After waking the pc i need to re-activate WIFI network
after waking the pc from sleep: i always find the there is no WIFI network detected, so i need to re-activate WIFI network to detect the networks again.
what can cause this problem? and how to fix it?
inxi -Farz         ✔
  Kernel: 6.9.0-rc4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=94056c3c-7682-4647-ae52-62c2357c4be2 rw
    resume=UUID=16903b87-9499-4dcb-907d-8ae397807ed4 udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.1.0
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: Latitude 7480 v: N/A
  Mobo: Dell model: 0CDXCF v: A00 serial: <superuser required> part-nu: 07A0
    uuid: <superuser required> UEFI: Dell v: 1.36.0 date: 01/29/2024
  ID-1: BAT0 charge: 15.2 Wh (72.4%) condition: 21.0/60.0 Wh (34.9%)
    volts: 7.6 min: 7.6 model: SMP DELL DM3WC64 type: Li-poly serial: <filter>
    status: discharging
  Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 600 min/max: 400/3000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 600 2: 600 3: 600 4: 600 bogomips: 20004
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
    class-ID: 0300
  Device-2: Microdia HP Integrated Webcam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:6321
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 11.29 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel
    v: 24.0.5-manjaro1.1 device-ID: 8086:1916 surfaces: xcb,xlib,wayland
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.9.0-rc4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  Local Storage: total: 238.47 GiB used: 148.02 GiB (62.1%)
    model: MZVLQ256HBJD-00BH1 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: HPS1NFAV temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 59.8 GiB size: 58.56 GiB (97.93%) used: 28.67 GiB (49.0%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
    used: 31.9 MiB (8.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 170.46 GiB size: 166.72 GiB (97.81%)
    used: 117.18 GiB (70.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 7.81 GiB used: 2.14 GiB (27.4%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 33.0 C pch: 30.0 C mobo: 27.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1644 libs: 427 tools: octopi,pamac pm: flatpak
    pkgs: 0
    1: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
    3: https://mirror.easyname.at/manjaro/testing/$repo/$arch
    4: https://mirror.dkm.cz/manjaro/testing/$repo/$arch
    5: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    7: https://mirror.kku.ac.th/manjaro/testing/$repo/$arch
    8: https://mirrors.tuna.tsinghua.edu.cn/manjaro/testing/$repo/$arch
  Memory: total: 12 GiB available: 11.56 GiB used: 6.94 GiB (60.0%)
  Processes: 274 Power: uptime: 2d 7h 59m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 30 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 4.62 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
Without any information no one can help.
Maybe begin with system information.
inxi -Farz
At face value, I’d guess that the machine is hibernating and some devices will automatically be turned off in the process. In that event, if the WiFi is not immediately available, you might just need to wait a few minutes.
If hibernation is the catalist, then you might consider choosing a different (non-hibernation) sleep state in power settings and see it that makes any obvious difference.
Other than that random thought, I’ll simply add :man_shrugging:
Cheers.
usually i click the “sleep” button and not “hibernate”
