All of my screen recording programs don't work anymore
Hello, I recently do full system update. The issue that came up is that all of my screen recording program doesn’t work anymore.
OBS Studio
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Using EGL/X11
info: CPU Name: AMD Ryzen 5 3500 6-Core Processor
info: CPU Speed: 4068.685MHz
info: Physical Cores: 6, Logical Cores: 6
info: Physical Memory: 15917MB Total, 7597MB Free
info: Kernel Version: Linux 6.1.26-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.5.0 (runtime), 6.4.2 (compiled)
info: Portable mode: false
qt.core.qmetaobject.connectslotsbyname: QMetaObject::connectSlotsByName: No matching signal for on_tbar_position_valueChanged(int)
info: OBS 29.0.2-2 (linux)
info: ---------------------------------
info: audio settings reset:
	samples per sec: 48000
	speakers:        2
	max buffering:   960 milliseconds
	buffering type:  dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce GTX 1650/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 530.41.03, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
	base resolution:   1920x1080
	output resolution: 1920x1080
	downscale filter:  Lanczos
	fps:               60/1
	format:            NV12
	YUV mode:          Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] No captures available
warning: v4l2loopback not installed, virtual camera disabled
info: NVENC supported
zsh: segmentation fault (core dumped)  obs
simplescreenrecorder (AUR)
simplescreenrecorder: error while loading shared libraries: libavformat.so.59: cannot open shared object file: No such file or directory
gpu-screen-recorder-git (AUR)
window name: [Stable Update] 2023-05-07 - Kernels, KDE Gear 23.04.0, KDE Frameworks 5.105.0, Qt5, Firefox, Thunderbird - Announcements / Stable Updates - Manjaro Linux Forum — Mozilla Firefox, window id: 115343422
window name: SG Physics 2D (DEBUG), window id: 119537668
gpu-screen-recorder: error while loading shared libraries: libavcodec.so.59: cannot open shared object file: No such file or directory
waitpid failed: No child processes
Notification: title: GPU Screen Recorder, body: Failed to save video. Either your graphics card doesn't support GPU Screen Recorder or you don't have enough disk space to record a video
See:
Your OBS Studio issue is completely unrelated to the next issue:
You need to rebuild both AUR packages against libavcodec.so.60 from ffmpeg 6.0.
Aaah, yes it works now thanks.
Hmm, looks like this wasn’t the issue but yes, it is obs problem. It just a coincidence that the error happened together with every other screen recording program I had installed.
I just removed libva-vdpau-driver to fix it.
I guess you dont need VDPAU backend for VAAPI then ?
(useful if vdpau is superior or the only acceleration available while an application only provides VAAPI)
I dont have your system info … so I couldnt say.
I… I think I don’t… I’m not sure. I usually using this NVENC thing.
While I wanted to check what vaapi is, I found another problem. OBS will crash when I tried to open settings.
QVariant: Provided metatype for 'QColor' does not support destruction and copy construction
info: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
It’s still record fine, I’ll just keep it like this for now.
  Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=11b28901-a616-4d72-9228-58de9a9b777e rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <superuser required>
    UEFI: American Megatrends v: P4.50 date: 03/12/2021
  System RAM: available: 15.54 GiB used: 5.78 GiB (37.2%)
  Info: model: AMD Ryzen 5 3500 bits: 64 type: MCP arch: Zen 2 gen: 3 level: v3
    note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 2474 high: 3979 min/max: 2200/4120 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2209 4: 2059 5: 2200 6: 3979 bogomips: 43218
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 530.41.03
    alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 09:00.0 chip-ID: 10de:1f82 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 508x572mm (20.00x22.52")
    s-diag: 765mm (30.12")
  Monitor-1: DP-1 pos: primary,top res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: HDMI-0 pos: bottom res: 1920x1080 hz: 60 dpi: 166
    size: 294x166mm (11.57x6.54") diag: 338mm (13.29") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX
    1650/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:10fa class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: JMTek LLC. USB PnP Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-8:2 chip-ID: 0c76:126e class-ID: 0300
  API: ALSA v: k6.1.26-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.70 status: off tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: br-45f77f971491 state: down mac: <filter>
  IF-ID-2: br-a1f989416b95 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-3: br-b778e40a8b96 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-4: br-dd39ee16bd3e state: down mac: <filter>
  Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-5: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
    all]
  IF-ID-6: veth144245c state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-7: veth43b4a6e state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-8: veth4a6a2c0 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-9: veth6b2fdcd state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-10: vethb62892b state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-11: vethc549d97 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-12: vethc884f06 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-13: vethd06548e state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Local Storage: total: 2.96 TiB used: 1.93 TiB (65.2%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 3B2QEXM7 temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000VX008-2E3164
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CV12 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: V-Gen model: 01SM21NT256MT
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 5A0 scheme: GPT
  ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%) used: 53.07 GiB (54.3%)
    fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 11b28901-a616-4d72-9228-58de9a9b777e
  ID-2: /boot/efi raw-size: 1000 MiB size: 996 MiB (99.60%)
    used: 26.5 MiB (2.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: D4F8-5870
  ID-3: /home raw-size: 390.62 GiB size: 383.43 GiB (98.16%)
    used: 340.31 GiB (88.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: home uuid: 3b3e44b5-a833-4e09-b668-250413d14da3
  ID-4: /mnt/cross_apps raw-size: 332.88 GiB size: 332.88 GiB (100.00%)
    used: 234.8 GiB (70.5%) fs: ntfs dev: /dev/nvme0n1p8 maj-min: 259:8
    label: CrossApps uuid: 424EFD4D4EFD3A6D
  ID-5: /mnt/warehouse raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.32 TiB (72.4%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Warehouse
    uuid: 9C5EDB7B5EDB4CA0
  ID-6: /var/cache raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
    used: 53.07 GiB (54.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: 11b28901-a616-4d72-9228-58de9a9b777e
  ID-7: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: a744f76f-4318-41b8-8117-a8299568048d
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 97.14 GiB fs: ntfs label: N/A
    uuid: 56B4F6A3B4F684B1
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 516 MiB fs: ntfs label: N/A
    uuid: 50642D1A642D03F6
  ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sdb2 maj-min: 8:18 size: 238.46 GiB fs: ntfs label: N/A
    uuid: A008D09008D06736
  Device-1: 1-8:2 info: JMTek LLC. USB PnP Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-4: 3-4:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0
    chip-ID: 058f:6254 class-ID: 0900
  Device-1: 3-4.3:3 info: Holtek USB Gaming Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 04d9:a002 class-ID: 0300
  Hub-5: 3-4.4:4 info: Alcor Micro USB Hub ports: 4 rev: 2.0
  Device-1: 3-4.4.2:5 info: Wacom One Pen Display 13 type: HID
    driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 chip-ID: 056a:03a6 class-ID: 0300 serial: <filter>
  Device-2: 3-4.4.4:6 info: Logitech G502 SE HERO Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 68.2 C mobo: N/A
  Processes: 376 Uptime: 1h 13m wakeups: 0 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1650 libs: 499 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.27
Pretty much all you would need to know is probably covered here:
https://wiki.archlinux.org/title/Hardware_video_acceleration
(I have a ryzen 2500u and use both VAAPI and VDPAU and have the faux backend ones … I ended up using vaapi predominantly … but amdgpu can handle both)
In your case … you probably want to focus on having vdpau well and good … as well as use its backend for vaapi … because you use nvidia. and vdpau is for nvidia and vaapi is not … so in cases, such as your browser, that only VAAPI is available … you want to use the vdpau backend for it.
(things that arent good at having a sane default or fallback can have problems if hw-accel is not properly configured both on the system and the application in question … a good example is VLC … which has a miriad of issues if you dont handle hw-accel properly)
