Hi.
After update (i just installed manajaro gnome…) the terminal app does not work… dont load. (i can install another of course but… why does not work?)
Another problem is the touchpad, does not have the option for scroll with two fingers, dont scroll at all.
Hey @9acca9,
You can check this link for more information about the possible terminal app solution.
TL:DR
- As root edit the file
/etc/locale.gen - Enable the needed locales - including en_US.UTF-8 UTF-8 as fallback.
- Rebuild the locale database using the
locale-genscript
