Is it possible to increase sound above 100 using the audio buttons in my laptop. i find it very annoying that i have to go to pulseaudio and then increase it above 100 .
I remember that ubuntu had this functionality to increase above 100
output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d62b0b2e-bfac-4cc0-8645-d4b67e3c6632 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 2324FV6 v: ThinkPad X230
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 2324FV6 serial: <filter> UEFI-[Legacy]: LENOVO
v: G2ETB7WW (2.77 ) date: 09/24/2019
ID-1: BAT0 charge: 38.8 Wh (100.0%) condition: 38.8/57.7 Wh (67.2%)
volts: 12.5 min: 11.1 model: SANYO 45N1031 type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 7.45 GiB used: 2.55 GiB (34.2%)
Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 20761
Speed: 1322 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1322 2: 1413
3: 1380 4: 1523
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 04f2:b2eb class-ID: 0e02
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 125 size: 277x156mm (10.9x6.1")
diag: 318mm (12.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.2.2 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
Device-3: Sierra Wireless Sierra Wireless Gobi 3000 Modem device (MC8355)
type: USB driver: qcserial,qmi_wwan bus-ID: 3-4:4 chip-ID: 1199:9013
class-ID: 0000
IF: wwp0s20u4 state: down mac: <filter>
Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] type: USB driver: btusb
v: 0.8 bus-ID: 1-1.4:3 chip-ID: 0a5c:21e6 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 111.79 GiB used: 43.29 GiB (38.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Morebeck model: V602 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1A0 scheme: MBR
ID-1: / raw-size: 85.48 GiB size: 83.58 GiB (97.78%) used: 43.29 GiB (51.8%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: d62b0b2e-bfac-4cc0-8645-d4b67e3c6632
ID-1: swap-1 type: file size: 3 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda2 maj-min: 8:2 size: 1024 MiB fs: ext4 label: N/A
uuid: 61ab7529-70f0-4bb0-9386-bcb4bc84f4c0
ID-2: /dev/sda3 maj-min: 8:3 size: 24.82 GiB fs: btrfs
label: fedora_localhost-live uuid: 528b07af-d548-4d5b-8845-273e91dc5b4d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad]
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 1-1.6:4 info: Chicony Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 3-2:3 info: A4Tech 2.4G Device type: Keyboard,Mouse
power: 100mA chip-ID: 09da:2403 class-ID: 0301
Device-3: 3-4:4
info: Sierra Wireless Sierra Wireless Gobi 3000 Modem device (MC8355)
type: Network driver: qcserial,qmi_wwan interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1199:9013 class-ID: 0000
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3424
Processes: 226 Uptime: 8m wakeups: 3 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1311 pacman: 1299 lib: 338 flatpak: 0
snap: 12 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
