After updating the system, oc does not load.
Already tired of reinstalling drivers does not help.
graphics card gtx 1060
i see you have a command line.
try to directly start your system with command:
startx
if it not work, first check xserver settings:
https://wiki.manjaro.org/index.php/Did_X.server_recognise_your_monitor_correctly%3F
try to reinstall your video driver with a free one:
https://wiki.manjaro.org/index.php/Configure_Graphics_Cards
The command
modprobe yourvideodriver
does nothing?
modprone: Fatal: Module yourvideodriver not found in directory /lib/modules/6.2.0-2-rt3-MANJARO
Through the server did not work. Regarding drivers sudo mhwd -a pci nonfree 0300 error, "pacman failed " “script failed”. Here it is without errors sudo pacman -S --overwrite "*" linux515-nvidia but didn’t help.
first rerun update again:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
if no errors and you are up to date, provide full output/picture from:
startx
and also output from:
mhwd -l -li
mhwd-kernel -li
I can’t embed photos so text
startx
X Org X Seruer 1.21.1.8
X Protoco1 ersion 11, Reuis ion 0
Current Operating System : Linux user-2 6.2.0-2-rt3-MANJARO #1 SMP PREEMPT_RT Se
Apr 16 02:12:15 UTC 2023 x86_64
Kernel command 1ine: B00T_IMAGE=/boot/uml inuz-6.2-rt-x86 64 root=UUID=blac2fbb-
550-4778-b0c9-7a9a8c4dOcf2 rw nouueau modeset=0 quiet cryptdeuice-UUID=3d562315
97b1-4b89-bc61-702143e324b6 : luks-3d562315-97b1-4b89-bc61-702143e324b6 root=/deu.
mapper/luks-34562315-97b1-4b89-bc61-702143e324b6 apparmor=1 secur ity=apparmor ue
eu. log prior ity=3
Current version of piKman: 0 42 2
Before report ing problems, check wiki-X
to make sure that you haue the latest uersion.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (??) not ice, (ID informat ional,
(WW) warning, (EE) error,
(==) Log fi le: “/home/user/. local/share/xorg/Xorg 0 log”,
(NID not implemented, (??) unknoun.
:12 2023
(==) Using
conf ig file: "/etc/X11/x0rg conf9
(==) Using config directory: “etc/X11/xorg conf d”
(==) Using system config directory “/usr/share/X11/xorg conf d’
ion. EE) (EE) Seruer terminated with error (1). Closing log fi le.tional informat
xinit: giuing up
xinit: unable to connect to X server: Connection refused
. Time: Tue May 9
xinit: server error
mhwd -l -li
Name
Video-nvideo - 2023.03.23 - false - psi
Video Nvidia 470xx - 2023.03.23 - false - psi
Video Nvidia 390xx - 2023.03.23 - false - psi
Video -linux -2018.05.04 - true pci
Video- modesetting 2020 01. 13 true pci
Video vesa 2017 03 12 true pci
mhwd-kernel -li
6.2.0-2-rt3-MANJARO linux62)
The fol low ing kerne ls are instal led in your system:
Linux515
Linux518-rt
Linux62-rt
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
what do you mean you cant post pictures? how did you post pictures in your first post?
the mhwd -l -li output doesnt say what you have installed…
do you have manjaro live usb?
you have one dead kernel so remove it:
sudo mhwd-kernel -r linux518-rt
then remove this:
sudo mhwd -r pci video-linux
and install proper drivers:
sudo mhwd -i pci video-nvidia
reboot
what are those squares? but it looks like its exist in filesystem issue…
do you have manjaro live usb? it would be better to repair it from there
I don’t know, but I can do it.
if anything, I have os esch encryption
live usb yes
boot into manjaro live usb, make sure you are connected to internet, open terminal and post output from:
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
you dont need to post pictures, you can just copy the output here, it would be better…
so chroot:
sudo cryptsetup -v luksOpen /dev/nvme0n1p1 cryptDrive
sudo mount /dev/mapper/cryptDrive /mnt
sudo manjaro-chroot /mnt
if there were errors, post them here, if not, post output from:
pacman -Qm
pacman -Qs nvidia
EDIT:
also post output from:
ldconfig
if its too long, dont post it…
sh-5.1# pacman -Qm
amberol 0.9.1-1
anydesk-bin 6.2.1-2
badvpn-git r1950.07268f0-1
gnome-icon-theme 3.12.0-6
gnome-icon-theme-symbolic 3.12.0-6
google-chrome 112.0.5615.165-1
kazam 1.4.5-9
linux518-headers 5.18.19-3
linux519-headers 5.19.17-2
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
nordnm-git 0.8.1-1
openssl-1.0 1.0.2.u-1
openvpn-openssl-1.0 2.4.9-2
ovpnsplit 0.2.0-1
proxy-ns 1.0.7-1
redsocks-git 0.5.r11.g19b822e-1
remmina-plugin-teamviewer 1.3.0.0-3
simplescreenrecorder 0.4.4-1
systemd-fsck-silent 239-1
teamviewer 15.40.6-1
virtio-win 0.1.225.2-1
virtualbox-bin-guest-iso 7.0.2-1
yay-git 11.3.1.r119.g0387dfd-1
zoom 5.11.10-1
sh-5.1# pacman -Qs nvidia
local/egl-wayland 2:1.1.11-4
EGLStream-based Wayland external platform
local/libvdpau 1.5-1
Nvidia VDPAU library
local/linux515-nvidia 530.41.03-6 (linux515-extramodules)
NVIDIA drivers for linux
local/mhwd-nvidia 530.41.03-4
MHWD module-ids for nvidia 530.41.03
local/mhwd-nvidia-390xx 390.157-6
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.182.03-2
MHWD module-ids for nvidia 470.182.03
local/nvidia-utils 530.41.03-4
NVIDIA drivers utilities
sh-5.1#
and use formatting for the outputs, click this icon in editor </> and copy the output there;
or use:
your output here
remove these:
pacman -R linux518-headers linux519-headers manjaro-documentation-en manjaro-firmware linux515-nvidia nvidia-utils
and then post output from:
ldconfig
shows nothing on output ldconfig
so now install video drivers:
if there are errors, post them here
