Everything is good but when i transfer to nvidia mode in optimus-manager and put the second monitor in my laptop, it’s working but everything is laggy and not smooth and all effects like “Wobbly Windows” , “Magic Lamp” after adding the external monitor stop working.
So how can i fix this?
xrandr -q
output:
Screen 0: minimum 8 x 8, current 3286 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1366x768+1920+0 (normal left inverted right x axis y axis) 410mm x 230mm
1366x768 59.79*+
1920x1080 59.94
1280x1024 60.02
1280x960 60.00
1280x720 60.00 59.94
1152x864 75.00
1024x768 75.03 70.07 66.00 60.00
800x600 75.00 72.19 60.32 56.25
720x480 59.94 59.94
640x480 75.00 72.81 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.05*+ 60.01 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
1280x1024 (0x1f2) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x1f5) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1024x768 (0x203) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x212) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x213) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
640x480 (0x21f) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
Laptop config :
System: Host: Devloper Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.19.5 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 80YY v: Lenovo Y520-15IKBM serial: <superuser/root required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser/root required> UEFI: LENOVO v: 5XCN26WW
date: 12/20/2018
Battery: ID-1: BAT0 charge: 36.1 Wh condition: 38.0/45.0 Wh (84%)
CPU: Topology: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP L2 cache: 6144 KiB
Speed: 1100 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1083 2: 1080 3: 1089 4: 1030
Graphics: Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: nvidia v: 440.100
Device-3: Syntek EasyCamera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia resolution: 1: 1366x768~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1060 with Max-Q Design/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
Audio: Device-1: Intel CM238 HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.64-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter driver: ath10k_pci
IF: wlp2s0 state: up mac: 64:6e:69:d6:e3:31
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp3s0 state: down mac: 54:e1:ad:89:fa:19
Device-3: Qualcomm Atheros type: USB driver: btusb
Drives: Local Storage: total: 1.03 TiB used: 578.18 GiB (55.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW128HEGR-000L2 size: 119.24 GiB
ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
Partition: ID-1: / size: 47.67 GiB used: 42.44 GiB (89.0%) fs: ext4 dev: /dev/nvme0n1p6
Swap: ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p7
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 36 C
Info: Processes: 192 Uptime: 9m Memory: 7.67 GiB used: 2.53 GiB (33.0%) Shell: Bash inxi: 3.1.05
