Alacritty now shows a warning that stays at the bottom, appeared after this last update, everything else is ok. It shows this:
[WARN] See log at /tmp/Alacritty-1810.log ($ALACRITTY_LOG):
YAML config "/home/username/.config/alacritty/alacritty.yml" is deprecated, please migrate to TOML using `alacritty migrate`
Googling about it I found a similar situation about this: Alacritty throwing errors after Migration from YAML to TOML [WARN unused config] - Issues & Assistance - Garuda Linux Forum
Since some people are having issues with the migration, I please ask for some guidance or advice about this. Thank You.
cscs
3 January 2024 03:30
2
I would say take a look at the issue tracker.
opened 06:38PM - 28 Dec 22 UTC
closed 12:23AM - 12 Jun 23 UTC
I'm quite honestly tired of looking at YAML files with broken indentation. While… YAML is an awful format even for experienced users, clearly it's completely impossible for inexperienced ones to grasp its concept. And the documentation of our configuration file with everything commented out by default probably doesn't help.
Since as far as I know all previous issues with TOML have been fixed and escape sequences can be easily specified in TOML strings now, I think it would make sense to switch to TOML as our default format.
In a transitory period we could probably get away with just loading existing YAML files and writing them out as TOML, to allow for backward compatibility. This will probably produce somewhat messy TOML files, but I can't imagine an auto-generated TOML file would be much worse than a YAML file.
The only major drawbacks I see is that this is a rather big change that will no doubt annoy a bunch of people and some more advanced features of YAML (like anchors) are not supported in TOML. But nobody *really* needs anchors and I kinda like annoying people.
@kchibisov You proposed this a while ago on IRC, do you think this is a bad idea?
See https://github.com/alacritty/alacritty/issues/1217 for prior discussions.
It seems there are some considerations … like ‘links’ apparently.
If you’re talking about links no longer working, then that is an intended feature and there is not going to be any replacement for this in toml. You should be using imports instead (even with yaml really).
And comments
automatic migration drops all comments
If anything mentioned there is a deal-breaker I suppose you can stick with yaml.
Otherwise alacritty migrate should be a functional command.
See more at the arch wiki
https://wiki.archlinux.org/title/Alacritty
Sorry to respond only now, I posted this at 4 AM and then some sleep.
I did alacritty migrate
Said it did the migration sucessfully but after that it still show some warnings:
[WARN] See log at /tmp/Alacritty-3681.log ($ALACRITTY_LOG):
Unused config key: author
Unused config key: name
Unused config key: theme
Another user has reported similar warnings after migration:
[WARN ] [alacritty_config_derive] Unused config key: author · Issue #7229 · alacritty/alacritty · GitHub
alacritty.log file:
[0.000694499s] [WARN ] [alacritty_config_derive] Unused config key: author
[0.001027350s] [WARN ] [alacritty_config_derive] Unused config key: name
[0.001083784s] [WARN ] [alacritty_config_derive] Unused config key: items
[0.001111311s] [WARN ] [alacritty_config_derive] Unused config key: theme
I suggest edit alacritty configuration ~/.config/alacritty/alacritty.toml to remove unused config keys
Thank you very much for the help, I’m gonna look into that.
I do not have much experience editing config files, I will report if I need some assistance.
In my config file I have this:
theme = "Garuda.dr460nized"
[colors]
author = "dr460nf1r3"
name = "Garuda (dr460nized)"
[colors.bright]
black = "0xa6896b"
blue = "0xF35645"
cyan = "0xFAD32F"
green = "0xEB3247"
magenta = "0xF6A73B"
red = "0x5F4149"
white = "0xeec49a"
yellow = "0xBC4349"
[colors.cursor]
cursor = "0xeec49a"
text = "0x0a1124"
[colors.normal]
black = "0x0a1124"
blue = "0xF35645"
cyan = "0xFAD32F"
green = "0xEB3247"
red = "0x5F4149"
white = "0xeec49a"
yellow = "0xBC4349"
[colors.primary]
background = "0x0a1124"
foreground = "0xeec49a"
[env]
LANG = "en_US.UTF-8"
LC_CTYPE = "en_US.UTF-8"
TERM = "alacritty"
[font]
size = 11.0
[font.normal]
family = "monospace"
style = "Regular"
So do I just remove the lines:
Just that?
Are you using Garuda or Manjaro?
Please provide the output of:
Using Manjaro XFCE but the color theme on alacritty is garuda dragonized. I really like the colors xD
Sorry if I caused some confusion, here’s the output:
Kernel: 6.1.69-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e3de76d7-c1cb-416c-98c7-3d4b9c416c5f rw quiet apparmor=1
security=apparmor resume=UUID=4a3bd434-53f1-4ffb-b6e2-883bdd0768e9
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0975110000405F00000620180 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 2269 v: 73.41 serial: <superuser required>
UEFI: American Megatrends v: F.43 date: 08/19/2015
System RAM: total: 4 GiB note: est. available: 3.27 GiB
used: 1.87 GiB (57.2%)
Info: model: AMD A8-6410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1922 high: 2000 min/max: 1000/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2000 2: 2000
3: 1689 4: 2000 bogomips: 15979
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe
msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
wdt xsave xsaveopt
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-3 code: Volcanic Islands process: TSMC 28nm built: 2014-19 pcie:
gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 1002:6900 class-ID: 0380 temp: 44.0 C
Device-3: Chicony HP Truevision HD camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.2:3
chip-ID: 04f2:b40e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu,radeon unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: radeon display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4951 built: 2013
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: KABINI ( LLVM 16.0.6 DRM 2.50
6.1.69-1-MANJARO) device-ID: 1002:9851 memory: 500 MiB unified: no
API: Vulkan v: 1.3.274 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon R7 M260 (RADV ICELAND) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:6900 surfaces: xcb,xlib
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
API: ALSA v: k6.1.69-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:b723
class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:3 chip-ID: 0bda:b001
Local Storage: total: 465.76 GiB used: 262.41 GiB (56.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 2C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DU8A5SHL rev: ZH63
dev-links: cdrom
ID-1: / raw-size: 458.26 GiB size: 449.99 GiB (98.20%)
used: 262.35 GiB (58.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: e3de76d7-c1cb-416c-98c7-3d4b9c416c5f
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 0136-D163
ID-1: swap-1 type: partition size: 7.21 GiB used: 65.5 MiB (0.9%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 4a3bd434-53f1-4ffb-b6e2-883bdd0768e9
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.3:3 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 2-1.2:3 info: Chicony HP Truevision HD camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b40e class-ID: 0e02
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 045e:028e class-ID: ff00
Device-2: 3-2:3 info: Sunplus Innovation GameMouse type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1bcf:08b8 class-ID: 0300
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 48.4 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 44.0 C device: radeon temp: 43.0 C
Processes: 229 Uptime: 1h 42m wakeups: 0 Init: systemd v: 254
Packages: 1629 pm: pacman pkgs: 1541 libs: 428 tools: pamac pm: flatpak
pkgs: 84 pm: snap pkgs: 4 Shell: Bash v: 5.2.21 running-in: xfce4-terminal
inxi: 3.3.31
It’s an old laptop I know…
ARSManiac:
Sorry if I caused some confusion, do you still want the inxi output?
It’s a very colouful theme, indeed; perhaps too much for my tired eyes.
Inxi: No need, although it might be helpful to someone. I’m not familiar with Alacritty; or, at least, not familiar enough to offer advice with it. I tried it once on macOS, and it (or I) failed miserably, and I haven’t looked at it again.
Good luck.
I edited and provided the inxi output above if you still wanna look into it.
just remove the keys complained about and that’s it
Do I also remove the line [colors] before author = "dr460nf1r3" or just leave it there?
To my understanding the offending lines are:
ARSManiac:
Do I also remove
Try commenting the lines (not the header) with # and see what happens. You might also consider finding an updated theme (suitable for TOML), which your Garuda.dr460nized theme doesn’t seem to be.
The error message itself gives the command to migrate to the newer format alacritty migrate. The new configuration file should then have a .toml extension, I’m guessing.
I think you can likely download a similar colour theme, and perhaps edit its configuration file to reflect the dr460nized theme colours, though alacritty / alacritty-theme seems to have plenty to choose from otherwise, along with instructions.
I found An Example and Concise Guide to Alacritty Configuration through TOML , which might also be useful.
Beyond this, I have nothing more to offer. Good luck.
Aside:- You might consider obtaining more RAM for this machine, if possible. 4GB is insufficient. 8GB would be preferable for Manjaro.
Thanks for the help, I’m gonna just backup the TOML config file and proceed with the changes.
As for the RAM, Manjaro XFCE works very well even with only 4 GB of RAM, much snappier than Windows 10 or even Windows 8.1
Since support for many apps will end (or ended) on Windows 8.1 (Steam one of them) I started migrating to Manjaro almost 4 years ago, I droped Windows entirely almost 2 years now.
I commented the offending lines on alacritty.toml with # and no more warnings, thank you all for the help.
Click the tick under the post you feel helped you the most, and then this thread can be closed. Cheers.
More than one post helped me out!
Thank you cscs, nikgnomic and soundofthunder specially, I can tick only one tho.
Anyways thank you guys so much!
system
Closed
5 January 2024 06:36
18
