My System Info
- Kernel 6.6.63-1 LTS
- KDE Plasma 6.2.4
- AMD Ryzen 7 7800X3D
- X11
After updating and rebooting, the NVIDIA driver failed to load. I reinstalled the driver via the terminal and got the KDE log screen to load:
sudo mhwd -r pci video-nvidia
sudo mhwd -i pci video-nvidia
After rebooting, I got my usual login screen and proceeded to log into my account and everything was slow until it became fully unresponsive.
I forced rebooted the computer and switch from X11 to Wayland. Using Wayland I was able to get KDE up and running.
While checking the logs I noticed there’s a mismatched between the NVIDIA drives and the kernel module.
Driver version is 550.135 while the kernel module is 550.120.
[36356.158477] NVRM: API mismatch: the client has the version 550.135, but
NVRM: this kernel module has the version 550.120. Please
NVRM: make sure that this kernel module and all NVIDIA driver
NVRM: components have the same version.
# modinfo nvidia
filename: /lib/modules/6.6.54-2-MANJARO/extramodules/nvidia.ko.xz
alias: char-major-195-*
version: 550.120
supported: external
license: NVIDIA
firmware: nvidia/550.120/gsp_tu10x.bin
firmware: nvidia/550.120/gsp_ga10x.bin
srcversion: 7E8999DB9AD1F16F0BED033
alias: pci:v000010DEd*sv*sd*bc06sc80i00*
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
retpoline: Y
vermagic: 6.6.54-2-MANJARO SMP preempt mod_unload
# pacman -Qikk nvidia
Version : 550.135-2
Description : NVIDIA drivers for linux
Architecture : x86_64
URL : http://www.nvidia.com/
Licenses : custom
Groups : linux66-extramodules
Provides : nvidia=550.135 NVIDIA-MODULE
Depends On : linux66 nvidia-utils=550.135
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 51.02 MiB
Packager : Philip Mueller <philm@manjaro.org>
Build Date : sáb 23 nov 2024 20:03:36
Install Date : dom 01 dic 2024 08:12:33
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
linux66-nvidia: 14 total files, 0 altered files
X11 does not properly work after the update while running Kernel 6.6 LTS.
