After upgrade to Gnome 49.2 and login files and menus and setting not working
After huge update today and download over 6GB and reboot after login to gnome setting and file not loading and I can not use them for example I want use file for copy some files from my home to USB it not working and can not open.
for example I can not open setting and change some setting for example add new language to desktop nothing happen
inxi -zv5         ✔
  Kernel: 6.1.159-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
  Desktop: GNOME v: 49.2 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME H310M-R R2.0 v: Rev X.0x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: 2208 date: 07/09/2021
  System RAM: total: 24 GiB available: 23.42 GiB used: 4.09 GiB (17.5%)
  Device-1: ChannelA-DIMM1 type: DDR4 size: 16 GiB speed: 2666 MT/s
  Device-2: ChannelB-DIMM1 type: DDR4 size: 8 GiB speed: 2666 MT/s
  Info: 6-core model: Intel Core i7-8700K bits: 64 type: MT MCP
    arch: Coffee Lake rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
  Speed (MHz): avg: 4486 min/max: 800/4700 cores: 1: 4486 2: 4486 3: 4486
    4: 4486 5: 4486 6: 4486 7: 4486 8: 4486 9: 4486 10: 4486 11: 4486 12: 4486
    bogomips: 88824
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ASUSTeK driver: nvidia
    v: 470.256.02 arch: Kepler-2 bus-ID: 01:00.0
  Display: wayland server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch resolution: 1: 1920x1080~60Hz
    2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
    active: gbm,wayland,x11,surfaceless,device inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 21.1.6 256 bits)
  API: Vulkan v: 1.4.328 drivers: nvidia surfaces: N/A devices: 1
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: corectrl,
    nvidia-settings, nvidia-smi x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1
  API: ALSA v: k6.1.159-1-MANJARO status: kernel-api
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: off
  Server-3: PipeWire v: 1.4.9 status: active
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
  IF-ID-1: br-14d1814f7354 state: down mac: <filter>
  IF-ID-2: br-403a71a3b8da state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-5: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 1.14 TiB used: 756.59 GiB (64.7%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
    size: 931.51 GiB temp: 35 C
  ID-2: /dev/sdb vendor: Gigabyte model: GP-GSTFS31256GTND size: 238.47 GiB
    temp: 33 C
  ID-1: / size: 931.22 GiB used: 756.59 GiB (81.2%) fs: btrfs dev: /dev/sda2
    label: N/A uuid: 7df37fe0-544b-4b16-afca-3ca98d11d402
  ID-2: /boot/efi size: 299.4 MiB used: 612 KiB (0.2%) fs: vfat
    dev: /dev/sda1 label: N/A uuid: 2326-0454
  ID-3: /home size: 931.22 GiB used: 756.59 GiB (81.2%) fs: btrfs
    dev: /dev/sda2 label: N/A uuid: 7df37fe0-544b-4b16-afca-3ca98d11d402
  ID-4: /var/log size: 931.22 GiB used: 756.59 GiB (81.2%) fs: btrfs
  System Temperatures: cpu: 61.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 398 Uptime: 1h 49m Init: systemd
  Packages: 2654 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9
    inxi: 3.3.40
I would say it happens because of the removal of X11 since v49 See:
Nvidia 470xx doesn’t work with wayland, therefore it works only in Xwayland. I would guess that it is the lack of GBM support (GPU acceleration), which is a prerequisite for new GTK4 applications such as Nautilus or Gnome Settings, so a “Renderer-Collapse”.
Try to run it like this for testing purpose:
nautilus -q && GDK_RENDERER=software GSK_RENDERER=gl nautilus
In any case, it’s not a good idea to continue using Gnome with this old Nvidia GPU and the 470xx driver. Switch to XFCE, for example, which still has X11 support.
nautilus -q && GDK_RENDERER=software GSK_RENDERER=gl nautilus         ✔
** Message: 13:32:17.956: Connecting to org.freedesktop.Tracker3.Miner.Files
GSConnect: [Errno 2] No translation file found for domain: 'org.gnome.Shell.Extensions.GSConnect'
I use this desktop on my office and they can not change itPlease help me to fix it with currentI do want use Gnome not xfce and I see
nautilus         255 ✘
\*\* Message: 13:37:19.250: Connecting to org.freedesktop.Tracker3.Miner.Files
GSConnect: \[Errno 2\] No translation file found for domain: ‘org.gnome.Shell.Extensions.GSConnect’
libEGL warning: pci id for fd 29: 10de:1287, driver (null)
pci id for fd 38: 10de:1287, driver (null)
pci id for fd 40: 10de:1287, driver (null)
libEGL warning: egl: failed to create dri2 screen
zsh: segmentation fault (core dumped)  nautilus
If your hardware cannot handle Gnome using Wayland - there is not much one can suggest or do…
  • Gnome is Gnome - this is how it is.
  • Nvidia is Nvidia - this is how it is.
The following is only an idea - I don’t know if it will work for you - I have nothing better to suggest.
If so, then the only option would be the nouveau driver. Remove the offical nvidia as @linux-aarhus suggested and nouveau will take place after a reboot. This driver supports GBM.
In your case, it must be (just guessing):
sudo mhwd --install pci video-linux
sudo mhwd --remove pci video-nvidia-470xx
reboot
However you can check which config is actually installed: mhwd --listinstalled
sudo mhwd --install video-nvidia-570xx
Error: invalid use of option: -i/--install
Usage: mhwd [OPTIONS] <config(s)>
  --pci					list only pci devices and driver configs
  --usb					list only usb devices and driver configs
  -h/--help				show help
  -v/--version				show version of mhwd
  -f/--force				force reinstallation
  -d/--detail				show detailed info for -l/-li/-lh
  -l/--list				list available configs for devices
  -la/--listall				list all driver configs
  -li/--listinstalled			list installed driver configs
  -lh/--listhardware			list hardware information
  -i/--install <usb/pci> <config(s)>	install driver config(s)
  -ic/--installcustom <usb/pci> <path>	install custom config(s)
  -r/--remove <usb/pci> <config(s)>	remove driver config(s)
  -a/--auto <usb/pci> <free/nonfree> <classid>	auto install configs for classid
  --pmcachedir <path>			set package manager cache path
  --pmconfig <path>			set package manager config
  --pmroot <path>			set package manager root
sudo mhwd --remove pci video-nvidia-470xx         ✔
> Removing video-nvidia-470xx...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia-470xx/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies...
:: removing libxnvctrl-470xx breaks dependency 'libxnvctrl' required by sensors-applet
Error: pacman failed!
Error: script failed!
Remove sensors-applet and libxnvctrl first. Can be reinstalled afterward. Then try again.
I use this post and right now I can use my system
I try install
but GDM not starting and I can not get shell by ALT+SHIFT+F2
Moderator edit: Corrected glaring typo…
Because 570xx has no support for a GT730. You can probably install it, but it will not work.
Remove the video-nvidia - and install video-linux (opensource)
mhwd -r pci video-nvidia-570xx
mhwd -i pci video-linux
I do not know why after remove nvidia drive and use open source driver of nvidia my system is slow and has some lags
Please help me to find cause and fix it.
Nouveau is a open sourve driver that is not maintained by Nvidia.
Unfortunately it don’t have the same performance of the proprietary one.
Maybe this slow response is caused by some wrong setting, but maybe is the driver itself.
The refresh rate or your monitor is corrected set?
I set 1920*1080(16:9)
and refresh rate is 75.00 Hz
After remove Nvidia driver Gnome is slow and specially google chrome is very slow and I see lags
Have you tried to set the refresh rate to 60.
I find problem I use telegram desktop app , after remove it and use telegram web everything be OK and I have less lags and freeze
