When I say Vulcan 23.1.0 I do not mean the Vulkan from Khronos Group I mean the version of Manjaro distribution. The update to Vulcan 23.1.0 (GNOME 45) changed my background and caused the drawer to stop working. I cannot access my applications. Any ideas?
There is no vulcan in manjaro repo.
However Mesa - on all branches - contains vulkan-* 23.1.9 and thus your primary mirror is not up-to-date.
I suggest you open a terminal - better switch to console mode (TTY) - and rebuild your mirrorlist and run a full system sync.
sudo pacman-mirrors --continent && sudo pacman -Syyu
I don’t speak about Vulkan the Khronos Group API but for Vulcan with c the name of the Manjaro Version as looks below
Please don’t use images - please remove it - you should be able to express in words what you mean.
The name means nothing as Manjaro is rolling - you could call it an ISO name - but that is all there is to it.
I removed the image. How I can tell the current rolling snapshot version in order to help others to help me?
lsb_release can provide this information
lsb_release --all
lsb_release --codename --release
It has been codename Vulcan and 23.1.0 for quite some time - in fact the codename and release changes well before a new ISO is created.
But the snapshot doesn’t mean anything - as it is expected your system is kept in sync.
Please ensure your system is synced to a current up-to-date mirror. You can check your primary mirror with (sample)
$ pacman-mirrors --status
Local mirror status for unstable branch
Mirror #1 OK 00:17 Austria https://mirror.easyname.at/manjaro/
If the first mirror is not OK - rebuild your mirrorlist
Then run
sudo pacman -Syu
Then recheck if your issue persist
I have to ask - perhaps a stupid question - but since I have not used Gnome as DE for a long time - drawer - is that an extension or an app?
If it is
- is it in the official repo?
- is it from AUR?
- is it from Gnome Extensions web?
I found the solution. I went to Dash to Dock Settings > Launchers > Animate Show Applications. Probably the update reset the option. I use the Manjaro layout from the Layout Switcher.
