After doing a system update on 6-12-2022 Kontact/Kmail will not display my email. It looks like the problem is with the akonadi server. If I try to start Kontact in a termal I get the following output:
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
org.kde.pim.akonadiserver: Starting up the Akonadi Server...
org.kde.pim.akonadiserver: database server stopped unexpectedly
org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
org.kde.pim.akonadiserver: arguments: ("--defaults-file=/home/fptretter/.local/share/akonadi/mysql.conf", "--datadir=/home/fptretter/.local/share/akonadi/db_data/", "--socket=/run/user/1001/akonadi/mysql.sock
et", "--pid-file=/run/user/1001/akonadi/mysql.pid")
org.kde.pim.akonadiserver: stdout: ""
org.kde.pim.akonadiserver: stderr: "2022-06-12 12:15:28 0 [Note] /usr/bin/mysqld (server 10.8.3-MariaDB) starting as process 4843 ...\n"
org.kde.pim.akonadiserver: exit code: 1
org.kde.pim.akonadiserver: process error: "Unknown error"
org.kde.pim.akonadiserver: Shutting down AkonadiServer...
org.kde.pim.akonadicontrol: Application '/usr/bin/akonadiserver' exited normally...
Found no modules in speech-dispatcher. No text to speech possible.
Cannot initialize model with data QJsonObject(). missing: QJsonValue(string, "urls")
org.kde.pim.akonadicore: Job error: "" for collection: QVector()
org.kde.pim.messagelist: Failed to load tags ""
org.kde.pim.mailcommon: failed to retrieve tags ""
I saw someone post something similar but that was 19 days ago and I believe his exit code was 6 whereas mine is 1.
I also tried akonadictl status and got this output:
Akonadi Control: stopped
Akonadi Server: stopped
Akonadi Server Search Support: available (Remote Search, Akonadi Search Plugin)
Available Agent Types: akonadi_akonotes_resource, akonadi_archivemail_agent, akonadi_birthdays_resource, akonadi_contacts_resource, akonadi_davgroupware_resource, akonadi_etesync_resource, akonadi_ews_resourc
e, akonadi_ewsmta_resource, akonadi_followupreminder_agent, akonadi_google_resource, akonadi_ical_resource, akonadi_icaldir_resource, akonadi_imap_resource, akonadi_indexing_agent, akonadi_knut_resource, akon
adi_kolab_resource, akonadi_maildir_resource, akonadi_maildispatcher_agent, akonadi_mailfilter_agent, akonadi_mailmerge_agent, akonadi_mbox_resource, akonadi_migration_agent, akonadi_mixedmaildir_resource, ak
onadi_newmailnotifier_agent, akonadi_notes_resource, akonadi_openxchange_resource, akonadi_pop3_resource, akonadi_sendlater_agent, akonadi_tomboynotes_resource, akonadi_unifiedmailbox_agent, akonadi_vcard_res
ource, akonadi_vcarddir_resource
Any help or advice will be appreciated.
