Hi there,
I have similar problem and I followed steps described on another post:
rm manjaro-keyring* archlinux-keyring*
curl -O https://mirror.easyname.at/manjaro/pool/overlay/manjaro-keyring-20230616-3-any.pkg.tar.xz
curl -O https://mirror.easyname.at/manjaro/pool/sync/archlinux-keyring-20230704-1-any.pkg.tar.zst
ls
sudo rm -r /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman -U manjaro-keyring-20230616-3-any.pkg.tar.xz archlinux-keyring-20230704-1-any.pkg.tar.zst
sudo pacman-key --populate manjaro archlinux
However I’m not able to fix it. Did exactly what is described on above post. Latest keys are in the folder.
Error uknown trust shows up when I try to import keys with the command:
sudo pacman -U manjaro-keyring*.pkg.tar.xz archlinux-keyring*.pkg.tar.zst ✔
error: manjaro-sway: key "A44C644D792767CED7941AFEABB2075D5F310CF8" is unknown
:: Import PGP key A44C644D792767CED7941AFEABB2075D5F310CF8? [Y/n] y
error: manjaro-sway: signature from "Jonas Strassel <info@jonas-strassel.de>" is unknown trust
error: database 'manjaro-sway' is not valid (invalid or corrupted database (PGP signature))
loading packages...
error: failed to prepare transaction (invalid or corrupted database)
I’ve seen Pacman Troubleshooting page also but it wasn’t helpful. What else I can do?
Thanks!
