Hi all.
I’m having a very strange issue where all my mounted drives (apart from the boot drive) become unmounted and cant be remounted with the following error:
An error occurred while accessing ‘drive name here’, the system responded: The requested operation has failed: Error mounting /dev/sdb5 at /run/media/username/drive: wrong fs type, bad option, bad superblock on /dev/sdb1, missing codepage or helper program, or other error.
This error repeats for all 4 of my mounted drives (1 SATA SSD, 1 NVMe SSD and 2 SATA HDDs). I dual boot and have confirmed all the drives are operational on windows 11. This is the 2nd time this has happened after my whole system lagged for about 5 seconds and my desktop appears to reload. it previously randomly fixed itself after rebooting but not this time.
My external drive that is NTFS won’t mount but my fat32 USB drives will without issue.
Things I have tried:
Restarting numerous times
Booting into windows and back into manjaro
Updating all packages (pacman, yay and flatpack)
Disabling fast boot in UEFI and shutting down windows fully
I was able to find another person having a similar issue:
https://www.reddit.com/r/linux4noobs/comments/1dpk1x1/can_no_longer_mountread_an_ntfs_partition_in/
I ran the following commands from one of the comments:
mkdir ~/ntfs_test
sudo ntfs-3g /dev/sdb1 ~/ntfs_test
ls ~/ntfs_test
The result I got:
Windows is hibernated, refused to mount.
Falling back to read-only mount because the NTFS partition is in an
unsafe state. Please resume and shutdown Windows fully (no hibernation
or fast restarting.)
Could not mount read-write, trying read-only
I got the same output as them leading me the believe I have the same issue with windows messing with the drives. I don’t want to remove my dual boot as I need windows as a fallback for some applications. I don’t use hibernation and i didn’t put the system to sleep when I exited it.
inxi output:
CPU: 12-core AMD Ryzen 9 3900X (-MT MCP-) speed/min/max: 2159/2200/4672 MHz
Kernel: 6.6.54-2-MANJARO x86_64 Up: 16m Mem: 6.96/31.26 GiB (22.2%)
Storage: 6.37 TiB (6.5% used) Procs: 479 Shell: Zsh inxi: 3.3.36
