On AoE4, when starting a multiplayer game, my system freezes when the loading screen → in-game transition happens. Audio (ie. Discord) works, and the mouse moves, but literally nothing else besides alt+print screen works, and I have to either REISUB or power down the system.
journalctl creates the following line about 10,000 times:
plasmashell[7430]: amdgpu: The CS has been cancelled because the context is lost.
and this line shows up a lot as well
[drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
This problem only started within the last month or so. It worked fine (after running the de-sync script) before that.
System info:
Kernel: 5.13.19-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=45541690-78c8-42d0-a61c-28fee78274a2 ro quiet apparmor=1
security=apparmor resume=UUID=f4a9258e-7db2-4457-a378-1e44e5fe2eb9
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B550 AORUS PRO AC v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B550 AORUS PRO AC v: x.x serial: <superuser required>
UEFI: American Megatrends v: F10 date: 09/18/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
status: discharging
RAM: total: 31.28 GiB used: 3.28 GiB (10.5%)
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201006
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2419 high: 3707 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3707 2: 3138
3: 2053 4: 2054 5: 2212 6: 2052 7: 2053 8: 2052 9: 3631 10: 3195 11: 2052
12: 2053 13: 2303 14: 2055 15: 2053 16: 2053 bogomips: 121408
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
prctl and seccomp
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Dell S2421NX serial: <filter>
built: 2021 res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon RX 6800 (navi21 LLVM
14.0.6 DRM 3.41 5.13.19-2-MANJARO) direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 1-3:2 chip-ID: 1532:0537 gen: 4 speed: 16 GT/s class-ID: 0300
serial: <filter> lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA Kraken V3 X type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-5:3 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci1 rfk-id: 2 state: up address: see --recommends
Device-2: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12 BCM20702A0] type: USB
driver: btusb v: 0.8 bus-ID: 3-4:2 chip-ID: 19ff:0239 class-ID: fe01
serial: <filter>
Report: ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 2.96 TiB used: 608.72 GiB (20.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUA723020ALA640
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: NS00 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: THNSNJ256GCST
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0102 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WDBNCE0010PNC
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.94 GiB (98.32%)
used: 608.71 GiB (67.1%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 45541690-78c8-42d0-a61c-28fee78274a2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: C730-9A4C
dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: f4a9258e-7db2-4457-a378-1e44e5fe2eb9
ID-1: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: D
uuid: C42415DB2415D172
ID-2: /dev/sdb1 maj-min: 8:17 size: 350 MiB fs: ntfs label: System Reserved
uuid: 3A2CC7612CC716B3
ID-3: /dev/sdb2 maj-min: 8:18 size: 238.13 GiB fs: ntfs label: N/A
uuid: FE32C91932C8D833
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: Razer USA Kraken V3 X type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:0537 class-ID: 0300
serial: <filter>
Device-2: 1-5:3 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-2: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7:5 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-8:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-3: 1-10:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12
BCM20702A0] type: Bluetooth driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 19ff:0239 class-ID: fe01
serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 40.1 C mobo: N/A gpu: amdgpu temp: 49.0 C
mem: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 369 Uptime: 11m wakeups: 2 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1591
pm: pacman pkgs: 1579 libs: 450 tools: pamac pm: flatpak pkgs: 0 pm: snap
pkgs: 12 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
