After update 3rd display is not working
Hi, I have:
  • My laptop
  • Extra display vía HDMI
  • Extra display vía Display Port to USB-C
After update the monitor with USB C is not working anymore. I can move the mouse and I can see it but the screen is black. And the monitor HDMI I can see everything but it’s frozen and I can move the mouse and see it but if I do click nothing is happening. Always was working ok and I have this line to detect my USB-C display in /etc/default/grub
optimus-manager.startup=hybrid nvidia_drm.modeset=1
The line complete is:
GRUB_CMDLINE_LINUX_DEFAULT="resume=UUID=f868137e-dac2-4bd8-b260-70ad9aef5f1d udev.log_priority=3 optimus-manager.startup=hybrid nvidia_drm.modeset=1"
Always was working ok until the update.
This is my information:
      ~  inxi -zv8         ✔
  Kernel: 6.6.83-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e8ad0b83-8ba5-4838-bd74-fb0464854b35 rw
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Laptop System: PCSpecialist product: GM6PX0X v: Standard
    serial: <superuser required>
  Mobo: TongFang model: GM6PX0X v: Standard serial: <superuser required>
    part-nu: 0001 uuid: <superuser required> UEFI: American Megatrends LLC.
    v: N.1.09A02 date: 05/15/2023
  ID-1: BAT0 charge: 96.2 Wh (97.0%) condition: 99.2/99.2 Wh (100.0%)
    volts: 16.6 min: 15.5 model: standard type: Li-ion serial: <filter>
    status: not charging
  System RAM: total: 64 GiB available: 62.54 GiB used: 7.18 GiB (11.5%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 32 GiB speed: 4800 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMS5X32G2A48C40A2-PC serial: N/A
  Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
  Info: model: 13th Gen Intel Core i9-13900HX bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x12C
  Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
    st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
    KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
  Speed (MHz): avg: 800 min/max: 800/5200:5400:3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
    24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800
    bogomips: 154880
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: AIstone Global
    driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4
    bus-ID: 00:02.0 chip-ID: 8086:a788 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
    vendor: AIstone Global driver: nvidia v: 570.133.07
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-5
    empty: DP-3,DP-4,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:28a0 class-ID: 0300
  Device-3: Trust USB Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 145f:0203
    class-ID: 0102 serial: <filter>
  Device-4: Chicony FHD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 04f2:b7c2
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3128x1920 s-dpi: 96 s-size: 826x507mm (32.52x19.96")
    s-diag: 969mm (38.16")
  Monitor-1: HDMI-A-5 mapped: HDMI-1-0 note: disabled pos: top-right
    model: Samsung S24C650 serial: <filter> built: 2016 res: mode: 1920x1080
    hz: 60 scale: 177% (0.5625) to: 1080x1920 dpi: 94 gamma: 1.2 chroma: red:
    x: 0.643 y: 0.337 green: x: 0.314 y: 0.631 blue: x: 0.157 y: 0.059 white:
    x: 0.314 y: 0.329 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  Monitor-2: eDP-1 pos: primary,bottom-l model: BOE Display 0x0a3b
    built: 2021 res: mode: 2048x1152 hz: 60 scale: 100% (1) dpi: 151 gamma: 1.2
    chroma: red: x: 0.647 y: 0.325 green: x: 0.290 y: 0.620 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 2560x1600
  EDID-Warnings: 1: parse_edid: unknown tag 112
    drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 25.0.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
    device-ID: 8086:a788 memory: 30.53 GiB unified: yes
  API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28a0
    surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: N/A device-ID: 8086:a788
    surfaces: xcb,xlib
  Device-1: Intel Raptor Lake High Definition Audio vendor: AIstone Global
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  Device-2: NVIDIA AD107 High Definition Audio vendor: AIstone Global
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  API: ALSA v: k6.6.83-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: wireplumber
    status: active tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: AIstone Global driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 3a:00.0
  IF: enp58s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.86 TiB used: 631.69 GiB (33.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: solidgm model: SSDPFKNU020TZ
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 120 GiB size: 117.81 GiB (98.17%) used: 86.88 GiB (73.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: e8ad0b83-8ba5-4838-bd74-fb0464854b35
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 539B-5961
  ID-3: /home raw-size: 1.34 TiB size: 1.31 TiB (98.35%)
    used: 544.82 GiB (40.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: 49795415-6145-464f-af91-3da018e865f9
  ID-4: /mnt/raspberryPi raw-size: N/A size: 937.33 GiB
    used: 284.41 GiB (30.3%) fs: cifs dev: /dev/data
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: f868137e-dac2-4bd8-b260-70ad9aef5f1d
  Device-1: 1-2:2 info: Trust Primo Deskset type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 145f:0328 class-ID: 0301
  Device-2: 1-3:3 info: Trust USB Camera type: video,audio
    chip-ID: 145f:0203 class-ID: 0102 serial: <filter>
  Device-3: 1-5:4 info: Chicony FHD Webcam type: video driver: uvcvideo
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b7c2 class-ID: 0e02 serial: <filter>
  Device-4: 1-6:5 info: Integrated Express ITE Device(8233)
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 048d:7000 class-ID: 0300
  Device-5: 1-8:6 info: Integrated Express ITE Device(8176) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5000 class-ID: 0301
  Device-6: 1-10:7 info: Integrated Express ITE Device(8291)
    chip-ID: 048d:ce00 class-ID: 0300
  Device-7: 1-14:8 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1757 pm: pacman pkgs: 1694 libs: 432 tools: pamac,yay pm: flatpak
    pkgs: 49 pm: snap pkgs: 14
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    4: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    5: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    6: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    7: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    8: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    9: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    10: https://mirror.init7.net/manjaro/stable/$repo/$arch
    11: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    12: https://mirror.23m.com/manjaro/stable/$repo/$arch
    13: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    14: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    15: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    16: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    17: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    18: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    19: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    20: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    21: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    22: https://manjaro.ynh.ovh/stable/$repo/$arch
    23: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    24: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    25: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    27: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    28: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    29: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    30: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    31: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    32: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    33: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    34: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    35: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    36: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    37: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    38: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    39: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    40: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    41: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    42: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    43: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    44: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    45: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    46: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    49: http://manjaro.grena.ge/stable/$repo/$arch
    50: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    52: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    53: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    54: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    55: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    57: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    58: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    59: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    60: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    62: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    65: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    66: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    67: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    68: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    69: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    70: http://manjaro.mirror.ac.za/stable/$repo/$arch
    71: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    72: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    73: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    74: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    75: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    76: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    78: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    79: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    80: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    81: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    82: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    83: https://linorg.usp.br/manjaro/stable/$repo/$arch
    84: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    85: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    86: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    87: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    88: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    89: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    90: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    91: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    92: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    93: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    94: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    95: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    96: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    97: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    98: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    99: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    100: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 500
  1: cpu: 14.1% command: firefox pid: 3768 mem: 533.8 MiB (0.8%)
  2: cpu: 7.6% command: firefox pid: 4035 mem: 336.0 MiB (0.5%)
  3: cpu: 7.3% command: electron pid: 2883 mem: 343.8 MiB (0.5%)
  4: cpu: 6.5% command: Xorg pid: 1531 mem: 156.0 MiB (0.2%)
  5: cpu: 4.3% command: code pid: 5238 mem: 238.8 MiB (0.3%)
  Memory top: 5 of 500
  1: mem: 533.8 MiB (0.8%) command: firefox pid: 3768 cpu: 14.1%
  2: mem: 486.0 MiB (0.7%) command: plasmashell pid: 2029 cpu: 1.6%
  3: mem: 445.2 MiB (0.6%) command: firefox pid: 3872 cpu: 1.8%
  4: mem: 385.0 MiB (0.6%) command: electron pid: 2808 cpu: 2.7%
  5: mem: 343.8 MiB (0.5%) command: electron pid: 2883 cpu: 7.3%
  Processes: 500 Power: uptime: 16m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 25 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: kitty
    inxi: 3.3.37
I hope someone can help me please. It is possible do a roll back?
Thanks!
I did a rollback one week ago with Timeshift and it’s working OK right now but now I feel afraid with the updates. What can I do?
thanks
Perform the update.
The issue can’t possibly be diagnosed when it doesn’t exist.
If it’s not running properly after the update, the first thing I would try is to login into a wayland session.
Also, please provide inxi command output again after the update.
That program is no longer in the Manjaro repos and hasn’t been maintained for years. Please see the following for alternatives:
Please also see:
Ok I will try to do it again this afternoon and I will bring the information here. I hope timeshift continue working good like before.
Ok after the update I will post the inxi command. When I updated the first time continue working ok, the problem was when I turned of my laptop and next day I turn on again :frowning:
Thanks @Yochanan I have read the post and I will try with Optimus GPU switcher too but I need to uninstall optimus-manager if I understood ok. This means I need a different command in my /etc/default/grub/ to detect the display?
I have this right now:
thanks to all and I will keep posting here
One question more before update this afternoon:
When I’m trying to update, in the GUI I have this message:
Error
Falled to prepare transaction
could not satisfy dependencies:
- removing lib32-expat breaks dependency 'lib32-expat' required by lib32-fontconfig
- removing lib32-expat breaks dependency 'libexpat.so=1-32' required by lib32-fontconfig
- removing lib32-libcap breaks dependency 'lib32-libcap' required by lib32-systemd
Mod edit: Replaced screenshot with text extracted from it
And for that I did vía terminal:
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
it is possible something was broken because I did in that way? I always use the GUI to update but in this case, I can’t and when I did yesterday the command before, the display stop working.
I prefer ask before do the update again.
Thanks!
I removed the lib32x files from my partner’s computer after she go that message, and blocked the multilib repository. As she isn’t using WINE or Steam.
I have STEAM, so maybe I need to keep it, right?
Thanks
Yes, someone with Games will have to deal with this. I don’t use the lib32s either.
Could you please post the complete output, from start to finish, of:
sudo pacman -Syu
I have a feeling this may be related to having the Community repo still active in the /etc/pacman.conf file. If so, please read the following pinned post:
You are right, I did the command and:
[sudo] password for diego:
:: Synchronising package databases...
 core is up to date
 extra is up to date
 community.db failed to download
error: failed retrieving file 'community.db' from mirrors.nic.cz : The requested URL returned error: 404
error: failed retrieving file 'community.db' from ftp.gwdg.de : The requested URL returned error: 404
error: failed retrieving file 'community.db' from mirror.it4i.cz : The requested URL returned error: 404
error: failed retrieving file 'community.db' from mirror.alpix.eu : The requested URL returned error: 404
error: failed retrieving file 'community.db' from ct.mirror.garr.it : The requested URL returned error: 404
error: failed retrieving file 'community.db' from nnenix.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'community.db' from manjaro.c3sl.ufpr.br : Failed to connect to manjaro.c3sl.ufpr.br port 443 after 3692 ms: Could not connect to server
error: failed retrieving file 'community.db' from manjaro.repo.cure.edu.uy : The requested URL returned error: 404
error: failed to synchronize all databases (failed to retrieve some files)
and If I remove the lines like the post that you sent me to fix it I can see:
      ~  sudo pacman -Syu         1 ✘  8s 
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
warning: dependency cycle detected:
warning: libcap will be installed before its systemd-libs dependency
warning: egl-gbm will be installed before its mesa dependency
warning: egl-x11 will be installed before its mesa dependency
warning: xdg-desktop-portal-kde will be installed before its plasma-workspace dependency
warning: lib32-pam will be installed before its lib32-systemd dependency
warning: libcamera-ipa will be installed before its libcamera dependency
warning: mhwd-nvidia will be installed before its mhwd-db dependency
Packages (448) abseil-cpp-20250127.0-2  alsa-card-profiles-1:1.4.1-1  android-tools-35.0.2-12  android-udev-20250314-1  archlinux-appstream-data-20250317-1
               ark-24.12.3-1  aspnet-targeting-pack-9.0.3.sdk104-1  at-spi2-core-2.56.0-1  attica-6.12.0-1  audiocd-kio-24.12.3-1  baloo-6.12.0-1
               baloo-widgets-24.12.3-1  bash-5.2.037-2  bluedevil-1:6.3.3-1  bluez-5.80-1  bluez-libs-5.80-1  bluez-qt-6.12.0-1  breeze-6.3.3-1  breeze-gtk-6.3.3-1
               breeze-icons-6.12.0-1  breeze5-6.3.3-1  ca-certificates-mozilla-3.109-1  cairo-1.18.4-1  cfitsio-1:4.6.0-4  chromaprint-1.5.1-10  containerd-2.0.4-1
               coreutils-9.6-4  dbus-1.16.2-1  device-mapper-2.03.31-1  dhcpcd-10.2.2-1  diffutils-3.11-2  dkms-3.1.6-1  docker-1:28.0.1-1  dolphin-24.12.3-1
               dolphin-plugins-24.12.3-1  dotnet-runtime-9.0.3.sdk104-1  dotnet-sdk-9.0.3.sdk104-1  dotnet-targeting-pack-9.0.3.sdk104-1  egl-gbm-1.1.2-1
               egl-wayland-4:1.1.18-1  egl-x11-1.0.0-1  electron33-33.4.3-1  electron34-34.3.2-1  elisa-24.12.3-1  exfatprogs-1.2.8-1  expat-2.7.0-1  faac-1.31.1-1
               faad2-2.11.2-1  ffmpeg-2:7.1-7  ffmpeg4.4-4.4.5-3  ffmpegthumbs-24.12.3-1  filelight-24.12.3-1  firefox-136.0.2-1  fmt-11.1.4-1  fontconfig-2:2.16.1-1
               foomatic-db-gutenprint-ppds-5.3.5-1  frameworkintegration-6.12.0-1  freerdp-2:3.14.0-1  gawk-5.3.1-2  gcr-4-4.3.1-1  ghostscript-10.05.0-1  git-2.49.0-1
               glib2-2.84.0-1  glibmm-2.68-2.84.0-1  gobject-introspection-runtime-1.84.0-1  gst-libav-1.26.0-1  gst-plugin-pipewire-1:1.4.1-1  gst-plugins-bad-1.26.0-1
               gst-plugins-bad-libs-1.26.0-1  gst-plugins-base-1.26.0-1  gst-plugins-base-libs-1.26.0-1  gst-plugins-good-1.26.0-1  gst-plugins-ugly-1.26.0-1
               gstreamer-1.26.0-1  gtest-1.16.0-2  gtk3-1:3.24.49-1  gutenprint-5.3.5-1  gwenview-24.12.3-1  htop-3.4.0-1  hwdata-0.393-1  hwinfo-23.3-3  hwloc-2.12.0-1
               iana-etc-20250213-1  imagemagick-7.1.1.46-1  jdk-openjdk-24.u36-1  kaccounts-integration-24.12.3-1  kaccounts-providers-24.12.3-1
               kactivitymanagerd-6.3.3-1  kamera-24.12.3-1  karchive-6.12.0-1  kate-24.12.3-1  kauth-6.12.0-1  kbookmarks-6.12.0-1  kcalc-24.12.3-1  kcmutils-6.12.0-1
               kcodecs-6.12.0-1  kcolorscheme-6.12.0-1  kcompletion-6.12.0-1  kconfig-6.12.0-1  kconfigwidgets-6.12.0-1  kcontacts-1:6.12.0-1  kcoreaddons-6.12.0-1
               kcrash-6.12.0-1  kdbusaddons-6.12.0-1  kde-cli-tools-6.3.3-1  kde-gtk-config-6.3.3-1  kdeclarative-6.12.0-1  kdeconnect-24.12.3-1  kdecoration-6.3.3-1
               kded-6.12.0-1  kdegraphics-mobipocket-24.12.3-1  kdegraphics-thumbnailers-24.12.3-1  kdenetwork-filesharing-24.12.3-1  kdeplasma-addons-6.3.3-1
               kdesu-6.12.0-1  kdialog-24.12.3-1  kdnssd-6.12.0-1  kdoctools-6.12.0-1  keditbookmarks-24.12.3-1  kfilemetadata-6.12.0-1  kfind-24.12.3-1
               kglobalaccel-6.12.0-1  kglobalacceld-6.3.3-1  kguiaddons-6.12.0-1  khelpcenter-24.12.3-1  kholidays-1:6.12.0-1  ki18n-6.12.0-1  kiconthemes-6.12.0-1
               kidletime-6.12.0-1  kinfocenter-6.3.3-1  kio-6.12.0-1  kio-extras-24.12.3-1  kirigami-6.12.0-1  kitemmodels-6.12.0-1  kitemviews-6.12.0-1  kitty-0.40.0-1
               kitty-shell-integration-0.40.0-1  kitty-terminfo-0.40.0-1  kjobwidgets-6.12.0-1  kmenuedit-6.3.3-1  kmod-34.1-1  knewstuff-6.12.0-1
               knotifications-6.12.0-1  knotifyconfig-6.12.0-1  konsole-24.12.3-1  kpackage-6.12.0-1  kparts-6.12.0-1  kpeople-6.12.0-1  kpipewire-6.3.3-1
               kpmcore-24.12.3-1  kpty-6.12.0-1  kquickcharts-6.12.0-1  krunner-6.12.0-1  ksanecore-24.12.3-1  kscreen-6.3.3-1  kscreenlocker-6.3.3-1  kservice-6.12.0-1
               ksshaskpass-6.3.3-1  kstatusnotifieritem-6.12.0-1  ksvg-6.12.0-1  ksystemlog-24.12.3-1  ksystemstats-6.3.3-1  ktexteditor-6.12.0-1  ktexttemplate-6.12.0-1
               ktextwidgets-6.12.0-1  kunitconversion-6.12.0-1  kuserfeedback-6.12.0-1  kvantum-1.1.4-1  kwallet-6.12.0-1  kwallet-pam-6.3.3-1  kwalletmanager-24.12.3-1
               kwayland-6.3.3-1  kwayland-integration-6.3.3-1  kwidgetsaddons-6.12.0-1  kwin-6.3.3.1-1  kwindowsystem-6.12.0-1  kwrited-6.3.3-1  kxmlgui-6.12.0-1
               layer-shell-qt-6.3.3-1  ldb-2:4.22.0-1  lib32-at-spi2-core-2.56.0-1  lib32-audit-4.0.3-1  lib32-cairo-1.18.4-1  lib32-dbus-1.16.2-1  lib32-expat-2.7.0-1
               lib32-fontconfig-2:2.16.1-1  lib32-gettext-0.24-1  lib32-glib2-2.84.0-1  lib32-gtk3-1:3.24.49-1  lib32-libcap-2.75-1  lib32-libnghttp2-1.65.0-1
               lib32-libssh2-1.11.1-1  lib32-libtasn1-4.20.0-1  lib32-libunistring-1.3-1  lib32-libxkbcommon-1.8.1-1  lib32-libxkbcommon-x11-1.8.1-1
               lib32-libxshmfence-1.3.3-1  lib32-mesa-1:25.0.1-2  lib32-nss-3.109-1  lib32-nvidia-utils-570.133.07-1  lib32-pam-1.7.0-1  lib32-pango-1:1.56.3-1
               lib32-spirv-tools-1:1.4.309.0-1  lib32-sqlite-3.49.1-1  lib32-systemd-257.4-1  lib32-vulkan-intel-1:25.0.1-2  lib32-vulkan-nouveau-1:25.0.1-2
               lib32-vulkan-radeon-1:25.0.1-2  libadwaita-1:1.6.5-1  libarchive-3.7.7-3  libavif-1.2.1-1  libayatana-appindicator-0.5.94-1  libcamera-0.4.0-1
               libcamera-ipa-0.4.0-1  libcap-2.75-1  libcupsfilters-2.1.1-2  libebur128-1.2.6-2  libfreeaptx-0.2.2-1  libgdiplus-6.2-1  libgirepository-1.84.0-1
               libheif-1.19.7-2  libjxl-0.11.1-3  libkcddb-24.12.3-1  libkcompactdisc-24.12.3-1  libkdcraw-24.12.3-1  libkexiv2-24.12.3-1  libksane-24.12.3-1
               libkscreen-6.3.3-1  libksysguard-6.3.3-1  libmanette-0.2.11-2  libmysofa-1.3.3-1  libnghttp2-1.65.0-1  libnm-1.52.0-1  libpipewire-1:1.4.1-1
               libplasma-6.3.3-1  libqalculate-5.5.2-1  libseccomp-2.5.6-1  libsixel-1.10.5-1  libsm-1.2.6-1  libspeechd-0.12.0-1  libsrtp-1:2.7.0-1  libutempter-1.2.3-1
               libvlc-3.0.21-15  libwbclient-2:4.22.0-1  libx11-1.8.12-1  libx86emu-3.7-1  libxkbcommon-1.8.1-1  libxkbcommon-x11-1.8.1-1  libxmlb-0.3.22-1
               libxnvctrl-570.133.07-1  libxslt-1.1.43-1  libzip-1.11.3-1  linux-firmware-20250311.b69d4b74-2  linux-firmware-whence-20250311.b69d4b74-2
               linux515-5.15.179-1  linux515-headers-5.15.179-1  linux515-nvidia-570.133.07-1  linux515-virtualbox-host-modules-7.1.6-6  linux54-5.4.291-1
               linux54-headers-5.4.291-1  linux54-nvidia-570.133.07-1  linux54-virtualbox-host-modules-7.1.6-5  linux61-6.1.131-1  linux61-headers-6.1.131-1
               linux61-nvidia-570.133.07-1  linux61-virtualbox-host-modules-7.1.6-8  linux66-6.6.83-1  linux66-headers-6.6.83-1  linux66-nvidia-570.133.07-1
               linux66-virtualbox-host-modules-7.1.6-13  lvm2-2.03.31-1  man-pages-6.13-1  mesa-1:25.0.1-2  mhwd-db-20250113-1  mhwd-nvidia-570.133.07-2  milou-6.3.3-1
               modemmanager-qt-6.12.0-1  mpv-1:0.39.0-5  networkmanager-1.52.0-1  networkmanager-qt-6.12.0-1  noto-fonts-1:2025.03.01-1  npm-11.2.0-1  nss-3.109-1
               nvidia-driver-assistant-0.20.124.06-1  nvidia-settings-570.133.07-2.2  nvidia-utils-570.133.07-2  obsidian-1.8.9-2  ocean-sound-theme-6.3.3-1
               okular-24.12.3-1  opencv-4.11.0-5  oxygen-6.3.3-1  oxygen5-6.3.3-1  pango-1:1.56.3-1  partitionmanager-24.12.3-1  perl-error-0.17030-1  perl-libwww-6.78-1
               pipewire-1:1.4.1-1  pipewire-audio-1:1.4.1-1  plasma-activities-6.3.3-1  plasma-activities-stats-6.3.3-1  plasma-browser-integration-6.3.3-1
               plasma-desktop-6.3.3-1  plasma-integration-6.3.3-1  plasma-nm-6.3.3-1  plasma-pa-6.3.3-1  plasma-systemmonitor-6.3.3-1  plasma-thunderbolt-6.3.3-1
               plasma-workspace-6.3.3-1  plasma-workspace-wallpapers-6.3.3-1  plasma5-integration-6.3.3-1  plasma5support-6.3.3-1  plymouth-kcm-6.3.3-1
               polkit-kde-agent-6.3.3-1  poppler-25.03.0-1  poppler-glib-25.03.0-1  poppler-qt6-25.03.0-1  powerdevil-6.3.3-1  print-manager-1:6.3.3-1  prison-6.12.0-1
               protobuf-30.0-3  protobuf-c-1.5.1-1  purpose-6.12.0-1  python-cryptography-44.0.2-1  python-filelock-3.18.0-1  python-jeepney-0.9.0-1
               python-keyring-25.6.0-1  python-more-itertools-10.6.0-1  qca-qt5-2.3.10-1  qca-qt6-2.3.10-1  qemu-audio-alsa-9.2.2-1  qemu-audio-dbus-9.2.2-1
               qemu-audio-jack-9.2.2-1  qemu-audio-oss-9.2.2-1  qemu-audio-pa-9.2.2-1  qemu-audio-pipewire-9.2.2-1  qemu-audio-sdl-9.2.2-1  qemu-audio-spice-9.2.2-1
               qemu-base-9.2.2-1  qemu-block-curl-9.2.2-1  qemu-block-dmg-9.2.2-1  qemu-block-gluster-9.2.2-1  qemu-block-iscsi-9.2.2-1  qemu-block-nfs-9.2.2-1
               qemu-block-ssh-9.2.2-1  qemu-chardev-baum-9.2.2-1  qemu-chardev-spice-9.2.2-1  qemu-common-9.2.2-1  qemu-desktop-9.2.2-1  qemu-docs-9.2.2-1
               qemu-emulators-full-9.2.2-1  qemu-full-9.2.2-1  qemu-hw-display-qxl-9.2.2-1  qemu-hw-display-virtio-gpu-9.2.2-1  qemu-hw-display-virtio-gpu-gl-9.2.2-1
               qemu-hw-display-virtio-gpu-pci-9.2.2-1  qemu-hw-display-virtio-gpu-pci-gl-9.2.2-1  qemu-hw-display-virtio-vga-9.2.2-1
               qemu-hw-display-virtio-vga-gl-9.2.2-1  qemu-hw-s390x-virtio-gpu-ccw-9.2.2-1  qemu-hw-usb-host-9.2.2-1  qemu-hw-usb-redirect-9.2.2-1
               qemu-hw-usb-smartcard-9.2.2-1  qemu-img-9.2.2-1  qemu-pr-helper-9.2.2-1  qemu-system-aarch64-9.2.2-1  qemu-system-alpha-9.2.2-1
               qemu-system-alpha-firmware-9.2.2-1  qemu-system-arm-9.2.2-1  qemu-system-arm-firmware-9.2.2-1  qemu-system-avr-9.2.2-1  qemu-system-hppa-9.2.2-1
               qemu-system-hppa-firmware-9.2.2-1  qemu-system-loongarch64-9.2.2-1  qemu-system-m68k-9.2.2-1  qemu-system-microblaze-9.2.2-1
               qemu-system-microblaze-firmware-9.2.2-1  qemu-system-mips-9.2.2-1  qemu-system-or1k-9.2.2-1  qemu-system-ppc-9.2.2-1  qemu-system-ppc-firmware-9.2.2-1
               qemu-system-riscv-9.2.2-1  qemu-system-riscv-firmware-9.2.2-1  qemu-system-rx-9.2.2-1  qemu-system-s390x-9.2.2-1  qemu-system-s390x-firmware-9.2.2-1
               qemu-system-sh4-9.2.2-1  qemu-system-sparc-9.2.2-1  qemu-system-sparc-firmware-9.2.2-1  qemu-system-tricore-9.2.2-1  qemu-system-x86-9.2.2-1
               qemu-system-x86-firmware-9.2.2-1  qemu-system-xtensa-9.2.2-1  qemu-tests-9.2.2-1  qemu-tools-9.2.2-1  qemu-ui-curses-9.2.2-1  qemu-ui-dbus-9.2.2-1
               qemu-ui-egl-headless-9.2.2-1  qemu-ui-gtk-9.2.2-1  qemu-ui-opengl-9.2.2-1  qemu-ui-sdl-9.2.2-1  qemu-ui-spice-app-9.2.2-1  qemu-ui-spice-core-9.2.2-1
               qemu-user-9.2.2-1  qemu-vhost-user-gpu-9.2.2-1  qemu-vmsr-helper-9.2.2-1  qpdf-12.0.0-1  qqc2-breeze-style-6.3.3-1  qqc2-desktop-style-6.12.0-1
               qt5-wayland-5.15.16+kde+r60-1  re2-1:20240702-3  runc-1.2.6-1  rust-1:1.85.1-1  samba-2:4.22.0-1  sddm-kcm-6.3.3-1  sdl2-compat-2.32.52-1
               sdl2_image-2.8.8-1  sdl3-3.2.8-1  shaderc-2025.1-1  signon-kwallet-extension-24.12.3-1  skanlite-24.12.3-1  smbclient-2:4.22.0-1  snapd-2.68-1
               solid-6.12.0-1  sonnet-6.12.0-1  spectacle-1:6.3.3-1  spirv-tools-1:1.4.309.0-1  svt-av1-3.0.1-1  syndication-6.12.0-1  syntax-highlighting-6.12.0-1
               systemd-257.4-1  systemd-libs-257.4-1  systemd-sysvcompat-257.4-1  systemsettings-6.3.3-1  threadweaver-6.12.0-1  tree-sitter-0.25.3-1  vlc-3.0.21-15
               vte-common-0.78.4-1  vte3-0.78.4-1  vulkan-intel-1:25.0.1-2  vulkan-nouveau-1:25.0.1-2  vulkan-radeon-1:25.0.1-2  wine-10.3-1  xapian-core-1:1.4.27-1
               xdg-desktop-portal-kde-6.3.3-1  xorg-xauth-1.1.4-1  xorg-xinit-1.4.4-1  yakuake-24.12.3-1  zvbi-0.2.44-1
Total Installed Size:  9769,44 MiB
Net Upgrade Size:       633,71 MiB
But now I don’t know if I need to do in this way or follow the other answers that I received previously
Sorry for all the questions
Everything looks fine - you can proceed with the update. The dependency cycle warnings are just advising that some packages will be installed first as other upgraded packages now require them.
Now that you have removed the Community repo, you should be able to do your updates as you have normally been doing them.
And don’t forget to check for .pacnew/.pacsave files:
pacdiff -o
This is the inxi command after the update and I have the same problem with the display :frowning:
  System RAM: total: 64 GiB available: 62.54 GiB used: 6.18 GiB (9.9%)
    microcode: 0x12C
  Speed (MHz): avg: 909 min/max: 800/5200:5400:3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 909 2: 909 3: 909 4: 909
    5: 909 6: 909 7: 909 8: 909 9: 909 10: 909 11: 909 12: 909 13: 909 14: 909
    15: 909 16: 909 17: 909 18: 909 19: 909 20: 909 21: 909 22: 909 23: 909
    24: 909 25: 909 26: 909 27: 909 28: 909 29: 909 30: 909 31: 909 32: 909
    bogomips: 154880
    xtopology xtpr
    link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-3,HDMI-A-5
    empty: DP-4,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:28a0 class-ID: 0300
  Screen-1: 0 s-res: 2560x2368 s-dpi: 96 s-size: 676x626mm (26.61x24.65")
    s-diag: 921mm (36.27")
  Monitor-1: HDMI-1-0 pos: top res: mode: 1920x1080 hz: 60
    scale: 177% (0.5625) to: 1080x1920 dpi: 94 size: 521x293mm (20.51x11.54")
    diag: 598mm (23.53") modes: N/A
  Monitor-2: eDP-1 pos: primary,bottom res: mode: 2560x1600 hz: 240
    scale: 100% (1) dpi: 189 size: 344x215mm (13.54x8.46") diag: 406mm (15.97")
    modes: N/A
    inactive: wayland
    surfaces: xcb,xlib
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.86 TiB used: 631.39 GiB (33.1%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 28.9 C scheme: GPT
  ID-1: / raw-size: 120 GiB size: 117.81 GiB (98.17%) used: 86.7 GiB (73.6%)
    uuid: 539B-5961
    used: 544.69 GiB (40.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 284.42 GiB (30.3%) fs: cifs dev: /dev/data
  Device-6: 1-10:8 info: Integrated Express ITE Device(8291)
  Device-7: 1-14:10 info: Intel AX211 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 40.0 C mobo: N/A
  Packages: 1756 pm: pacman pkgs: 1694 libs: 432 tools: pamac,yay pm: flatpak
    pkgs: 48 pm: snap pkgs: 14
    1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    3: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    4: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    6: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    8: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 545
  1: cpu: 55.4% command: firefox pid: 3781 mem: 523.2 MiB (0.8%)
  2: cpu: 28.2% command: firefox pid: 4036 mem: 344.3 MiB (0.5%)
  3: cpu: 20.8% command: zsh pid: 4388 mem: 9.17 MiB (0.0%)
  4: cpu: 13.8% command: electron pid: 3389 mem: 336.3 MiB (0.5%)
  5: cpu: 12.3% command: firefox pid: 3886 mem: 449.9 MiB (0.7%)
  Memory top: 5 of 545
  1: mem: 547.4 MiB (0.8%) command: plasmashell pid: 2559 cpu: 6.3%
  2: mem: 523.2 MiB (0.8%) command: firefox pid: 3781 cpu: 55.4%
  3: mem: 449.9 MiB (0.7%) command: firefox pid: 3886 cpu: 12.3%
  4: mem: 344.3 MiB (0.5%) command: firefox pid: 4036 cpu: 28.2%
  5: mem: 336.3 MiB (0.5%) command: electron pid: 3389 cpu: 13.8%
  Processes: 545 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
    tool: systemctl
    inxi: 3.3.37
Now I will try to move to wayland or see if removing optimus manager and changing to Optimus GPU switcher works.
I don’t know why this is happening. I will update soon
Finally I solved the problem and was a mix of the answers of @scotty65 (different problem, with my packages) @Yochanan and @Wollie (display):
Like I said in my configuration always I was using HYBRID and was working perfect because with Nvidia or Integrated I had problems before the update.
GRUB_CMDLINE_LINUX_DEFAULT=".... optimus-manager.startup=hybrid nvidia_drm.modeset=1"
After the update, I tried to use in Wayland and works perfectly but was not in x11.
I wanted to solve it in x11 and I tried removing optimus-manager and I installed Optimus GPU switcher. Doing this was not working but I changed to Nvidia and now yes, is working in x11 perfectly.
Thanks to everyone to help me
