I haven’t been so attentive to the updates recently.
After the last one, only a few things work.
The systems boots normally, but many programs and even some settings are not opening anymore.
I tried re-installing some programs or changing them, but nothing works.
I thought of re-installing the whole thing, but I cannot even burn the iso file on a usb drive.
Does anyone have ideas?
Kernel: 5 . 10 . 53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11 . 1 . 0
parameters: BOOT_IMAGE=/boot/vmlinuz-5 . 10-x86_64
root=UUID=d685df21-3d1c-4846-a77a-88fc6ef652d4 rw quiet udev . log_priority=3
Desktop: Xfce 4 . 16 . 0 tk: Gtk 3 . 24 . 29 info: xfce4-panel wm: xfwm 4 . 16 . 1 vt: 7
dm: LightDM 1 . 30 . 0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 5570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0DRPKR v: X07 serial: <filter> UEFI: Dell v: 1 . 0 . 0
date: 08/07/2017
ID-1: BAT0 charge: 32 . 3 Wh (100 . 0%) condition: 32 . 3/42 . 0 Wh (76 . 8%)
volts: 12 . 8 min: 11 . 4 model: SMP DELL Y3F7Y6B type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 7 . 54 GiB used: 4 . 08 GiB (54 . 1%)
RAM Report: permissions: Unable to run dmidecode . Root privileges required .
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 699 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 699 2: 700 3: 700
4: 700 5: 700 6: 700 7: 701 8: 700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02 . 0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:6a06 class-ID: 0e02
Display: x11 server: X . Org 1 . 20 . 11 compositor: xfwm4 v: 4 . 16 . 1 driver:
loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 . 0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20 . 0x11 . 2")
s-diag: 582mm (22 . 9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4 . 6 Mesa 21 . 1 . 5
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f . 3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5 . 10 . 53-1-MANJARO running: yes
Sound Server-2: JACK v: 1 . 9 . 19 running: no
Sound Server-3: PulseAudio v: 14 . 2 running: yes
Sound Server-4: PipeWire v: 0 . 3 . 32 running: no
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus-ID: 02:00 . 0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802 . 11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel modules: wl port: d000
bus-ID: 03:00 . 0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0 . 8 bus-ID: 1-7:6
chip-ID: 0cf3:e009 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 8 state: up address: <filter>
Message: No logical block device data found .
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3 . 0 port: f060 bus-ID: 00:17 . 0 chip-ID: 8086 . 282a rev: 21 class-ID: 0104
Local Storage: total: 4 . 78 TiB used: 4 . 06 TiB (85 . 0%)
SMART Message: Required tool smartctl not installed . Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC311 SATA 256GB
size: 238 . 47 GiB block-size: physical: 4096 B logical: 512 B speed: 6 . 0 Gb/s
type: SSD serial: <filter> rev: 0P10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: A-Data model: HD830
size: 4 . 55 TiB block-size: physical: 4096 B logical: 4096 B type: N/A
serial: <filter> rev: 9203 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C2
dev-links: cdrom
ID-1: / raw-size: 237 . 97 GiB size: 233 . 24 GiB (98 . 01%)
used: 143 . 96 GiB (61 . 7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: d685df21-3d1c-4846-a77a-88fc6ef652d4
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99 . 80%)
used: 296 KiB (0 . 1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 8337-BA51
ID-3: /run/media/nicolo/0a5b9c57-6300-488a-ad6f-b0128787733f
raw-size: 4 . 55 TiB size: 4 . 51 TiB (99 . 19%) used: 3 . 92 TiB (86 . 9%) fs: ext4
dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 0a5b9c57-6300-488a-ad6f-b0128787733f
Alert: No swap data was found .
Message: No unmounted partitions found .
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2 . 0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2 . 0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-2:8 info: Logitech Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2 . 0 speed: 1 . 5 Mb/s
power: 100mA chip-ID: 046d:c018 class-ID: 0301
Device-3: 1-5:4 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 2 rev: 2 . 0 speed: 480 Mb/s power: 500mA
Device-4: 1-6:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2 . 0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-5: 1-7:6 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2 . 0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3 . 0 speed: 5 Gb/s
Device-1: 2-3:61 info: A-DATA HD830 type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3 . 0 speed: 5 Gb/s power: 896mA chip-ID: 125f:a84a
class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42 . 0 C mobo: 37 . 0 C sodimm: SODIMM C gpu: amdgpu
temp: 43 . 0 C
Fan Speeds (RPM): cpu: 0
Processes: 259 Uptime: 1d 10h 42m wakeups: 163 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11 . 1 . 0 clang: 12 . 0 . 1 Packages: pacman: 1544
lib: 321 flatpak: 0 Shell: Bash v: 5 . 1 . 8 running-in: xfce4-terminal
inxi: 3 . 3 . 06
