Akonadi fails to start following Stable Update 2025-08-30
The last stable update broke akonadi here. Furthermore ist shows very interesting behavior - it seems the code which determines if akonadi is running is duplicated and inconsistent:
$ akonadictl stop
Akonadi is not running.
$ akonadictl start
Akonadi is already running.
$ akonadictl stop
 $ akonadictl restart
$ akonadictl -v
akonadictl 6.5.0 (25.08.0)
$  akonadiconsole
setHighDpiScaleFactorRoundingPolicy must be called before creating the QGuiApplication instance
Please register the custom scheme 'cid' via QWebEngineUrlScheme::registerScheme() before installing the custom scheme handler.
libva error: /usr/lib/dri/i965_drv_video.so init failed
 stores  4
org.kde.pim.akonadicore: ""
org.kde.pim.akonadicore: Job error:  "" for collection: QList()
Akonadi programs like akonadiconsole do not start.
I’ve moved your post to its own Topic. This way you are more likely to get dedicated assistance; also, I guess that Update thread will be closed shortly as we are about due for another update (which, itself, may fix the issue).
Cheers! :smiley_cat:
There are more commands like akonadictl status and akonadictl instances where the latter indicates that having multiple instances running is a feature not an inconsistency.
This is completely weird. Please provide more system information like inxi -zv8
What about Kontact or KOrganiser or KMail?
More akonadi output:
$ akonadictl status
Akonadi Control: stopped
Akonadi Server: running
Akonadi Server Search Support: available (Remote Search)
Available Agent Types: akonadi_archivemail_agent, akonadi_birthdays_resource, akonadi_contacts_resource, akonadi_davgroupware_resource, akonadi_etesync_resource, akonadi_ews_resource, akonadi_ewsmta_resource, akonadi_followupreminder_agent, akonadi_google_resource, akonadi_ical_resource, akonadi_icaldir_resource, akonadi_imap_resource, akonadi_indexing_agent, akonadi_knut_resource, akonadi_kolab_resource, akonadi_maildir_resource, akonadi_maildispatcher_agent, akonadi_mailfilter_agent, akonadi_mailmerge_agent, akonadi_mbox_resource, akonadi_migration_agent, akonadi_mixedmaildir_resource, akonadi_newmailnotifier_agent, akonadi_notes_agent, akonadi_openxchange_resource, akonadi_pop3_resource, akonadi_sendlater_agent, akonadi_unifiedmailbox_agent, akonadi_vcard_resource, akonadi_vcarddir_resource
$ akonadictl instances
(default)
inxi output:
$ inxi -zv8
  Kernel: 6.16.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=76c81852-b6e0-45b1-afeb-18d1a4dbfede rw quiet splash
    resume=UUID=3f65b71f-e858-4e6c-9151-14dd50c7d010 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Desktop Mobo: AZW model: MINI S v: 10 serial: <superuser required>
    part-nu: 01 uuid: <superuser required> UEFI: American Megatrends LLC.
    v: ADLNV104 date: 02/06/2023
  System RAM: total: 16 GiB available: 15.39 GiB used: 5.84 GiB (37.9%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A
    serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: no module installed
  Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
    note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
    model-id: 0xBE (190) stepping: 0 microcode: 0x1D
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 699 min/max: 700/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 699 2: 699 3: 699 4: 699 bogomips: 6451
    bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
    alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46d1
    class-ID: 0300
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: EIZO NANAO EV2785 serial: <filter> built: 2022
    res: mode: 3840x2160 hz: 60 scale: 125% (1.25) to: 3072x1728 dpi: 163
    gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.306 y: 0.647 blue:
    x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1200,
    1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1280x800, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL-N)
    device-ID: 8086:46d1 memory: 15.03 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: N/A device: 0 type: integrated-gpu
    name: Intel Graphics (ADL-N) driver: mesa intel v: 25.2.1-arch1.4
    device-ID: 8086:46d1 surfaces: N/A
  Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:54c8 class-ID: 0403
  API: ALSA v: k6.16.4-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-N PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:54f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: enp1s0.1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-2: enp1s0.2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-3: enp1s0.7 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager, sshd, systemd-networkd, systemd-timesyncd
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 118.55 GiB (24.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: EHFM90.1 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 459.7 GiB size: 451.41 GiB (98.20%)
    used: 118.55 GiB (26.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 76c81852-b6e0-45b1-afeb-18d1a4dbfede
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 2856-732A
  ID-3: /mnt/net/fs/data raw-size: N/A size: 7.28 TiB used: 3.11 TiB (42.8%)
    fs: nfs4 remote: fs:/mnt/disk/data
  ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 3f65b71f-e858-4e6c-9151-14dd50c7d010
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-3:2 info: NEC HighSpeed Hub ports: 4 rev: 2.0
    chip-ID: 0409:005a class-ID: 0900
  Device-1: 1-3.1:4 info: Pixart Imaging Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 093a:2510 class-ID: 0301
  Device-2: 1-3.2:5 info: Logitech Corded Keyboard K280e type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 046d:c328 class-ID: 0300
  Device-3: 1-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 52.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 2019 libs: 494 tools: pamac pm: flatpak pkgs: 0
    1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 239
  1: cpu: 29.6% command: firefox pid: 1701 mem: 667.3 MiB (4.2%)
  2: cpu: 19.1% command: Xwayland pid: 817 mem: 59.5 MiB (0.3%)
  3: cpu: 17.5% command: kwin_wayland pid: 721 mem: 413.7 MiB (2.6%)
  4: cpu: 8.4%
    command: ././/lib/x86_64-linux-gnu/webkit2gtk-4.0/WebKitWebProcess pid: 1446
    mem: 185.7 MiB (1.1%)
  5: cpu: 7.4% command: firefox pid: 2263 mem: 346.0 MiB (2.1%)
  Memory top: 5 of 239
  1: mem: 667.3 MiB (4.2%) command: firefox pid: 1701 cpu: 29.6%
  2: mem: 413.7 MiB (2.6%) command: kwin_wayland pid: 721 cpu: 17.5%
  3: mem: 396.6 MiB (2.5%) command: plasmashell pid: 925 cpu: 5.6%
  4: mem: 346.0 MiB (2.1%) command: firefox pid: 2263 cpu: 7.4%
  5: mem: 331.2 MiB (2.1%) command: firefox pid: 2015 cpu: 3.6%
  Processes: 239 Power: uptime: 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.3 running-in: konsole inxi: 3.3.39
KMail also does not work (that is how I detected the issue originally). KMail detects that akonadi (Personal Information Service) is not running and tries to start it, but fails with “A required background service is not running”
This seems to be the problem. I can’t tell what it is caused by. There was a similar report for Arch recently. Notice that the mentioned packages akonadi-notes and knotes aren’t part of the Arch distro - so if you should have installed them then probably from the AUR.
If these packages aren’t the culprit I would try akonadictl fsck to check for a data corruption issue. But check whether you have these packages installed first and if so whether removing them solves the issue.
Many thanks for the quick reply. Indeed there were old versions of knotes (24.08!) and akonadi-notes on my system.
After that I run akonadictrl fsck and restarted the KDE session, which resolved the issue.
Could it be that these packages have been in Manjaro before but got removed recently? I found more outdated package, which I now also remove.
Thanks again :slight_smile:
Manjaro mirrors Arch. So yes these packages probably were in Arch and got removed when they were outdated. Now if the AUR is enabled and you installed these packages (originally from the Arch or rather Manjaro repository) they won’t be removed but taken from the AUR which still contains everything. I think they would be removed in the case the AUR isn’t enabled. I mean I use the AUR and I noticed the behavior (I think it would be the same on Arch) and have to clean up packages i didn’t install myself from the AUR regularly.
