Wenn ich über die Radeon gehe wird der Prozess nach einer weile gekillt.
weingeist-m17xr3 kernel: Out of memory: Killed process 1870 (darkplaces-linu) total-vm:5706168kB, anon-rss:180488kB, file-rss:0k>
Über die Intel geht es.
Die Infos
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x48 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 2 outputs: 8 associated providers: 1 name:modesetting
Provider 1: id: 0xd5 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 6 outputs: 5 associated providers: 1 name:AMD Radeon HD 6900M Series @ pci:0000:01:00.0
mhwd -li INT ✘
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
inxi -Fazy ✔
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=42fd7bb3-5c7a-433b-9574-f0b3219e4659 rw quiet apparmor=1
security=apparmor rcutree.rcu_idle_qp_delay=1 mitigations=off
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Portable System: Alienware product: M17xR3 v: A12
serial: <superuser required>
Mobo: Alienware model: M17xR3 v: A12 serial: <superuser required>
BIOS: Alienware v: A12 date: 08/20/2012
ID-1: BAT1 charge: 54.4 Wh (100.0%) condition: 54.4/90.0 Wh (60.4%)
volts: 12.6 min: 11.1 model: SDI DELL 7XC9N1AM type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 897 high: 1147 min/max: 800/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 797 2: 797 3: 933
4: 1111 5: 797 6: 797 7: 1147 8: 797 bogomips: 35097
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: AMD Blackcomb [Radeon HD 6970M/6990M] vendor: Dell
driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:6720 class-ID: 0300
Device-3: Ricoh Laptop_Integrated_Webcam_3M type: USB driver: uvcvideo
bus-ID: 2-1.4:3 chip-ID: 05ca:181a class-ID: 0e02
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: ati,modesetting,radeon alternate: fbdev,vesa
vendor: Dell Alienware M17x R3 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: AMD Barts HDMI Audio [Radeon HD 6790/6850/6870 / 7720 OEM]
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa88 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Dell
driver: atl1c v: kernel port: 5000 bus-ID: 07:00.0 chip-ID: 1969:1083
class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-N 1103 Half-size Mini PCIe Card
driver: ath9k v: kernel bus-ID: 0d:00.0 chip-ID: 168c:0030 class-ID: 0280
IF: wlp13s0 state: up mac: <filter>
Device-1: Dell DW375 Bluetooth Module type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:3 chip-ID: 413c:8187 class-ID: fe01 serial: <filter>
Local Storage: total: 931.52 GiB used: 307.13 GiB (33.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9750420AS
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: DEM1 scheme: MBR
ID-1: / raw-size: 170.89 GiB size: 167.14 GiB (97.81%) used: 16.5 GiB (9.9%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: file size: 256 MiB used: 2.8 MiB (1.1%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
ID-2: swap-2 type: file size: 256 MiB used: 44.1 MiB (17.2%) priority: 49
file: /var/lib/systemd-swap/swapfc/2
System Temperatures: cpu: 52.0 C mobo: N/A gpu: radeon temp: 57.5 C
Processes: 232 Uptime: 32m wakeups: 2 Memory: 5.74 GiB
used: 3.17 GiB (55.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1206 lib: 331 flatpak: 0 Shell: Zsh v: 5.8
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
inxi -Gxxa ✔
class-ID: 0300
lspci -vvv PIPE ✘ 5m 0s
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
Subsystem: Dell Device 0490
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 24
Bus: primary=00, secondary=01, subordinate=06, sec-latency=0
I/O behind bridge: 00006000-00006fff [size=4K]
Memory behind bridge: c8400000-c93fffff [size=16M]
Prefetchable memory behind bridge: 00000000a0000000-00000000afffffff [size=256M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09) (prog-if 00 [VGA controller])
Subsystem: Dell Device 04ba
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 26
Region 0: Memory at c0000000 (64-bit, non-prefetchable) [size=4M]
Region 2: Memory at b0000000 (64-bit, prefetchable) [size=256M]
Region 4: I/O ports at 7000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 36
Region 0: Memory at c9404000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at c940a000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
Subsystem: Dell Alienware M17x R3
Interrupt: pin A routed to IRQ 38
Region 0: Memory at c9400000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 17
Bus: primary=00, secondary=07, subordinate=0c, sec-latency=0
I/O behind bridge: 00005000-00005fff [size=4K]
Memory behind bridge: c7400000-c83fffff [size=16M]
Prefetchable memory behind bridge: 00000000c0400000-00000000c13fffff [size=16M]
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5) (prog-if 00 [Normal decode])
Interrupt: pin C routed to IRQ 18
Bus: primary=00, secondary=0d, subordinate=12, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: c6400000-c73fffff [size=16M]
Prefetchable memory behind bridge: 00000000c1400000-00000000c23fffff [size=16M]
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5) (prog-if 00 [Normal decode])
Interrupt: pin D routed to IRQ 19
Bus: primary=00, secondary=13, subordinate=18, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: c5400000-c63fffff [size=16M]
Prefetchable memory behind bridge: 00000000c2400000-00000000c33fffff [size=16M]
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5) (prog-if 00 [Normal decode])
Interrupt: pin B routed to IRQ 16
Bus: primary=00, secondary=19, subordinate=1e, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: c4400000-c53fffff [size=16M]
Prefetchable memory behind bridge: 00000000c3400000-00000000c43fffff [size=16M]
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 0: Memory at c9409000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM67 Express Chipset LPC Controller (rev 05)
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port Mobile SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin B routed to IRQ 25
Region 0: I/O ports at 7098 [size=8]
Region 1: I/O ports at 70bc [size=4]
Region 2: I/O ports at 7090 [size=8]
Region 3: I/O ports at 70b8 [size=4]
Region 4: I/O ports at 7060 [size=32]
Region 5: Memory at c9408000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin C routed to IRQ 19
Region 0: Memory at c9406000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at 7040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Blackcomb [Radeon HD 6970M/6990M] (prog-if 00 [VGA controller])
Subsystem: Dell Radeon HD 6990M
Interrupt: pin A routed to IRQ 37
Region 0: Memory at a0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at c8400000 (64-bit, non-prefetchable) [size=128K]
Region 4: I/O ports at 6000 [size=256]
Expansion ROM at c8440000 [disabled] [size=128K]
Kernel driver in use: radeon
Kernel modules: radeon
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Barts HDMI Audio [Radeon HD 6790/6850/6870 / 7720 OEM]
Interrupt: pin B routed to IRQ 39
Region 0: Memory at c8420000 (64-bit, non-prefetchable) [size=16K]
07:00.0 Ethernet controller: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet (rev c0)
Interrupt: pin A routed to IRQ 40
Region 0: Memory at c7400000 (64-bit, non-prefetchable) [size=256K]
Region 2: I/O ports at 5000 [size=128]
Kernel driver in use: atl1c
Kernel modules: atl1c
0d:00.0 Network controller: Qualcomm Atheros AR93xx Wireless Network Adapter (rev 01)
Subsystem: Rivet Networks Killer Wireless-N 1103 Half-size Mini PCIe Card [AR9380]
Interrupt: pin A routed to IRQ 18
Region 0: Memory at c6400000 (64-bit, non-prefetchable) [size=128K]
Expansion ROM at c6420000 [disabled] [size=64K]
Kernel driver in use: ath9k
Kernel modules: ath9k
13:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader (rev 01)
Interrupt: pin A routed to IRQ 35
Region 0: Memory at c5401000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
13:00.1 SD Host controller: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader (rev 01)
Region 0: Memory at c5400000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
19:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04) (prog-if 30 [XHCI])
Region 0: Memory at c4400000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
Für alle Tipps zu diesem System bin ich dankbar.
Edit: Mehrere Tests haben ergeben das die Radeon wohl nicht richtig angesprochen wird.
Der Lüfter schafft meiner Meinung nach auch nicht die volle Leistung. Unter W10 ist die Kiste lauter aber da läuft es.
