Hi! I have a different problem with KDE/x11 and because of it sometimes I use KDE/openbox. After that something happened with shortcuts on both systems: almost nothing works (for example, meta to open search panel or ctrl+alt+t for a terminal).
> System:
> Host: dan-lt Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc
> v: 11.1.0 Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux base: Arch Linux
> Machine:
> Type: Laptop System: LENOVO product: 81WE v: IdeaPad 3 15IIL05
> serial: <superuser required>
> Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
> UEFI: LENOVO v: EMCN47WW date: 07/29/2021
> Battery:
> ID-1: BAT0 charge: 6.2 Wh (19.9%) condition: 31.1/35.0 Wh (88.7%)
> volts: 7.2 min: 7.5 model: SMP L16M2PB2 status: Discharging
> CPU:
> Info: quad core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
> arch: Ice Lake rev: 5 cache: L1: 320 KiB L2: 2 MiB L3: 6 MiB
> Speed (MHz): avg: 2245 high: 3258 min/max: 400/3600 cores: 1: 1128
> 2: 1086 3: 1241 4: 2483 5: 3026 6: 2586 7: 3154 8: 3258 bogomips: 19048
> Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
> Graphics:
> Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
> bus-ID: 00:02.0
> Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
> bus-ID: 1-5:2
> Display: x11 server: X.Org 1.21.1.2 driver: loaded: intel
> resolution: 1920x1080~60Hz
> OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.5
> direct render: Yes
> Audio:
> Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
> driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
> Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
> Sound Server-2: JACK v: 1.9.19 running: no
> Sound Server-3: PulseAudio v: 15.0 running: yes
> Sound Server-4: PipeWire v: 0.3.40 running: yes
> Network:
> Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
> bus-ID: 00:14.3
> IF: wlp0s20f3 state: up mac: e0:d4:64:08:b7:3b
> Bluetooth:
> Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
> driver: btusb v: 0.8 bus-ID: 1-10:4
> Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
> Drives:
> Local Storage: total: 476.94 GiB used: 125 GiB (26.2%)
> ID-1: /dev/nvme0n1 vendor: Western Digital
> model: PC SN530 SDBPMPZ-512G-1101 size: 476.94 GiB temp: 29.9 C
> Partition:
> ID-1: / size: 468.09 GiB used: 125 GiB (26.7%) fs: ext4 dev: /dev/nvme0n1p2
> ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
> dev: /dev/nvme0n1p1
> Swap:
> ID-1: swap-1 type: file size: 8 GiB used: 15.5 MiB (0.2%) file: /swapfile
> Sensors:
> System Temperatures: cpu: 67.0 C mobo: N/A
> Fan Speeds (RPM): N/A
> Info:
> Processes: 277 Uptime: 12h 7m Memory: 7.33 GiB used: 3.12 GiB (42.6%)
> Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1570
> Shell: Zsh v: 5.8 inxi: 3.3.11
