Hey there,
After the stable update to Gnome 44 OBS Studio has stopped opening. When run from the terminal I get the following error:
obs: error while loading shared libraries: libpython3.10.so.1.0: cannot open shared object file: No such file or directory
This makes perfect sense, as the currently installed Python is 3.11 (per system updates - I did not update it manually). Should I try to downgrade Python? Shouldn’t OBS have Python 3.10 as a dependency?
Thanks!
Alan
Inxi:
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=20705b87-eec6-4fb3-8353-031c51df1cac ro quiet splash apparmor=1
security=apparmor udev.log_priority=3 nvidia_drm.modeset=1
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4602
date: 02/23/2023
Device-1: hid-CC20412029RJ2XQAQ-battery model: Apple Inc. Magic Trackpad 2
serial: N/A charge: N/A status: discharging
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2574 high: 3700 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
3: 2200 4: 3700 5: 3700 6: 2200 7: 2200 8: 3012 9: 3700 10: 2200 11: 2200
12: 3700 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200
20: 2200 21: 2200 22: 2873 23: 2200 24: 2200 bogomips: 177338
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Nanjing Magewell Eco Capture Dual HDMI M.2 vendor: SafeNet
driver: Eco Capture v: N/A alternate: MWEcoCapture pcie: gen: 2 speed: 5 GT/s
lanes: 4 bus-ID: 04:00.0 chip-ID: 1cd7:0051 class-ID: 0400
Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-1,DP-2,DP-3
empty: HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 10de:2182 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :1 screens: 1
Screen-1: 0 s-res: 5440x1080 s-dpi: 96 s-size: 1439x286mm (56.65x11.26")
s-diag: 1467mm (57.76")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: right model: Dell P2418HT
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: DP-2 note: disabled pos: center model: HS133PC built: 2020
res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2 size: 294x166mm (11.57x6.54")
diag: 338mm (13.3") ratio: 3:2, 4:3 modes: max: 1920x1080 min: 640x480
Monitor-3: DP-3 mapped: DP-4 note: disabled pos: primary,left
model: HP E202 serial: <filter> built: 2020 res: 1600x900 hz: 60 dpi: 92
gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9
modes: max: 1600x900 min: 640x480
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
driver: Eco Capture alternate: MWEcoCapture pcie: gen: 2 speed: 5 GT/s
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 0b:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Kingston HyperX Cloud Alpha S
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 7-3:3 chip-ID: 0951:16ed class-ID: 0300
serial: <filter>
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-ac907f97584b state: down mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: veth8975027 state: up speed: 10000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 465.77 GiB used: 336.45 GiB (72.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM13.0 temp: 35.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Garmin model: swm2 size: 9.8 MiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 12 Mb/s
lanes: 1 mode: 1.1 tech: N/A serial: <filter> fw-rev: 1.00
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 336.45 GiB (73.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 31.0 C mobo: 32.0 C
Processes: 447 Uptime: 4h 35m wakeups: 4 Memory: available: 15.53 GiB
used: 3.19 GiB (20.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1684 pm: dpkg
pkgs: 0 pm: pacman pkgs: 1672 libs: 432 tools: gnome-software,pacaur,pamac
pm: flatpak pkgs: 5 pm: snap pkgs: 7 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.27
