Again: Multi monitor set up
Is there a way to somehow lock or glue down my multi monitor setup so that the set up will not be messed up after monitor are turned of by “power save”?
I’m running KDE Plasma v: 6.0.5 Manjaro Linux and the only way to prevent a total mess is to turn off the “switch of monitor when idle”. I there better solution? What info shall I provide?
I don’t recall seeing this with Plasma 6.1.4 which is now in testing branch.
6.2 is coming closer - primo October.
So I’ll wait till October… This has been a real shame and a pain in the butt. Hopefully there is a cure. Thx for you answer.
