) there isn’t anyone I know who would be able to dig very deep into this. The packages themselves all come straight from Arch, with the exception of manjaro-pipewire, which is packaged by @Yochanan, but that’s only a metapackage, which pulls in everything else needed.
All I can say is that pipewire.{service,socket}, pipewire-pulse.{service,socket} and wireplumber.service all run under your user’s UID, which means that the problem must be located somewhere in your home directory.
:man_shrugging:
Addendum: Audio over HDMI has always been problematic in GNU/Linux. Better is to connect your speakers to the Line Out of your sound adapter, if possible.
@libertypo In this case I’d suggest setting up a second user account and see if the problem still occurs there. :wink:
Sensible advice but, before that, I’ll investigate further when I’ll get back home on why this happens. Meanwhile thanks @Aragorn and @BG405 for the tips. I’ll update the thread if I find anything else
@Aragorn, @BG405
So it seems wireplumber was guilty as charged in my case, as per my whining.
wireplumber 0.5.17
Highlights:
  • This release fixes a significant regression introduced in version 0.5.16.
    Users are strongly encouraged to upgrade to this release and avoid using 0.5.16
Fixes:
  • Fixed factory-created device, node and link objects to stop sharing
    ownership with their registry global, fixing a regression from the
    WpClientContext introduced in 0.5.16 that broke proper object
    destruction in the monitor scripts
  • Improved default-nodes to also rank on the object.serial of a node’s
    device and on the node’s own object.serial, so that route priorities
    are only compared between nodes of the same card, and the election no
    longer changes for no apparent reason when all other keys are equal
I’ll idle the audio tonight and close the thread tomorrow morning if nothing changes.
Thanks for chipping in.
Edit :
The 0.5.17 of wireplumber seems solid, thanks to upstream who moved rather fast to correct this. That said, the thread could be closed.
@Aragorn @BG405 can you do the honors please?
