Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=f6b1fe1f-7509-4637-817d-260c9d4a5fc8 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Acer product: Aspire A314-23P v: V1.04
Mobo: MDU model: Evelyne_MDU v: V1.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.04
date: 12/09/2022
ID-1: BAT0 charge: 30.7 Wh (77.9%) condition: 39.4/41.8 Wh (94.4%)
power: 5.7 W volts: 12.1 min: 11.2 model: LGC AP19B8K type: Li-ion
serial: <filter> status: discharging cycles: 112
System RAM: total: 8 GiB available: 7 GiB used: 5.55 GiB (79.3%)
Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: spec: 6400 MT/s actual: 5500 MT/s volts:
curr: 0.5 min: 0.5 max: 0.5 width (bits): data: 32 total: 32
manufacturer: Samsung part-no: K3LKBKB0BM-MGCP serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 5 7520U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0xA0 (160) stepping: 0
microcode: 0x8A00008
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1912 high: 2800 min/max: 900/6735 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2800 2: 2800
3: 2800 4: 900 5: 900 6: 2800 7: 900 8: 1397 bogomips: 44730
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt x2apic xgetbv1
xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Mendocino vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 off: eDP-1
empty: DP-1,DP-2 bus-ID: 03:00.0 chip-ID: 1002:1506 class-ID: 0300
temp: 40.0 C
Device-2: Quanta ACER HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 0408:403a
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: LG (GoldStar) IPS FULLHD built: 2014
res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
x: 0.306 y: 0.631 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900,
1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480, 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2016 res: 1920x1080
dpi: 158 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
raphael_mendocino LLVM 17.0.6 DRM 3.54 6.5.13-7-MANJARO)
device-ID: 1002:1506 memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.0.9-manjaro1.1 device-ID: 1002:1506 surfaces: xcb,xlib
Device-1: AMD Rembrandt Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: MEDIATEK vendor: AzureWave driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 14c3:7902
class-ID: 0280
Device-2: Realtek RTL88x2bu [AC1200 Techkey] driver: rtw_8822bu type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0bda:b812
class-ID: 0000 serial: <filter>
IF: wlp3s0f4u2 state: up mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 13d3:3594
Local Storage: total: 476.94 GiB used: 22.63 GiB (4.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA512TFK
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 30.9 C
scheme: GPT
ID-1: / raw-size: 30.17 GiB size: 29.53 GiB (97.87%) used: 22.58 GiB (76.5%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: f6b1fe1f-7509-4637-817d-260c9d4a5fc8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 56.1 MiB (21.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: AA10-8085
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 445.5 GiB fs: ntfs label: Acer
uuid: 66C4110CC410E05B
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1024 MiB fs: ntfs
label: Recovery uuid: 205011B550119320
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-2:2 info: Quanta ACER HD User Facing type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:403a class-ID: fe01
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-1:2 info: SteelSeries ApS Rival 100 Gaming Mouse
type: HID,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 130mA
chip-ID: 1038:1702 class-ID: 0301
Device-2: 3-2:3 info: Realtek RTL88x2bu [AC1200 Techkey] type: Network
driver: rtw_8822bu interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:b812 class-ID: 0000
serial: <filter>
Device-3: 3-3:4 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3594 class-ID: e001 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1281 libs: 345 tools: pamac pm: flatpak pkgs: 0
1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
2: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
8: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
No active dnf repos in: /etc/dnf/dnf.conf
Processes:
CPU top: 5 of 266
1: cpu: 16.3% command: firefox pid: 1680 mem: 625.1 MiB (8.7%)
2: cpu: 9.7% command: firefox pid: 5660 mem: 461.1 MiB (6.4%)
3: cpu: 3.6% command: firefox pid: 2657 mem: 111.0 MiB (1.5%)
4: cpu: 3.5% command: Xorg pid: 573 mem: 149.5 MiB (2.0%)
5: cpu: 3.5% command: kwin_x11 pid: 773 mem: 236.2 MiB (3.2%)
Memory top: 5 of 266
1: mem: 1150.7 MiB (16.0%) command: pamac-manager pid: 1523 cpu: 0.3%
2: mem: 625.1 MiB (8.7%) command: firefox pid: 1680 cpu: 16.3%
3: mem: 563.8 MiB (7.8%) command: firefox pid: 2196 cpu: 2.3%
4: mem: 558.7 MiB (7.7%) command: plasmashell pid: 812 cpu: 1.3%
5: mem: 461.1 MiB (6.4%) command: firefox pid: 5660 cpu: 9.7%
Processes: 266 Power: uptime: 1h 1m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 2.79 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
Also, I believe it is the major update cause I had not logged into linux (I use it to learn linux) for about 2.5 months
