Due to some recurring MySQL errors and huge memory footprint I’ve considered switching away from MySQL as the backend for Akonadi.
Since SQLite is poorly supported I had to skip it in favor of a better supported database such as PostgreSQL, although there are many guides on how to make the switch with some different Linux flavors I couldn’t find any relevant guide for Manjaro or Arch, there should be some package to support this backend (on other flavors I could find something like libQt5Sql-postgres
and such, but there’s no such package in Manjaro).
I found some tutorials suggesting removing the Akonadi configuration from .local/akonadi
and replacing it with some PSQL specific config but I’m not sure it’ll work without a designated plugin for that.
What steps do I need to take in order to switch the backend database from MySQL to PostgreSQL?
Thanks in advance
