After yesterday updates (2024-10-08), Manjaro can’t reboot or shutdown. It just show blank screen and nothing happen (mouse and keyboard are working). There I can turn off or reboot, then I press power button and use “Switch user”.
sudo shutdown is working.
After updates, shutdown screen was changed:
Before it was like this:
inxi:
Summary
Kernel: 6.10.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=eccc78ae-a2e1-49c9-a78f-9c39efaf08fb rw quiet splash acpi=force
apm=power_off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Portable System: Dell product: Inspiron 7720 v: N/A
serial: Chassis: type: 8 v: 0.1
serial:
Mobo: Dell model: 04M3YM v: A00 serial:
uuid: UEFI-[Legacy]: Dell v: A12 date: 12/18/2012
System RAM: total: 8 GiB available: 7.61 GiB used: 2.55 GiB (33.4%)
Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B5273EB0-CK0 serial:
Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
Info: model: Intel Core i7-3630QM bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1200 min/max: 1200/3400 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 bogomips: 19162
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
disabled
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: HDMI-A-1,LVDS-1 empty: DP-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 650M] vendor: Dell driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:0fd1
class-ID: 0300
Device-3: Suyin Laptop_Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:4
chip-ID: 064e:8126 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: intel dri: i965 gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1184 s-dpi: 96 s-size: 1013x312mm (39.88x12.28")
s-diag: 1060mm (41.73") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: Idek Iiyama PLX2783H serial:
built: 2021 res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: LVDS-1 model: ChiMei InnoLux 0x1720 built: 2011 res: 1920x1080
dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
device-ID: 8086:0166 memory: 1.46 GiB unified: yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k6.10.11-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:0887
class-ID: 0280
IF: wlp2s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp3s0 state: down mac:
IF-ID-1: br-27f6707ba464 state: down mac:
IP v4: scope: global broadcast:
IF-ID-2: br-5b8827f2ead5 state: down mac:
IF-ID-3: br-628943c57393 state: down mac:
IF-ID-4: br-71e1190f8cb5 state: down mac:
IF-ID-5: br-961d2e4558b4 state: down mac:
IF-ID-6: br-a248d3b92d7b state: down mac:
IF-ID-7: br-a86628535cea state: down mac:
IF-ID-8: br-b73814262b13 state: down mac:
IF-ID-9: br-c91ce88d9c0e state: down mac:
IF-ID-10: br-d3f4f9bae4f6 state: down mac:
IF-ID-11: br-d50ad4bc7378 state: down mac:
IF-ID-12: docker0 state: down mac:
Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
WAN IP:
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.5:3
chip-ID: 8087:07da class-ID: e001
Local Storage: total: 1.37 TiB used: 334.7 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 1B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: fw-rev: 0003 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Netac model: SSD 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: fw-rev: 4A0 scheme: MBR
ID-1: / raw-size: 224.08 GiB size: 219.51 GiB (97.96%)
used: 84.48 GiB (38.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: eccc78ae-a2e1-49c9-a78f-9c39efaf08fb
ID-2: /media/hdd1000 raw-size: 916.09 GiB size: 900.64 GiB (98.31%)
used: 250.23 GiB (27.8%) fs: ext4 dev: /dev/sdb5 maj-min: 8:21 label: N/A
uuid: dbd8d613-2ea4-4203-a604-dccb0afa1aa0
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 42c778e5-dd0d-49bc-af0c-60e8ac21b178
ID-1: /dev/sdb1 maj-min: 8:17 size: 500 MiB fs: vfat label: ESP
uuid: BE8C-F8E9
ID-2: /dev/sdb2 maj-min: 8:18 size: 40 MiB fs: vfat label: DIAGS
uuid: E41B-6882
ID-3: /dev/sdb3 maj-min: 8:19 size: 128 MiB fs:
label: N/A uuid: N/A
ID-4: /dev/sdb4 maj-min: 8:20 size: 500 MiB fs: ntfs label: WINRETOOLS
uuid: 1A201CAF201C943B
ID-5: /dev/sdb6 maj-min: 8:22 size: 450 MiB fs: ntfs label: N/A
uuid: 96C40648C4062AD7
ID-6: /dev/sdb7 maj-min: 8:23 size: 13.84 GiB fs: ntfs label: PBR Image
uuid: DC86354986352584
ID-7: /dev/sdc1 maj-min: 8:33 size: 350 MiB fs: ntfs
label: \xd0\x97\xd0\xb0\xd1\x80\xd0\xb5\xd0\xb7\xd0\xb5\xd1\x80\xd0\xb2\xd0\xb8\xd1\x80\xd0\xbe\xd0\xb2\xd0\xb0\xd0\xbd\xd0\xbe \xd1\x81\xd0\xb8\xd1\x81\xd1\x82\xd0\xb5\xd0\xbc\xd0\xbe\xd0\xb9
uuid: 8688B67D88B66B77
ID-8: /dev/sdc2 maj-min: 8:34 size: 237.59 GiB fs: ntfs label: N/A
uuid: 72D2C0D5D2C09F2B
ID-9: /dev/sdc3 maj-min: 8:35 size: 549 MiB fs: ntfs label: N/A
uuid: 1EA039FEA039DCC9
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.3:3 info: Realtek RTS5129 Card Reader Controller
type: driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial:
Device-2: 1-1.5:4 info: Suyin Laptop_Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 064e:8126 class-ID: 0e02
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.5:3 info: Intel Centrino Bluetooth Wireless Transceiver
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 8087:07da
class-ID: e001
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-2:2 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-2.3:4 info: A4Tech Keyboard (FK11) type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 09da:2268 class-ID: 0300
Device-2: 3-3:3 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 18f8:0f97 class-ID: 0300
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 71.0 C mobo: 52.0 C sodimm: SODIMM C
Fan Speeds (rpm): N/A
Processes: 233 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.02 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1444 libs: 398 tools: pamac pm: flatpak pkgs: 0
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.32 running-in: far2l inxi: 3.3.36
~$ journalctl -p 3 -xb
окт 09 06:05:20 pcname kernel: Bluetooth: hci0: unexpected event for opcode 0x0000
окт 09 06:05:35 pcname org_kde_powerdevil[1389]: busno=4, All features that should not exist detected. Monitor does not indicate unsupported
