After update Manjaro linux is not working
Some time ago I updated the system and after that it did not start I restored the system with snapshot and waited a week today I updated the system, and it does not work again
PS. sorry for the screens I can not do otherwise
PS2. system settings in profile
Now I am booted from snapshot
neofetch:
██████████████████  ████████   alexbespik@pc
██████████████████  ████████   OS: Manjaro Linux x86_64
██████████████████  ████████   Host: ASUS TUF Gaming F15 FX506LH_FX506LH 1.0
████████            ████████   Kernel: 5.15.131-1-MANJARO
████████  ████████  ████████   Uptime: 6 mins
████████  ████████  ████████   Packages: 2043 (pacman), 78 (flatpak), 18 (snap)
████████  ████████  ████████   Shell: bash 5.1.16
████████  ████████  ████████   Resolution: 1920x1080
████████  ████████  ████████   DE: Plasma 5.27.8
████████  ████████  ████████   WM: KWin
████████  ████████  ████████   WM Theme: Wings-Dark-Aurorae
████████  ████████  ████████   Theme: [Plasma]
████████  ████████  ████████   Icons: Papirus-Dark [Plasma], Papirus-Dark [GTK2/3]
                               Terminal: konsole
                               CPU: Intel i5-10300H (8) @ 3.000GHz
                               GPU: Intel CometLake-H GT2 [UHD Graphics]
                               GPU: NVIDIA 01:00.0 NVIDIA Corporation TU117M
                               Memory: 3948MiB / 31940MiB
Moderator edit: Removed useless, unreadable photos
In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
neofetch is not very helpful
A good start for system info is:
inxi -Fazy
Though, it might be most helpful to get the logs from when you fail to start.
https://forum.manjaro.org/t/howto-use-public-command-line-pastebin-services-without-installing-anything/38378
  Kernel: 5.15.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2023-10-22_01-13-23/@/boot/vmlinuz-5.15-x86_64
    root=UUID=1de0527b-6c92-4038-88b7-7a7af1aab7cd
    rootflags=defaults,discard=async,subvol=timeshift-btrfs/snapshots/2023-10-22_01-13-23/@
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LH_FX506LH
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FX506LH v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FX506LH.309 date: 02/02/2021
  ID-1: BAT1 charge: 25.6 Wh (62.4%) condition: 41.0/48.1 Wh (85.2%)
    volts: 11.9 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: N/A
  Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2841 high: 2956 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2726 2: 2718 3: 2830
    4: 2956 5: 2766 6: 2902 7: 2913 8: 2920 bogomips: 40009
  Type: retbleed mitigation: Enhanced IBRS
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU117M vendor: ASUSTeK driver: nvidia v: 535.104.05
    alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f99
    class-ID: 0300
  Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 322e:202c
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
    hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.7-1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 30.46 GiB unified: yes
  API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 driver: nvidia v: 535.104.05
    device-ID: 10de:1f99 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 23.1.7-1
    device-ID: 8086:9bc4 surfaces: xcb,xlib
  Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
    chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  API: ALSA v: k5.15.131-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.80 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-14:4 chip-ID: 13d3:3563
  Local Storage: total: 1.38 TiB used: 692.02 GiB (49.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Kingston model: SNV2S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 43.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
    lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA007 temp: 32.9 C
    scheme: GPT
  ID-1: / raw-size: 400.77 GiB size: 400.77 GiB (100.00%)
    used: 289.36 GiB (72.2%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
  ID-2: /boot/efi raw-size: 1.06 GiB size: 1.06 GiB (99.80%)
    used: 568 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:2
  ID-3: /home raw-size: 400.77 GiB size: 400.77 GiB (100.00%)
  ID-4: /var/log raw-size: 400.77 GiB size: 400.77 GiB (100.00%)
  System Temperatures: cpu: 43.0 C pch: 57.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Processes: 297 Uptime: 14m wakeups: 1 Memory: total: 32 GiB
  available: 31.19 GiB used: 4.39 GiB (14.1%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
  clang: 16.0.6 Packages: 2139 pm: dpkg pkgs: 0 pm: pacman pkgs: 2043 libs: 523
  tools: pamac,yay pm: flatpak pkgs: 78 pm: snap pkgs: 18 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
How did you configure the hybrid graphics // nvidia ?
mhwd -l -li
I ask because your inxi report seems odd - it appears to be stating the nvidia driver is loaded, when the most common PRIME configuration would state the intel iGPU is in use.
Installed PCI configs:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:01:00.0 (0300:10de:1f99) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime            2023.03.23               false            PCI
          video-nvidia            2023.03.23               false            PCI
    video-nvidia-470xx            2023.03.23               false            PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2023.09.12                true            PCI
> 0000:00:02.0 (0300:8086:9bc4) Display controller Intel Corporation:
