Akonadi trouble
I am using akonadi for korganizer (my agenda)
But it fails me. The problem is mysqld related.
When I start korganizer I receive these errors:
Error #1 in korganizer:
The Akonadi personal information management service is not running. This application cannot be used without it.
Error #2 in korganizer:
The Akonadi personal information management service is not operational.
In terminal I investigate:
akonadictl --verbose start
org.kde.pim.akonadiserver: Starting up the Akonadi Server...
org.kde.pim.akonadiserver: Found mysql_install_db:  "/usr/bin/mysql_install_db"
org.kde.pim.akonadiserver: Found mysqlcheck:  "/usr/bin/mysqlcheck"
org.kde.pim.akonadiserver: Using mysqld: "/usr/bin/mysqld"
org.kde.pim.akonadiserver: Failed to detect mysqld version!
org.kde.pim.akonadiserver: mysqld reports version 0.0.0 (Oracle MySQL)
org.kde.pim.akonadiserver: Executing: "/usr/bin/mysqld" "--defaults-file=/home/me/.local/share/akonadi/mysql.conf --datadir=/home/me/.local/share/akonadi/db_data/ --socket=/run/user/1000/akonadi/mysql.socket --pid-file=/run/user/1000/akonadi/mysql.pid"
org.kde.pim.akonadiserver: Could not start database server!
org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
org.kde.pim.akonadiserver: arguments: ("--defaults-file=/home/me/.local/share/akonadi/mysql.conf", "--datadir=/home/me/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
org.kde.pim.akonadiserver: process error: "execvp: Permission denied"
org.kde.pim.akonadiserver: terminating connection threads
org.kde.pim.akonadiserver: terminating service threads
org.kde.pim.akonadiserver: stopping db process
org.kde.pim.akonadiserver: Shutting down AkonadiServer...
org.kde.pim.akonadicontrol: Application '/usr/bin/akonadiserver' exited normally...
This happened since last manjaro update.
Please help linux Gods.
Sorry @cgoise already explained the solution in another thread (but I am not allowed to post a link to the thread):
This seems to be related to apparmor.
sudo aa-complain /usr/bin/akonadiserver fixed it for me.
Once the issue is fixed, or if this doesn’t help in your case, you should issue a
sudo aa-enforce /usr/bin/akonadiserver ,
to reactivate apparmor.
sudo aa-complain /usr/bin/akonadiserver work for me.
thanks a lot.
