I am looking for themes of alacritty
Once I tried arcolinux there i found that there was transparent backgroud and titles of repos like
community, extra were of different colours .even after some search there was no wiki or tutorials for the same
inxi --admin --verbosity=7 --filter --width
Kernel: 5.14.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=3d92a08e-ec54-419d-a9ac-5513127177cd ro quiet apparmor=1
Desktop: Qtile 0.18.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 81D6 v: Lenovo ideapad 330-15AST
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 330-15AST
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724WIN
serial: <superuser required> UEFI: LENOVO v: 8UCN19WW date: 05/14/2021
ID-1: BAT0 charge: 26.1 Wh (96.3%) condition: 27.1/30.6 Wh (88.3%)
volts: 8.4 min: 7.6 model: CPT-COS L16C2PB2 type: Li-poly serial: <filter>
status: Unknown
RAM: total: 6.67 GiB used: 1.64 GiB (24.6%)
Info: Dual Core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64
type: MCP arch: Excavator family: 15 (21) model-id: 70 (112) stepping: 0
microcode: 6006705 cache: L1: 256 KiB L2: 2 MiB bogomips: 10402
Speed: 2000 MHz min/max: 2000/3450 MHz boost: enabled Core speeds (MHz):
1: 3450 2: 3450
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4 fpu
fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca mce
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse pse36 ptsc
rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xop xsave xsaveopt
disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.3:5
chip-ID: 13d3:5a02 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 driver: loaded: modesetting
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD STONEY (DRM 3.42.0 5.14.18-1-MANJARO LLVM 13.0.0)
v: 4.5 Mesa 21.2.5 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.2:4 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 3 state: up address: <filter>
Local Storage: total: 931.51 GiB used: 75.43 GiB (8.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: LCM2 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE0N rev: T.02
dev-links: cdrom
ID-1: / raw-size: 315.05 GiB size: 309.11 GiB (98.11%)
used: 75.32 GiB (24.4%) fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: 3d92a08e-ec54-419d-a9ac-5513127177cd
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 114 MiB (11.4%) fs: vfat dev: /dev/sda14 maj-min: 8:14 label: N/A
uuid: 9604-07C2
ID-1: swap-1 type: partition size: 2.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: b6b04b23-0477-4459-a870-9c714febfac2
ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 6C8C-D247
ID-2: /dev/sda10 maj-min: 8:10 size: 195.31 GiB fs: ntfs label: New Volume
uuid: EEFE8A31FE89F25F
ID-3: /dev/sda11 maj-min: 8:11 size: 19.29 GiB fs: ntfs label: New Volume
uuid: 00AC900EAC8FFC7A
ID-4: /dev/sda12 maj-min: 8:12 size: 2.93 GiB fs: swap label: N/A
uuid: d491e39d-bb42-43fe-82ab-39fa21701fe8
ID-5: /dev/sda13 maj-min: 8:13 size: 25 GiB fs: ntfs label: LENOVO
uuid: 4244764544763C2B
ID-6: /dev/sda15 maj-min: 8:15 size: 173.09 GiB fs: btrfs label: N/A
uuid: e7a21b7a-3f64-4fad-89ff-71f881ab13c1
ID-7: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-8: /dev/sda3 maj-min: 8:3 size: 172.84 GiB fs: ntfs label: Windows
uuid: 02A48FFDA48FF209
ID-9: /dev/sda4 maj-min: 8:4 size: 1024 KiB fs: <superuser required>
ID-10: /dev/sda5 maj-min: 8:5 size: 1.5 GiB fs: ntfs label: New Volume
uuid: 9EFA3429FA33FBD9
ID-11: /dev/sda6 maj-min: 8:6 size: 954 MiB fs: vfat label: N/A
uuid: 2D1E-B69F
ID-12: /dev/sda7 maj-min: 8:7 size: 500 MiB fs: vfat label: N/A
uuid: 361C-712A
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.2:4 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-2: 1-1.3:5 info: IMC Networks EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5a02
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 2-1:3 info: Maxxter Telink Wireless Receiver type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 248a:8367 class-ID: 0301
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 180 Uptime: 59m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1934 lib: 504
flatpak: 0 Shell: fish v: 3.3.1 running-in: alacritty inxi: 3.3.09
If anyone can plz tell me how to get it will be helpfull
Thank in advance
