After upgrade could no longer install Wayfire
I had both Plasma and Wayfire desktops installed. Had to remove Wayfire to do the updates, as there were conflicts. After upgrade could no longer install Wayfire with the Wayfire-desktop-git build. Since that is form AUR I do not expect a fix anytime soon, just wanted to let people know that if they have Wayfire-desktop-git they might want to check carefully before updating to this level.
Apparently it’s an orphan, so you may never get a fix. With just a quick look, I see there are a bunch of other wayfire packages in the AUR but no idea which would be similar to this.
Wrong package. :wink:
Wayland - ArchWiki
Is it?
Maybe @wpeckham can clarify.
wayfire-desktop-git is an improperly named meta package. :wink:
Tried that, and it runs into EXACTLY the same issues.
