After update start on wayland
Hi, the update was perfect, but I realized it now starts directly on Wayland.
I would like to use X11 because some apps like Zoom and Slack are not working properly on Wayland (especially when sharing the screen).
I used to go to Settings → SDDM and choose X11, but now that option has disappeared.
I also installed kwin-x11.
What else do I need to install or how can I change to x11 again?
Thanks!
Known Issues and Solutions
Hi @ZeR0ByTe,
I think the package is plasma-x11-session and can be installed using:
pamac install plasma-x11-session
Thanks @soundofthunder and @Mirdarthos.
I have read the post but I didn’t the line about plasma-x11-session. My fault.
All is working perfectly right now, thanks!
