After Update - Several problems in Wayland mode
Yesterday I did a full system update. And when I tried to use my laptop this morning I had following problems:
  • After entering password in GDM, freeze of mouse and keyboard, switching to TTY not possible, power button was recognized for clean shutdown
  • After reboot in GDM, switching to TTY, login and executing “startx”, UI came up
  • But several problems with apps: Slow start (e.g. Chromium), apps forgetting login data (e.g. Netxcloud client)
  • Using of media keys (like pause) freezes session again
  • Test with separate user account, same problem
I was able to solve the problems by forcing GDM into X11 mode in file
/etc/gdm/custom.conf
by activating the line
WaylandEnable=false
Since then the system behaves normal. Here my INXI output:
  Kernel: 6.6.83-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=0dcaff71-7476-4d2e-a715-ac882a2a5aba rw quiet splash apparmor=1
  Desktop: GNOME v: 47.5 tk: GTK v: 3.24.49 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: TUXEDO product: TUXEDO Book BM15 Gen10 v: N/A
  Mobo: NB01 model: NJ50_70CU serial: <superuser required> part-nu: BM1510
    uuid: <superuser required> UEFI: INSYDE v: 1.07.19I date: 10/24/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
    status: discharging
  Info: model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA6 (166) stepping: 0 microcode: 0xFE
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2100 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2100 2: 2100 3: 2100 4: 2100 5: 2100 6: 2100
    7: 2100 8: 2100 bogomips: 33615
  Type: retbleed mitigation: Enhanced IBRS
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel Comet Lake UHD Graphics vendor: CLEVO/KAPOK driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: HDMI-A-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9bca class-ID: 0300
  Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 04f2:b685
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: primary model: Dell S2721DGF
    serial: <filter> built: 2021 res: mode: 2560x1440 hz: 60 scale: 100% (1)
    dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-2: eDP-1 note: disabled model: ChiMei InnoLux 0x15e8 built: 2016
    res: 2560x1440 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: gpu: nvidia-smi x11: xprop,xrandr
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
  Device-2: Antlion Audio Wireless Microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2.1:5 chip-ID: 2f96:0100 class-ID: 0300
  API: ALSA v: k6.6.83-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: off with: pipewire-media-session
    status: active tools: pw-cat,pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-V vendor: CLEVO/KAPOK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 698.65 GiB used: 261.5 GiB (37.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 25.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 108.16 GiB (47.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 153.34 GiB (33.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Heya,
Not sure what could be the problem, there is no swap configured tho, but since x11 works this does not seem to be a lead.
When switching back to wayland does the journal report anything that might indicate something breaking?
An option to try, newer lts kernel, 6.12
…is incomplete.
Please provide full system information as described (below).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Hi,
here the full INXI output
    base: Arch Linux
    status: discharging
  System RAM: total: 16 GiB available: 15.32 GiB used: 4.3 GiB (28.1%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 min: 1.35 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471A1K43CB1-CTD serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
  Speed (MHz): avg: 800 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 33615
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    loop
    class-ID: 0e02
    dpi: 109 gamma: 1.2 chroma: red: x: 0.686 y: 0.310 green: x: 0.263
    y: 0.671 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 2560x1080, 2048x1152, 1920x1200, 1920x1080, 1920x1080i,
    1600x1200, 1680x1050, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x576i, 720x480, 720x480i, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 90
    res: 2560x1440 dpi: 142 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green:
    x: 0.314 y: 0.600 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
    class-ID: e001
  Local Storage: total: 698.65 GiB used: 261.47 GiB (37.4%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 21.9 C
    scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
    dev-links: cdrom
    used: 108.19 GiB (47.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 0dcaff71-7476-4d2e-a715-ac882a2a5aba
    label: NO_LABEL uuid: C6C4-A646
    used: 153.27 GiB (33.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: cda7cc61-a645-487b-a6a8-c3ab67fbe6f2
  ID-4: /home/johann raw-size: N/A size: 457.38 GiB used: 153.27 GiB (33.5%)
    fs: fuse.gocryptfs source: ERR-102
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Chicony USB2.0 Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b685 class-ID: 0e02
  Hub-2: 1-2:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
  Device-1: 1-2.1:5 info: Antlion Audio Wireless Microphone type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-2: 1-2.2:7 info: Logitech Gaming Keyboard G810 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 046d:c331 class-ID: 0300
    serial: <filter>
  Hub-3: 1-2.3:8 info: Uni Class ports: 4 rev: 1.1
    chip-ID: 10d5:1234 class-ID: 0900
  Device-1: 1-2.3.1:9 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-5:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
  Device-3: 1-10:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-5: 2-4:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0451:8140
  System Temperatures: cpu: 40.0 C pch: 36.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2524 pm: pacman pkgs: 2493 libs: 600 tools: gnome-software,pamac
    pm: flatpak pkgs: 29 pm: snap pkgs: 2
    1: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    2: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    4: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    6: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    8: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 308
  1: cpu: 27.0% command: firefox pid: 2556 mem: 569.9 MiB (3.6%)
  2: cpu: 19.2% command: thunderbird pid: 3220 mem: 472.4 MiB (3.0%)
  3: cpu: 12.8% command: firefox pid: 2950 mem: 249.7 MiB (1.5%)
  4: cpu: 11.9% command: firefox pid: 2715 mem: 244.4 MiB (1.5%)
  5: cpu: 11.6% command: gnome-shell pid: 1786 mem: 326.4 MiB (2.0%)
  Memory top: 5 of 308
  1: mem: 569.9 MiB (3.6%) command: firefox pid: 2556 cpu: 27.0%
  2: mem: 472.4 MiB (3.0%) command: thunderbird pid: 3220 cpu: 19.2%
  3: mem: 326.4 MiB (2.0%) command: gnome-shell pid: 1786 cpu: 11.6%
  4: mem: 249.7 MiB (1.5%) command: firefox pid: 2950 cpu: 12.8%
  5: mem: 244.4 MiB (1.5%) command: firefox pid: 2715 cpu: 11.9%
  Processes: 308 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.11 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Bash v: 5.2.37
    running-in: gnome-terminal inxi: 3.3.37
I also filtered the journalctl by the word “error” and here are the entries of the first boot yesterday where the “fun” began.
-- Boot 8acf8193b80d4d86a74807b8cca7bf16 --
Mär 26 07:50:59 TwiBook kernel: pcieport 0000:00:1c.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Mär 26 07:50:59 TwiBook kernel: pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Mär 26 07:50:59 TwiBook kernel: pcieport 0000:00:1d.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Mär 26 07:50:59 TwiBook kernel: pcieport 0000:00:1d.4: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Mär 26 07:50:59 TwiBook kernel: RAS: Correctable Errors collector initialized.
Mär 26 07:51:01 TwiBook polkitd[878]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Mär 26 07:51:01 TwiBook polkitd[878]: Error opening rules directory: Error opening directory “/usr/local/share/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Mär 26 07:51:06 TwiBook gnome-shell[1151]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Mär 26 07:51:07 TwiBook gsd-sharing[1245]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mär 26 07:51:07 TwiBook gsd-usb-protect[1248]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Mär 26 07:51:07 TwiBook org.gnome.Shell.desktop[1535]: Errors from xkbcomp are not fatal to the X server
Mär 26 07:51:07 TwiBook org.gnome.Shell.desktop[1538]: Errors from xkbcomp are not fatal to the X server
Mär 26 07:51:26 TwiBook gnome-shell[1822]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Mär 26 07:51:26 TwiBook gsd-usb-protect[1988]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Mär 26 07:52:42 TwiBook xdg-desktop-por[2180]: GError set over the top of a previous GError or uninitialized memory.
                                                This indicates a bug in someone's code. You must ensure an error is NULL before it's set.
                                                The overwriting error message was: Fehler beim Aufruf von StartServiceByName für org.freedesktop.impl.portal.desktop.gtk: Zeitüberschreitung wurde erreicht
Mär 26 07:52:46 TwiBook pulseaudio[2314]: Error opening PCM device hw:0: Datei oder Verzeichnis nicht gefunden
Mär 26 07:53:17 TwiBook pulseaudio[1476]: X11 I/O error handler called
Mär 26 07:53:17 TwiBook pulseaudio[1476]: X11 I/O error exit handler called, preparing to tear down X11 modules
Mär 26 07:53:22 TwiBook touchegg.desktop[2109]: terminate called after throwing an instance of 'std::runtime_error'
Mär 26 07:53:22 TwiBook touchegg.desktop[2109]:   what():  Error opening your X11 display. Make sure your DISPLAY environment variable is set
Mär 26 07:53:22 TwiBook tuxedo-control-center-tray.desktop[2137]: The futex facility returned an unexpected error code.
Mär 26 07:53:22 TwiBook gsettings[2911]: failed to commit changes to dconf: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._g_2dfile_2derror_2dquark.Code24: Failed to create file “/home/johann/.config/dconf/user.Y72132”: Transport endpoint is not connected
Mär 26 07:53:22 TwiBook dbus-broker-launch[2955]: ERROR launcher_load_service_dir @ ../dbus-broker-36/src/launch/launcher.c +764: Transport endpoint is not connected
Mär 26 07:53:22 TwiBook dbus-broker-launch[2955]: Exiting due to fatal error: -107
Mär 26 07:53:22 TwiBook dbus-broker-launch[2956]: ERROR launcher_load_service_dir @ ../dbus-broker-36/src/launch/launcher.c +764: Transport endpoint is not connected
Mär 26 07:53:22 TwiBook dbus-broker-launch[2956]: Exiting due to fatal error: -107
Mär 26 07:53:22 TwiBook pulseaudio[2314]: Failed to initialize daemon due to errors while executing startup commands. Source of commands: /etc/pulse/default.pa
-- Boot e95bde4f2a924dd3af880b35b4d30d65 --
I am not sure if I want to switch the kernel version because the system is a productive one, so I am not into experiments here.
Regards
There is no real risk involved. It is generally recommended to have at least one other Kernel installed in case of issues with the one you are currently using.
Your machine is much more recent than mine and I’m currently running linux613 without any apparent issues. You can always switch to another Kernel via the GRUB menu if you have any problems.
Manjaro allows multiple kernels to be installed. You have kernel 6.6 (LTS) installed and likely 6.1 (LTS) as well (guessing).
If you were to replace kernel 6.1 (LTS) with kernel 6.12 (LTS), or install 6.12 (LTS) as an additional kernel, that still leaves 6.6 (LTS) in situ.
This means you can alternately choose to boot with either kernel. Rather than random experimentation this seeks a possible solution without jeopardising your existing kernel.
Aside:- I note also that your system BIOS is out of date (2019). It might be beneficial to look for the latest non-beta BIOS on the manufacturer site. An updated BIOS can often solve known issues and mitigate against known security threats.
Hi,
I upgraded to a newer LTS Kernel
johann@TwiBook ~]$ inxi
CPU: quad core Intel Core i5-10210U (-MT MCP-) speed/min/max: 400/400/4200 MHz
Kernel: 6.12.19-1-MANJARO x86_64 Up: 1m Mem: 2.07/15.32 GiB (13.5%)
Storage: 698.65 GiB (37.5% used) Procs: 298 Shell: Bash inxi: 3.3.37
but the problems remain with Wayland.
I will check a possible BIOS update.
Regards
Hi, today I planned to upgrade the BIOS but I checked the state of the issue. And what I can say, the problem disappeared despite an pending Manjaro update.
set | grep -i way
MEMORY_PRESSURE_WATCH=/sys/fs/cgroup/user.slice/user-1000.slice/user@1000.service/session.slice/org.gnome.Shell@wayland.service/memory.pressure
WAYLAND_DISPLAY=wayland-0
XAUTHORITY=/run/user/1000/.mutter-Xwaylandauth.3JOY62
XDG_SESSION_TYPE=wayland
I post an inxi output again
  Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
  Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
    status: discharging
  System RAM: total: 16 GiB available: 15.32 GiB used: 4.19 GiB (27.3%)
  Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 33615
    loop
    class-ID: 0e02
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-2 model: Dell S2721DGF serial: <filter> built: 2021
    res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.686 y: 0.310 green:
    x: 0.263 y: 0.671 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15e8 built: 2016 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green: x: 0.314 y: 0.600
    modes: 1920x1080
  API: EGL Message: EGL data requires eglinfo. Check --recommends.
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
  API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: off with: pipewire-media-session
    class-ID: e001
  Local Storage: total: 698.65 GiB used: 264.99 GiB (37.9%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 22.9 C
    scheme: GPT
    dev-links: cdrom
    used: 105.22 GiB (46.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 159.77 GiB (34.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  ID-4: /home/johann raw-size: N/A size: 457.38 GiB used: 159.77 GiB (34.9%)
    serial: <filter>
  System Temperatures: cpu: 41.0 C pch: 39.0 C mobo: N/A
  Packages: 2535 pm: pacman pkgs: 2504 libs: 601 tools: gnome-software,pamac
    1: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    2: http://manjaro.grena.ge/stable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    6: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 292
  1: cpu: 15.0% command: firefox pid: 2798 mem: 473.8 MiB (3.0%)
  2: cpu: 10.9% command: thunderbird pid: 3654 mem: 504.4 MiB (3.2%)
  3: cpu: 10.4% command: gnome-shell pid: 1811 mem: 367.0 MiB (2.3%)
  4: cpu: 7.8% command: firefox pid: 3236 mem: 267.3 MiB (1.7%)
  5: cpu: 5.9% command: nextcloud pid: 2042 mem: 229.2 MiB (1.4%)
  Memory top: 5 of 292
  1: mem: 504.4 MiB (3.2%) command: thunderbird pid: 3654 cpu: 10.9%
  2: mem: 473.8 MiB (3.0%) command: firefox pid: 2798 cpu: 15.0%
  3: mem: 367.0 MiB (2.3%) command: gnome-shell pid: 1811 cpu: 10.4%
  4: mem: 267.3 MiB (1.7%) command: firefox pid: 3236 cpu: 7.8%
  5: mem: 246.9 MiB (1.5%) command: firefox pid: 3014 cpu: 3.6%
  Processes: 292 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    tool: systemctl
    running-in: gnome-terminal inxi: 3.3.38
Despite the magical self healing I will do the BIOS update.
Regards
Magical healing does not a solution make. :magic_wand:
Nonetheless, I’m glad you’re back on track.
Topic will be closed without a solution, as magic isn’t overly helpful to others finding this topic. :smile_cat: .
